Losing Repeater Connection Occasionally MT-3000
Hi again, I’m not savvy with this thing yet, but the previous solution when I asked this question about a month ago seemed to work for me up until recently again. (Previous solution was to update to the most recent beta firmware)
This time I’m having longer sessions before my MT-3000 disconnects.
Here’s some info and if you need anything else let me know.
Current firmware version - 4.5.0
Current firmware type - release6
kernel version - 5.4.211
logread.tar (238.5 KB)
Wed Jan 31 12:49:55 2024 cron.err crond[5386]: time disparity of 1264 minutes detected
Wed Jan 31 12:49:56 2024 daemon.notice netifd: Network device 'wgclient' link is up
Wed Jan 31 12:49:56 2024 daemon.notice netifd: Interface 'wgclient' is now up
Wed Jan 31 12:49:56 2024 daemon.info dnsmasq[5902]: exiting on receipt of SIGTERM
Wed Jan 31 12:49:56 2024 user.notice firewall: Reloading firewall due to ifup of wgclient (wgclient)
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq[9174]: Connected to system UBus
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq[9174]: started, version 2.85 cachesize 150
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq[9174]: DNS service limited to local subnets
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq[9174]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth cryptohash DNSSEC no-ID loop-detect inotify dumpfile
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq[9174]: UBus support enabled: connected to system bus
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq-dhcp[9174]: DHCP, IP range 192.168.9.100 -- 192.168.9.249, lease time 12h
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq-dhcp[9174]: DHCP, IP range 192.168.8.100 -- 192.168.8.249, lease time 12h
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq[9174]: using only locally-known addresses for domain test
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq[9174]: using only locally-known addresses for domain onion
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq[9174]: using only locally-known addresses for domain localhost
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq[9174]: using only locally-known addresses for domain invalid
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq[9174]: using only locally-known addresses for domain bind
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq[9174]: using only locally-known addresses for domain lan
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq[9174]: reading /tmp/resolv.conf.d/resolv.conf.wg
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq[9174]: using nameserver 193.138.219.228#53
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq[9174]: read /etc/hosts - 4 addresses
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq[9174]: read /tmp/hosts/dhcp.cfg01411c - 6 addresses
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq-dhcp[9174]: read /etc/ethers - 0 addresses
Wed Jan 31 12:49:59 2024 user.notice wgclient-up: env value:T_J_V_ifname=string J_V_address_external=1 USER=root ifname=wgclient ACTION=KEYPAIR-CREATED N_J_V_address_external=address-external SHLVL=2 J_V_keep=1 HOME=/ HOTPLUG_TYPE=wireguard T_J_V_interface=string J_V_ifname=wgclient T_J_V_link_up=boolean LOGNAME=root DEVICENAME= T_J_V_action=int TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin CONFIG_LIST_STATE= J_V_interface=wgclient K_J_V= action ifname link_up address_external keep interface J_V_link_up=1 J_V_action=0 T_J_V_address_external=boolean N_J_V_link_up=link-up T_J_V_keep=boolean PWD=/ JSON_CUR=J_V CONFIG_SECTIONS=global AzireVPN Mullvad FromApp group_937 group_256 group_3223 peer_2162 peer_2163 peer_2164 peer_2165 peer_2166 peer_2167 peer_2168 peer_2169 peer_2170 peer_2171 peer_2172 peer_2173 peer_2174 peer_2175 peer_2176 peer_2177 peer_2178 peer_2179 peer_2180 peer_2181 peer_2182 peer_2183 peer_2184 peer_2185 peer_2186 peer_2187 peer_2188 peer_2189 peer_2190 peer_2191 peer_2192 peer_2193 peer_2
I uploaded the log files for kernel and system as well.
Thank you guys for all you do and know.
-Tommy
I would also like to add that I’m using Mullvad on WireGuard.
At least for me, the logs look fine so far - not sure if it’s an issue with the router itself.
Did you restart the router after it got disconnected? Restarting clears the logs :frowning:
I wonder if maybe it’s the power cable I’m using? I will try to purchase a different cable and see if I see a difference in stability. Thanks for checking the log for me!
Does not mean that there isn’t a problem with the router itself - I was just not able to find one by reading the logs. But since I am not a developer, my word might be worthless. :sweat_smile:
But for me, it looks like the router rebooted.
