Hi all
I recently bought a hootoo travel router - the small red accent one with a power bank
I really needed it to act a a bridge to get on a hotels wifi - mainly to use the chromecast when away from home and it worked quite well but found that wifi was a bit slow on occasion
So while it works OK i thought the interface was a bit naff and then came across the GL inet range - and these look more like a more serious device
Im pretty green to them but looking at more the higher end ranges like the AR750 or the AR300M with external antennas
Is there any preference - not sure if you can use natively as a plex client of some sort yet or at least would need DLNA to share files if needed
Any recommendations or thoughts of which is better
