I thought I had everything working with my VPN setup, but then I noticed that my LAN loses Internet access when the Wireguard client is connected. However, the router itself (AR750S) has Internet access if I SSH in and try the same connectivity tests (e.g. ping 8.8.8.8). Within the LAN and across the VPN tunnel to the “AllowIPs” network, connectivity is fine. Disconnecting Wireguard immediately brings back connectivity. Some details below. Thanks!
VPN config:
root@GL-AR750S:/etc/config# cat wireguard
config proxy
option main_server 'Home'
option host <redacted>
option enable '0'
config peers 'wg_peer_9655'
option name 'Home'
option private_key <redacted>
option public_key <redacted>
option persistent_keepalive '25'
option listen_port '39977'
option end_point '<redacted>:51820'
option address '10.39.0.2/16'
option allowed_ips '10.33.0.0/16','10.39.0.0/16'
Routing table on router:
root@GL-AR750S:/etc/config# route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default fw.lan 0.0.0.0 UG 20 0 0 wlan-sta
10.33.0.0 * 255.255.0.0 U 0 0 0 wg0
10.37.0.0 * 255.255.0.0 U 20 0 0 wlan-sta
10.39.0.0 * 255.255.0.0 U 0 0 0 wg0
<vpn server ip> fw.lan 255.255.255.255 UGH 0 0 0 wlan-sta
192.168.8.0 * 255.255.255.0 U 0 0 0 br-lan
Router has Internet access:
root@GL-AR750S:/etc/config# ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8): 56 data bytes
64 bytes from 8.8.8.8: seq=0 ttl=119 time=11.936 ms
64 bytes from 8.8.8.8: seq=1 ttl=119 time=11.588 ms
But not LAN device:
C:\Users\kodbuse> ping 8.8.8.8 -t
Pinging 8.8.8.8 with 32 bytes of data:
Reply from 192.168.8.1: Destination port unreachable.