I didn’t reboot it myself, but here’s my entire log, I realized that I didn’t send the entire thing… :no_mouth:
Tue Jan 30 15:45:02 2024 kern.notice kernel: [   48.870059] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=144, ctrl_ch2=0, cent_ch=144 DBDCIdx=1, ChBand=1, BW=0, TXStream=3, RXStream=3, scan(1)
Tue Jan 30 15:45:02 2024 kern.notice kernel: [   48.895882] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=144, ctrl_ch2=0, cent_ch=144, RxPath=7, BandIdx=1, ChBand=1, BW=0,TXStream=3, RXStream=7, scan(1)
Tue Jan 30 15:45:02 2024 kern.notice kernel: [   48.972965] 7981@C23L3,scan_partial_trigger_checker() 1615: (rax0) NumOfChannels = 5, LastScanChannel = 144, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:02 2024 kern.notice kernel: [   49.053416] 7981@C23L3,operate_loader_phy() 394: oper_cfg: prim_ch(149), ht_bw(1), extcha(1), vht_bw(1), cen_ch_2(0), PhyMode=177!
Tue Jan 30 15:45:02 2024 kern.notice kernel: [   49.065155] 7981@C23L3,operate_loader_phy() 408: oper_dev after adjust: bw(2), prim_ch(149), cen_ch_1(155), cen_ch_2(0),ext_cha(1)!
Tue Jan 30 15:45:02 2024 kern.notice kernel: [   49.076987] 7981@C23L3,operate_loader_phy() 428: oper_radio after decision: bw(2), prim_ch(149), cen_ch_1(155), cen_ch_2(0)!
Tue Jan 30 15:45:02 2024 kern.notice kernel: [   49.088255] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=149, ctrl_ch2=0, cent_ch=155 DBDCIdx=1, ChBand=1, BW=2, TXStream=3, RXStream=3, scan(0)
Tue Jan 30 15:45:02 2024 kern.notice kernel: [   49.101378] 7981@C23L3,scan_partial_trigger_checker() 1615: (rax0) NumOfChannels = 5, LastScanChannel = 144, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:02 2024 kern.notice kernel: [   49.204975] 7981@C23L3,scan_partial_trigger_checker() 1615: (rax0) NumOfChannels = 5, LastScanChannel = 144, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:03 2024 kern.notice kernel: [   49.312737] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=149, ctrl_ch2=0, cent_ch=155, RxPath=7, BandIdx=1, ChBand=1, BW=2,TXStream=3, RXStream=7, scan(0)
Tue Jan 30 15:45:03 2024 kern.notice kernel: [   49.326574] 7981@C23L3,scan_partial_trigger_checker() 1615: (rax0) NumOfChannels = 5, LastScanChannel = 144, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:03 2024 kern.err kernel: [   49.339745] 7981@C12L1,EDCCAInit() 21006: EDCCA compensation: uni_compensation=0, bw_compensation=0, final compensation=0
Tue Jan 30 15:45:03 2024 kern.notice kernel: [   49.350875] 7981@C23L3,scan_ch_restore() 252: End of SCAN(TYPE: 8, BandIdx: 1), restore to BW(2) channel 155, Total BSS[83]
Tue Jan 30 15:45:03 2024 kern.notice kernel: [   49.362013] 7981@C08L3,UpdateBeaconHandler() 1931: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Tue Jan 30 15:45:03 2024 kern.notice kernel: [   49.370371] 7981@C08L3,UpdateBeaconHandler() 1936: 	Band1 BcnInitedRnd = 279
Tue Jan 30 15:45:03 2024 kern.notice kernel: [   49.377446] 7981@C08L3,UpdateBeaconHandler() 1931: BCN_UPDATE_ENABLE_TX, OmacIdx = 11 (rax1)
Tue Jan 30 15:45:03 2024 kern.notice kernel: [   49.385893] 7981@C08L3,UpdateBeaconHandler() 1936: 	Band1 BcnInitedRnd = 279
Tue Jan 30 15:45:03 2024 kern.notice kernel: [   49.429401] 7981@C23L3,scan_partial_trigger_checker() 1615: (rax0) NumOfChannels = 5, LastScanChannel = 144, bScanning = 1, BreakTime = 0[0]
Tue Jan 30 15:45:03 2024 kern.notice kernel: [   49.544972] 7981@C23L3,scan_partial_trigger_checker() 1615: (rax0) NumOfChannels = 5, LastScanChannel = 144, bScanning = 1, BreakTime = 1[0]
Tue Jan 30 15:45:03 2024 kern.notice kernel: [   49.660972] 7981@C23L3,scan_partial_trigger_checker() 1615: (rax0) NumOfChannels = 5, LastScanChannel = 144, bScanning = 1, BreakTime = 2[0]
Tue Jan 30 15:45:03 2024 kern.notice kernel: [   49.673704] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=149, ctrl_ch2=0, cent_ch=149 DBDCIdx=1, ChBand=1, BW=0, TXStream=3, RXStream=3, scan(1)
Tue Jan 30 15:45:03 2024 kern.warn kernel: [   49.686999] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (94:83:c4:3d:d6:72), Reason 0x10
Tue Jan 30 15:45:03 2024 kern.err kernel: [   49.695888] 7981@C03L1,ExtEventBeaconLostHandler() 176:   AP Beacon OFF!!!
