looks like this firmware is still in beta - do you know when it will be released as stable? or should i do it anyway. let me know! and thx for the quick response.
Please do it anyway but do a backup of your configuration before. It will need a few more weeks (or months) before this firmware will be marked stable.
This firmware based on MTK closed source wifi driver. The wifi is better than open source wifi driver version. And people also have Positive feedback on it.
Does it also fix the PPPoE issues? With the original firmware I cant connect to the internet using PPPoE. It just doesnt work. Even turning on IPV6, it doesnt work.
Hi.
On my Flint 2 randomly loses connection to the network.
When I change Flint 2 to TP-Link, the connection works properly.
My internet is FTTH with ONT terminal.
Firmware: v4.5.7
Where is the problem ?
My router is working fine over 60days and version 4.5.6. Use Vodafone UK, supply by City Fibre - VLAN ID is 911.
Just make sure ONT all green lights which have Internet access. If not lights then Flint 2 still can’t reach Internet access for some issue like provider dns or server down or other things.
