Kern.warn kernel dhcp request loop
I have a beryl router and i have modified the guest wifi network but now for some reason clients attached to my non guest network are constantly doing dhcp requests or dnsmasq is restarting constantly, i don't see this issue on my "iot" network.
Thu Jun 27 19:07:47 2024 kern.warn kernel: [ 2105.955725]
Thu Jun 27 19:07:49 2024 daemon.info dnsmasq-dhcp[25552]: DHCPREQUEST(br-lan) 192.168.8.209 LAPTOP:MAC:ADDRESS
Thu Jun 27 19:07:49 2024 daemon.info dnsmasq-dhcp[25552]: DHCPACK(br-lan) 192.168.8.209 LAPTOP:MAC:ADDRESS LAPTOP
Thu Jun 27 19:07:54 2024 kern.notice kernel: [ 2113.129796] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(0), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=1]LAPTOP:MAC:ADDRESS
Thu Jun 27 19:07:54 2024 kern.notice kernel: [ 2113.146569] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647:  Recv Assoc from STA - LAPTOP:MAC:ADDRESS
Thu Jun 27 19:07:54 2024 kern.notice kernel: [ 2113.155892] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)...
Thu Jun 27 19:07:54 2024 kern.notice kernel: [ 2113.165007] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Thu Jun 27 19:07:54 2024 kern.notice kernel: [ 2113.171054] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Thu Jun 27 19:07:55 2024 kern.notice kernel: [ 2113.280879] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Thu Jun 27 19:07:55 2024 kern.notice kernel: [ 2113.287565] 7981@C15L3,PeerPairMsg2Action() 6202: ===>Receive msg 2
Thu Jun 27 19:07:55 2024 kern.notice kernel: [ 2113.294338] 7981@C15L3,WPABuildPairMsg3() 5557: <=== send Msg3 of 4-way
Thu Jun 27 19:07:55 2024 kern.notice kernel: [ 2113.301065] 7981@C15L3,PeerPairMsg4Action() 6632: ===>Receive msg 4
Thu Jun 27 19:07:55 2024 daemon.info dnsmasq-dhcp[25552]: DHCPREQUEST(br-lan) 192.168.8.209 LAPTOP:MAC:ADDRESS
Thu Jun 27 19:07:55 2024 daemon.info dnsmasq-dhcp[25552]: DHCPACK(br-lan) 192.168.8.209 LAPTOP:MAC:ADDRESS LAPTOP
Thu Jun 27 19:07:55 2024 kern.warn kernel: [ 2113.313876] 7981@C15L2,PeerPairMsg4Action() 6994: AP SETKEYS DONE(ra0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=1 from LAPTOP:MAC:ADDRESS
Thu Jun 27 19:07:57 2024 daemon.info dnsmasq-dhcp[25552]: DHCPREQUEST(br-lan) 192.168.8.209 LAPTOP:MAC:ADDRESS
Thu Jun 27 19:07:57 2024 daemon.info dnsmasq-dhcp[25552]: DHCPACK(br-lan) 192.168.8.209 LAPTOP:MAC:ADDRESS LAPTOP
Thu Jun 27 19:08:00 2024 kern.notice kernel: [ 2118.557187] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(0), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=1]LAPTOP:MAC:ADDRESS
Thu Jun 27 19:08:00 2024 kern.notice kernel: [ 2118.576272] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647:  Recv Assoc from STA - LAPTOP:MAC:ADDRESS
Thu Jun 27 19:08:00 2024 kern.notice kernel: [ 2118.585578] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)...