Tue Jan 30 15:45:03 2024 kern.notice kernel: [   49.702851] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=149, ctrl_ch2=0, cent_ch=149, RxPath=7, BandIdx=1, ChBand=1, BW=0,TXStream=3, RXStream=7, scan(1)
Tue Jan 30 15:45:03 2024 kern.warn kernel: [   49.703005] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (96:83:c4:3d:d6:72), Reason 0x10
Tue Jan 30 15:45:03 2024 kern.err kernel: [   49.725527] 7981@C03L1,ExtEventBeaconLostHandler() 176:   AP Beacon OFF!!!
Tue Jan 30 15:45:03 2024 kern.notice kernel: [   49.776975] 7981@C23L3,scan_partial_trigger_checker() 1615: (rax0) NumOfChannels = 5, LastScanChannel = 149, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:03 2024 kern.notice kernel: [   49.873469] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=153, ctrl_ch2=0, cent_ch=153 DBDCIdx=1, ChBand=1, BW=0, TXStream=3, RXStream=3, scan(1)
Tue Jan 30 15:45:03 2024 kern.notice kernel: [   49.896963] 7981@C23L3,scan_partial_trigger_checker() 1615: (rax0) NumOfChannels = 5, LastScanChannel = 153, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:03 2024 kern.notice kernel: [   49.909583] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=153, ctrl_ch2=0, cent_ch=153, RxPath=7, BandIdx=1, ChBand=1, BW=0,TXStream=3, RXStream=7, scan(1)
Tue Jan 30 15:45:03 2024 kern.notice kernel: [   50.012986] 7981@C23L3,scan_partial_trigger_checker() 1615: (rax0) NumOfChannels = 5, LastScanChannel = 153, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:03 2024 kern.notice kernel: [   50.065466] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=157, ctrl_ch2=0, cent_ch=157 DBDCIdx=1, ChBand=1, BW=0, TXStream=3, RXStream=3, scan(1)
Tue Jan 30 15:45:03 2024 kern.notice kernel: [   50.091822] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=157, ctrl_ch2=0, cent_ch=157, RxPath=7, BandIdx=1, ChBand=1, BW=0,TXStream=3, RXStream=7, scan(1)
Tue Jan 30 15:45:03 2024 kern.notice kernel: [   50.128972] 7981@C23L3,scan_partial_trigger_checker() 1615: (rax0) NumOfChannels = 5, LastScanChannel = 157, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:03 2024 kern.notice kernel: [   50.244968] 7981@C23L3,scan_partial_trigger_checker() 1615: (rax0) NumOfChannels = 5, LastScanChannel = 157, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:03 2024 kern.notice kernel: [   50.258137] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=161, ctrl_ch2=0, cent_ch=161 DBDCIdx=1, ChBand=1, BW=0, TXStream=3, RXStream=3, scan(1)
Tue Jan 30 15:45:04 2024 kern.notice kernel: [   50.284442] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=161, ctrl_ch2=0, cent_ch=161, RxPath=7, BandIdx=1, ChBand=1, BW=0,TXStream=3, RXStream=7, scan(1)
Tue Jan 30 15:45:04 2024 kern.notice kernel: [   50.360966] 7981@C23L3,scan_partial_trigger_checker() 1615: (rax0) NumOfChannels = 5, LastScanChannel = 161, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:04 2024 kern.notice kernel: [   50.441464] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=165, ctrl_ch2=0, cent_ch=165 DBDCIdx=1, ChBand=1, BW=0, TXStream=3, RXStream=3, scan(1)
Tue Jan 30 15:45:04 2024 kern.notice kernel: [   50.467780] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=165, ctrl_ch2=0, cent_ch=165, RxPath=7, BandIdx=1, ChBand=1, BW=0,TXStream=3, RXStream=7, scan(1)
Tue Jan 30 15:45:04 2024 kern.notice kernel: [   50.481600] 7981@C23L3,scan_partial_trigger_checker() 1615: (rax0) NumOfChannels = 5, LastScanChannel = 165, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:04 2024 kern.notice kernel: [   50.585258] 7981@C23L3,scan_partial_trigger_checker() 1615: (rax0) NumOfChannels = 5, LastScanChannel = 165, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:04 2024 kern.notice kernel: [   50.637405] 7981@C23L3,operate_loader_phy() 394: oper_cfg: prim_ch(149), ht_bw(1), extcha(1), vht_bw(1), cen_ch_2(0), PhyMode=177!
Tue Jan 30 15:45:04 2024 kern.notice kernel: [   50.649144] 7981@C23L3,operate_loader_phy() 408: oper_dev after adjust: bw(2), prim_ch(149), cen_ch_1(155), cen_ch_2(0),ext_cha(1)!
Tue Jan 30 15:45:04 2024 kern.notice kernel: [   50.660971] 7981@C23L3,operate_loader_phy() 428: oper_radio after decision: bw(2), prim_ch(149), cen_ch_1(155), cen_ch_2(0)!
Tue Jan 30 15:45:04 2024 kern.notice kernel: [   50.672238] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=149, ctrl_ch2=0, cent_ch=155 DBDCIdx=1, ChBand=1, BW=2, TXStream=3, RXStream=3, scan(0)
Tue Jan 30 15:45:04 2024 kern.notice kernel: [   50.700963] 7981@C23L3,scan_partial_trigger_checker() 1615: (rax0) NumOfChannels = 5, LastScanChannel = 165, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:04 2024 kern.notice kernel: [   50.816957] 7981@C23L3,scan_partial_trigger_checker() 1615: (rax0) NumOfChannels = 5, LastScanChannel = 165, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:04 2024 kern.notice kernel: [   50.883642] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=149, ctrl_ch2=0, cent_ch=155, RxPath=7, BandIdx=1, ChBand=1, BW=2,TXStream=3, RXStream=7, scan(0)
Tue Jan 30 15:45:04 2024 kern.err kernel: [   50.898159] 7981@C12L1,EDCCAInit() 21006: EDCCA compensation: uni_compensation=0, bw_compensation=0, final compensation=0
Tue Jan 30 15:45:04 2024 kern.notice kernel: [   50.909329] 7981@C23L3,scan_ch_restore() 252: End of SCAN(TYPE: 8, BandIdx: 1), restore to BW(2) channel 155, Total BSS[114]
Tue Jan 30 15:45:04 2024 kern.notice kernel: [   50.920649] 7981@C08L3,UpdateBeaconHandler() 1931: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Tue Jan 30 15:45:04 2024 kern.notice kernel: [   50.929024] 7981@C08L3,UpdateBeaconHandler() 1936: 	Band1 BcnInitedRnd = 292
Tue Jan 30 15:45:04 2024 kern.notice kernel: [   50.933000] 7981@C23L3,scan_partial_trigger_checker() 1615: (rax0) NumOfChannels = 5, LastScanChannel = 165, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:04 2024 kern.notice kernel: [   50.936096] 7981@C08L3,UpdateBeaconHandler() 1931: BCN_UPDATE_ENABLE_TX, OmacIdx = 11 (rax1)
Tue Jan 30 15:45:04 2024 kern.notice kernel: [   50.957291] 7981@C08L3,UpdateBeaconHandler() 1936: 	Band1 BcnInitedRnd = 293
Tue Jan 30 15:45:04 2024 kern.notice kernel: [   50.964508] 7981@C23L3,cntl_scan_conf() 624: reset scan fsm, current status is 0x0
Tue Jan 30 15:45:04 2024 kern.notice kernel: [   50.972135] 7981@C08L3,UpdateBeaconHandler() 1931: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Tue Jan 30 15:45:04 2024 kern.notice kernel: [   50.980594] 7981@C08L3,UpdateBeaconHandler() 1936: 	Band1 BcnInitedRnd = 293
Tue Jan 30 15:45:04 2024 kern.notice kernel: [   50.987721] 7981@C08L3,UpdateBeaconHandler() 1931: BCN_UPDATE_ENABLE_TX, OmacIdx = 11 (rax1)
Tue Jan 30 15:45:04 2024 kern.notice kernel: [   50.996239] 7981@C08L3,UpdateBeaconHandler() 1936: 	Band1 BcnInitedRnd = 293
Tue Jan 30 15:45:04 2024 kern.debug kernel: [   51.003336] SCAN DONE, Reset FSM/CNTL IDLE.
Tue Jan 30 15:45:04 2024 kern.notice kernel: [   51.007583] 7981@C23L3,ReleaseChannelOpCharge() 1308: the ChOpCharge of owner=2 is released now!!
Tue Jan 30 15:45:04 2024 kern.notice kernel: [   51.007583]  7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(2), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=1]64:49:7d:d2:5f:19
Tue Jan 30 15:45:04 2024 kern.notice kernel: [   51.038487] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647:  Recv Assoc from STA - 64:49:7d:d2:5f:19
Tue Jan 30 15:45:04 2024 kern.notice kernel: [   51.047850] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ReASSOC Send ReASSOC response (Status=0)...
Tue Jan 30 15:45:04 2024 kern.notice kernel: [   51.057444] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 2
Tue Jan 30 15:45:04 2024 kern.notice kernel: [   51.063692] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=2
Tue Jan 30 15:45:04 2024 daemon.err usbmuxd[7858]: [15:45:04.819][3] usbmuxd v1.1.1 starting up
Tue Jan 30 15:45:04 2024 daemon.err usbmuxd[7858]: [15:45:04.819][3] Using libusb 1.0.24
Tue Jan 30 15:45:04 2024 daemon.err usbmuxd[7858]: [15:45:04.820][3] Initialization complete
Tue Jan 30 15:45:04 2024 daemon.err usbmuxd[7858]: [15:45:04.820][3] Enabled exit on SIGUSR1 if no devices are attached. Start a new instance with "--exit" to trigger.
Tue Jan 30 15:45:04 2024 kern.notice kernel: [   51.173694] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Tue Jan 30 15:45:04 2024 kern.notice kernel: [   51.180364] 7981@C15L3,PeerPairMsg2Action() 6202: ===>Receive msg 2
Tue Jan 30 15:45:04 2024 kern.notice kernel: [   51.187166] 7981@C15L3,WPABuildPairMsg3() 5557: <=== send Msg3 of 4-way
Tue Jan 30 15:45:04 2024 kern.notice kernel: [   51.193905] 7981@C15L3,PeerPairMsg4Action() 6632: ===>Receive msg 4
Tue Jan 30 15:45:04 2024 daemon.info dnsmasq-dhcp[5902]: DHCPREQUEST(br-lan) 192.168.8.206 64:49:7d:d2:5f:19
Tue Jan 30 15:45:04 2024 daemon.info dnsmasq-dhcp[5902]: DHCPACK(br-lan) 192.168.8.206 64:49:7d:d2:5f:19 USPRO-L-TB
Tue Jan 30 15:45:04 2024 kern.warn kernel: [   51.205650] 7981@C15L2,PeerPairMsg4Action() 6994: AP SETKEYS DONE(rax0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=1 from 64:49:7d:d2:5f:19
Tue Jan 30 15:45:05 2024 kern.debug kernel: [   51.684968] BcnCheck start after 4300 ms (ra0)
Tue Jan 30 15:45:06 2024 daemon.info dnsmasq-dhcp[5902]: DHCPREQUEST(br-lan) 192.168.8.206 64:49:7d:d2:5f:19
Tue Jan 30 15:45:06 2024 daemon.info dnsmasq-dhcp[5902]: DHCPACK(br-lan) 192.168.8.206 64:49:7d:d2:5f:19 USPRO-L-TB
Tue Jan 30 15:45:06 2024 daemon.err usbmuxd[7858]: [15:45:06.675][3] Caught signal 15, exiting
Tue Jan 30 15:45:06 2024 daemon.err usbmuxd[7858]: [15:45:06.675][3] usbmuxd shutting down
Tue Jan 30 15:45:06 2024 daemon.err usbmuxd[7858]: [15:45:06.775][3] Shutdown complete
Tue Jan 30 15:45:06 2024 daemon.info lua: (...arch64_cortex-a53/gl-sdk4-repeater/usr/sbin/repeater:1694) rax0: found 89 networks
Tue Jan 30 15:45:06 2024 daemon.info lua: (...arch64_cortex-a53/gl-sdk4-repeater/usr/sbin/repeater:1656) ra0: scan...
Tue Jan 30 15:45:06 2024 kern.info kernel: [   53.112326] Set ScanSSID =
Tue Jan 30 15:45:06 2024 kern.debug kernel: [   53.115292] Number of channels to scan = 5
Tue Jan 30 15:45:06 2024 kern.notice kernel: [   53.119716] 7981@C23L3,TakeChannelOpCharge() 1109: caller:Set_PartialScan_Proc+0x24c/0x338 [mt_wifi]. TakeCharge succeed!
