Latest beta firmware of ax 1800 flint support sqm-qos package?
I need to figure out if sqm-qos package is available for install in the latest beta firmware of flint, of if is only available gl-qos package
thanks a lot for the help
Only gl-sdk4-qos currently, hopefully they’ll add it soon, or make an alternative gui in the gl.iNet admin panel.
thanks for the reply, you think that is a good option test the beta, or stay in a stable firmware? greetings
I personally have been running the beta since it launched to the public. Can’t imagine going back😄 Most things work fine, some better. Only had a few issues.
If you do wanna make sure you have a 99% stable experience though, wait for the official or pre release, which is coming soon
Haven’t tried this myself yet, but in the new beta you can add sources yourself:
Might be worth a shot :wink:
that sounds very useful, maybe wort it the test!!
testing luci-app-qos and works well in my guest network!!
Awesome!:clap: Glad you got it working :smile:
