LAN lag
i have noticed that sometimes lag occurs on LAN connection. This lag looks like is quite regular (every fixed amount of time).
device: GL-RM1
firmware: 1.10 r2
Sending recording and logs.
recording.zip (2.5 MB)
system_logs_20260915_153817.zip (220.3 KB)
Can you confirm that this kind of periodic latency issue occurs when pinging the KVM IP address?
I will check it when I manage to replicate error. I does not occur regularly.
Thanks! Let us know what you find when you’re able to reproduce it.
i think i found the issue. looks like wifi card had turned on efficiency mode on my laptop receiving stream. when i set max performance for wifi, then ping and jitter dropped from 60ms and 40ms to 4ms and 1ms on LAN.
