Kernel errors
Hey
I have AXT1800
OpenWrt 21.02-SNAPSHOT r16399+164-c67509efd7
Kernel Version 4.4.60
Is that ok kernel constantly prints to logs:
Wed Nov 22 14:30:19 2023 kern.info kernel: [27642.433036] Workqueue: events_long netcell_poll_work [kmwan]
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.441039] [<8001f784>] (unwind_backtrace) from [<8001bad4>] (show_stack+0x10/0x14)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.441308] [<8001bad4>] (show_stack) from [<80075298>] (rcu_print_detail_task_stall_rnp+0x34/0x5c)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.449121] [<80075298>] (rcu_print_detail_task_stall_rnp) from [<800790e8>] (rcu_check_callbacks+0x718/0x8f0)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.457891] [<800790e8>] (rcu_check_callbacks) from [<8007bc28>] (update_process_times+0x38/0x64)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.467957] [<8007bc28>] (update_process_times) from [<8008b9a0>] (tick_sched_timer+0x48/0x88)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.476896] [<8008b9a0>] (tick_sched_timer) from [<8007c5ac>] (__hrtimer_run_queues+0xbc/0x184)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.485402] [<8007c5ac>] (__hrtimer_run_queues) from [<8007cc18>] (hrtimer_interrupt+0xc0/0x1f8)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.494001] [<8007cc18>] (hrtimer_interrupt) from [<8040f20c>] (arch_timer_handler_virt+0x28/0x30)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.503029] [<8040f20c>] (arch_timer_handler_virt) from [<800707e0>] (handle_percpu_devid_irq+0x6c/0x84)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.511795] [<800707e0>] (handle_percpu_devid_irq) from [<8006c770>] (generic_handle_irq+0x24/0x34)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.521429] [<8006c770>] (generic_handle_irq) from [<8006ca48>] (__handle_domain_irq+0x98/0xac)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.530195] [<8006ca48>] (__handle_domain_irq) from [<80009390>] (gic_handle_irq+0x54/0x94)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.538875] [<80009390>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.547203] Exception stack(0x9d91be40 to 0x9d91be88)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.554840] be40: 104d8bea 01bdb30b 00000003 ff7f8c98 00006951 00000000 808365ec 9b3ab0c0
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.559881] be60: 104dc658 0000191d 80836514 806d2f50 01bdb30b 9d91be90 104d9bff 7f06537c
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.568038] be80: 00000013 ffffffff
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.576205] [<8000a4c0>] (__irq_svc) from [<7f06537c>] (0x7f06537c)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.579517] [<7f06537c>] (0x7f06537c) from [<7f065774>] (netcell_poll_work+0xc/0x64 [kmwan])
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.585765] [<7f065774>] (netcell_poll_work [kmwan]) from [<8003ed30>] (process_one_work+0x220/0x3b8)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.594432] [<8003ed30>] (process_one_work) from [<8003f1b0>] (worker_thread+0x2e8/0x4d0)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.603545] [<8003f1b0>] (worker_thread) from [<8004428c>] (kthread+0xf0/0xf8)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.611702] [<8004428c>] (kthread) from [<80009c28>] (ret_from_fork+0x14/0x2c)
Wed Nov 22 14:30:19 2023 kern.info kernel: [27642.618815] kworker/1:1     R running      0   121      2 0x00000000
Wed Nov 22 14:30:19 2023 kern.info kernel: [27642.629755] Workqueue: events_long netcell_poll_work [kmwan]
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.637821] [<8001f784>] (unwind_backtrace) from [<8001bad4>] (show_stack+0x10/0x14)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.638095] [<8001bad4>] (show_stack) from [<80075298>] (rcu_print_detail_task_stall_rnp+0x34/0x5c)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.645908] [<80075298>] (rcu_print_detail_task_stall_rnp) from [<80079110>] (rcu_check_callbacks+0x740/0x8f0)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.654677] [<80079110>] (rcu_check_callbacks) from [<8007bc28>] (update_process_times+0x38/0x64)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.664744] [<8007bc28>] (update_process_times) from [<8008b9a0>] (tick_sched_timer+0x48/0x88)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.673685] [<8008b9a0>] (tick_sched_timer) from [<8007c5ac>] (__hrtimer_run_queues+0xbc/0x184)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.682191] [<8007c5ac>] (__hrtimer_run_queues) from [<8007cc18>] (hrtimer_interrupt+0xc0/0x1f8)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.690787] [<8007cc18>] (hrtimer_interrupt) from [<8040f20c>] (arch_timer_handler_virt+0x28/0x30)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.699815] [<8040f20c>] (arch_timer_handler_virt) from [<800707e0>] (handle_percpu_devid_irq+0x6c/0x84)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.708583] [<800707e0>] (handle_percpu_devid_irq) from [<8006c770>] (generic_handle_irq+0x24/0x34)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.718216] [<8006c770>] (generic_handle_irq) from [<8006ca48>] (__handle_domain_irq+0x98/0xac)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.726982] [<8006ca48>] (__handle_domain_irq) from [<80009390>] (gic_handle_irq+0x54/0x94)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.735663] [<80009390>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.743990] Exception stack(0x9d91be40 to 0x9d91be88)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.751628] be40: 104d8bea 01bdb30b 00000003 ff7f8c98 00006951 00000000 808365ec 9b3ab0c0
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.756669] be60: 104dc658 0000191d 80836514 806d2f50 01bdb30b 9d91be90 104d9bff 7f06537c
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.764825] be80: 00000013 ffffffff
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.772988] [<8000a4c0>] (__irq_svc) from [<7f06537c>] (0x7f06537c)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.776303] [<7f06537c>] (0x7f06537c) from [<7f065774>] (netcell_poll_work+0xc/0x64 [kmwan])
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.782551] [<7f065774>] (netcell_poll_work [kmwan]) from [<8003ed30>] (process_one_work+0x220/0x3b8)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.791221] [<8003ed30>] (process_one_work) from [<8003f1b0>] (worker_thread+0x2e8/0x4d0)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.800332] [<8003f1b0>] (worker_thread) from [<8004428c>] (kthread+0xf0/0xf8)
Wed Nov 22 14:30:19 2023 kern.warn kernel: [27642.808489] [<8004428c>] (kthread) from [<80009c28>] (ret_from_fork+0x14/0x2c)
This is almost certainly triggered by the snapshot firmware.
Snapshots (aka “nightly builds”) are untested, unfinished and buggy.
Your only option is to switch to the next snapshot firmware (the latest version is uploaded every night) or to revert to more stable firmware branches such as beta, rc or stable.
