LAN port as Source for VPN cascading
I'm using the GL Prune2 and set up a wireguard server. I'm connecting successfully. Additionally to the WAN (that I can use via wireguard VPN) I want to add another network. This on I connect to the 2. LAN port. A wireguard user should now be connected via the internet (WAN) to the VPN (Prune) and forwarded to the LAN (internal network without internet connection).
Would that be possible?
Thanks for hints.
Probably require adding the routing rule in the WireGaurd Server, to let the traffic routes to that LAN
OK can you help me set it up?
My Wireguard Tunnel Address is 192.168.9.1/24
The network I want to tunnel through the VPN is an internal net 172.66.x.x - what should I specify ini the Route Rule settings?
Please share the network topology with us, to clarify how to config the routing rule.
Normal Internet connected to WAN-Port, Wireguard Server set up to connect to the network from outside.
Now I want to add another network (internal network, no internet connection on it) to make it available from outside using Wireguard. The internal network can be connected to the LAN-Port.
As a user from outside, using Wireguard to connect to the Prune2, then routing to the internal network on the LAN port.
I want to make an internal network (for Updates/Deployments etc.) available from outside via the normal internet connection, since that internal network has non.
In fact I am not clarifying about this part topology.
Probably a topology figure/image to instead of the words will be better to know.
If another network is in the subnet under the Brume 2, it is supposed to be not add the routing rule.
Probably I understood and the routing rule is supposed to be:
