Hello everyone,
I need some help.
I have a PC connected to the LAN port by cable. I assigned this port to the IoT zone. The IoT interface uses the br-iot interface. I assigned the LAN port to this interface so that the PC on the LAN can communicate with devices in the IoT network. The assignment works because the PC is in the same subnet. I also have a server running on the PC. However, I cannot reach the server on the PC from Smart TVs that are in the same subnet.
The server cannot be reached. The firewall setup is correct, and the direction and ports are correct. It cannot be due to the Windows firewall.
On the router, I set up a traffic rule for RDP because I don't have a monitor, and I can access the PC from my standard network via the LAN port to which it is connected by cable. So routing for RDP works.
The network layout is:
PC LAN port connected by cable <--> IoT Wi-Fi <--> Smart TV
Unfortunately, the TVs cannot see the computer. A ping from the PC to the TV only results in a timeout.
The second thing I have found is that when the PC is connected to the IoT Wi-Fi via its wireless card instead of the cabled port, the TVs can see and reach the PC. So the problem seems to be limited to br-iot.
As soon as the PC is connected to the LAN port, communication between the devices in the IoT network stops working. As soon as it is connected via Wi-Fi, communication works and the server is reachable.
I have not enabled any isolation for either the LAN port or the IoT Wi-Fi. That means the devices within the network should be able to communicate, but this only works over Wi-Fi.
My suspicion is that something in br-iot is blocking the communication, and I don't know what it is.
Has anyone experienced a problem like this before?
Can anyone help me?
The goal is for the IoT network to remain isolated, with the sole exception of access from the main network to the IoT PC—and only in that direction via a traffic rule. The PC connected by cable should be able to communicate with the IoT Wi-Fi devices.
Thanks in advance.