Thu Jun 27 19:08:00 2024 kern.notice kernel: [ 2118.594693] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Thu Jun 27 19:08:00 2024 kern.notice kernel: [ 2118.600733] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Thu Jun 27 19:08:00 2024 kern.notice kernel: [ 2118.711518] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Thu Jun 27 19:08:00 2024 kern.notice kernel: [ 2118.718209] 7981@C15L3,PeerPairMsg2Action() 6202: ===>Receive msg 2
Thu Jun 27 19:08:00 2024 kern.notice kernel: [ 2118.724982] 7981@C15L3,WPABuildPairMsg3() 5557: <=== send Msg3 of 4-way
Thu Jun 27 19:08:00 2024 kern.notice kernel: [ 2118.731737] 7981@C15L3,PeerPairMsg4Action() 6632: ===>Receive msg 4
Thu Jun 27 19:08:00 2024 daemon.info dnsmasq-dhcp[25552]: DHCPREQUEST(br-lan) 192.168.8.209 LAPTOP:MAC:ADDRESS
Thu Jun 27 19:08:00 2024 daemon.info dnsmasq-dhcp[25552]: DHCPACK(br-lan) 192.168.8.209 LAPTOP:MAC:ADDRESS LAPTOP
Thu Jun 27 19:08:00 2024 kern.warn kernel: [ 2118.744472] 7981@C15L2,PeerPairMsg4Action() 6994: AP SETKEYS DONE(ra0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=1 from LAPTOP:MAC:ADDRESS
root@GL-MT3000:~# cat /etc/config/network
config interface 'loopback'
        option device 'lo'
        option proto 'static'
        option ipaddr '127.0.0.1'
        option netmask '255.0.0.0'
config globals 'globals'
        option ula_prefix 'fdf3:600d:9e9e::/48'
config device
        option name 'br-lan'
        option type 'bridge'
        list ports 'eth1'
        option macaddr '94:83:c4:4f:62:21'
config device
        option name 'eth1'
        option macaddr ''
config interface 'lan'
        option device 'br-lan'
        option ipaddr '192.168.8.1'
        option ip6assign '60'
        option isolate '0'
config device
        option name 'eth0'
        option macaddr ''
config interface 'wan'
        option device 'eth0'
        option proto 'dhcp'
        option force_link '0'
        option ipv6 '0'
        option metric '10'
config interface 'wan6'
        option proto 'dhcpv6'
        option disabled '1'
        option device '@wan'
config interface 'tethering6'
        option disabled '1'
        option device '@tethering'
config interface 'wwan6'
        option disabled '1'
        option device '@wwan'
config interface 'wwan'
        option proto 'dhcp'
        option metric '20'
config interface 'modem_1_1_2_6'
        option disabled '1'
        option device '@modem_1_1_2'
config rule 'policy_direct_rt'
        option lookup 'main'
        option suppress_prefixlength '0'
        option priority '1100'
config rule 'policy_default_rt_vpn'
        option mark '0x8000/0xc000'
        option lookup '8000'
        option priority '1101'
        option invert '1'
config rule6 'policy_direct_rt6'
config rule6 'policy_default_rt_vpn6'
        option invert '1'
config rule 'policy_default_rt_vpn_ts'
        option priority '1099'
        option mark '0x80000/0xc0000'
        option invert '0'
config device
        option bridge_empty '1'
        option name 'br-iot'
        option ipv6 '0'
config interface 'iot'
        option device 'br-iot'
        option ipaddr '192.168.100.1'
root@GL-MT3000:~# cat /etc/config/dhcp
config dnsmasq
        option domainneeded '1'
        option boguspriv '1'
        option filterwin2k '0'
        option localise_queries '1'
        option rebind_localhost '1'
        option local '/lan/'
        option domain 'lan'
        option expandhosts '1'
        option nonegcache '0'
        option authoritative '1'
        option readethers '1'
        option leasefile '/tmp/dhcp.leases'
        option resolvfile '/tmp/resolv.conf.d/resolv.conf.auto'
        option nonwildcard '1'
        option localservice '1'
        option ednspacket_max '1232'
        option rebind_protection '0'
config dhcp 'lan'
        option interface 'lan'
        option start '100'
        option limit '150'
        option leasetime '12h'
        option dhcpv4 'server'
        option ra_slaac '1'
        option force '1'
        option dhcpv6 'disabled'
        option ra 'disabled'
config dhcp 'wan'
        option interface 'wan'
        option ignore '1'
config odhcpd 'odhcpd'
        option maindhcp '0'
        option leasefile '/tmp/hosts/odhcpd'
        option leasetrigger '/usr/sbin/odhcpd-update'
        option loglevel '4'
config domain
        option name 'console.gl-inet.com'
        option ip '192.168.8.1'
config domain
        option ip '::ffff:192.168.8.1'
config dhcp 'iot'
        option start '100'
        option limit '150'
        option interface 'iot'
        list ra_flags 'none'
What if you just keep the Guest wifi settings?
You changed name to iot in this two files. Not sure if need to change other files. At least /etc/config/wireless should have some changes I think.
Try to turn off the SSID(s) one by one, see which SSID are frequently connected as the log appears, and find out if this device is your trust device.
