I have the above model and the latest firmware that shows up in the web ui is 3.019 however I see 3.024 at GL.iNet download center . Am I looking in the wrong place?
You are correct. There is some issues in upgrade so we didn’t release it. Upgrading to this version you could loose all of you settings.
If you upgrade without reserving settings, then it is fine.