Tue Jan 30 15:45:06 2024 kern.notice kernel: [   53.119716]  bScanning = 1
Tue Jan 30 15:45:06 2024 kern.notice kernel: [   53.144969] 7981@C23L3,scan_partial_trigger_checker() 1615: (ra0) NumOfChannels = 5, LastScanChannel = 0, bScanning = 1, BreakTime = 0[0]
Tue Jan 30 15:45:06 2024 kern.notice kernel: [   53.260985] 7981@C23L3,scan_partial_trigger_checker() 1615: (ra0) NumOfChannels = 5, LastScanChannel = 0, bScanning = 1, BreakTime = 1[0]
Tue Jan 30 15:45:07 2024 kern.notice kernel: [   53.376973] 7981@C23L3,scan_partial_trigger_checker() 1615: (ra0) NumOfChannels = 5, LastScanChannel = 0, bScanning = 1, BreakTime = 2[0]
Tue Jan 30 15:45:07 2024 kern.notice kernel: [   53.389312] 7981@C23L3,scan_partial_trigger_checker() 1641: Reset BssTable for partial scan
Tue Jan 30 15:45:07 2024 kern.notice kernel: [   53.398061] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=1, ctrl_ch2=0, cent_ch=1 DBDCIdx=0, ChBand=0, BW=0, TXStream=2, RXStream=2, scan(1)
Tue Jan 30 15:45:07 2024 kern.notice kernel: [   53.421504] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=1, ctrl_ch2=0, cent_ch=1, RxPath=3, BandIdx=0, ChBand=0, BW=0,TXStream=2, RXStream=3, scan(1)
Tue Jan 30 15:45:07 2024 kern.warn kernel: [   53.435020] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (94:83:c4:3d:d6:71), Reason 0x10
Tue Jan 30 15:45:07 2024 kern.err kernel: [   53.435026] 7981@C03L1,ExtEventBeaconLostHandler() 176:   AP Beacon OFF!!!
Tue Jan 30 15:45:07 2024 kern.notice kernel: [   53.492983] 7981@C23L3,scan_partial_trigger_checker() 1615: (ra0) NumOfChannels = 5, LastScanChannel = 1, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:07 2024 kern.notice kernel: [   53.593490] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=2, ctrl_ch2=0, cent_ch=2 DBDCIdx=0, ChBand=0, BW=0, TXStream=2, RXStream=2, scan(1)
Tue Jan 30 15:45:07 2024 kern.notice kernel: [   53.608962] 7981@C23L3,scan_partial_trigger_checker() 1615: (ra0) NumOfChannels = 5, LastScanChannel = 2, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:07 2024 kern.notice kernel: [   53.616111] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=2, ctrl_ch2=0, cent_ch=2, RxPath=3, BandIdx=0, ChBand=0, BW=0,TXStream=2, RXStream=3, scan(1)
Tue Jan 30 15:45:07 2024 kern.notice kernel: [   53.724967] 7981@C23L3,scan_partial_trigger_checker() 1615: (ra0) NumOfChannels = 5, LastScanChannel = 2, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:07 2024 kern.notice kernel: [   53.777480] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=3, ctrl_ch2=0, cent_ch=3 DBDCIdx=0, ChBand=0, BW=0, TXStream=2, RXStream=2, scan(1)
Tue Jan 30 15:45:07 2024 kern.notice kernel: [   53.800074] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=3, ctrl_ch2=0, cent_ch=3, RxPath=3, BandIdx=0, ChBand=0, BW=0,TXStream=2, RXStream=3, scan(1)
Tue Jan 30 15:45:07 2024 kern.notice kernel: [   53.837262] 7981@C23L3,scan_partial_trigger_checker() 1615: (ra0) NumOfChannels = 5, LastScanChannel = 3, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:07 2024 kern.notice kernel: [   53.952972] 7981@C23L3,scan_partial_trigger_checker() 1615: (ra0) NumOfChannels = 5, LastScanChannel = 3, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:07 2024 kern.notice kernel: [   53.965842] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=4, ctrl_ch2=0, cent_ch=4 DBDCIdx=0, ChBand=0, BW=0, TXStream=2, RXStream=2, scan(1)
Tue Jan 30 15:45:07 2024 kern.notice kernel: [   53.988441] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=4, ctrl_ch2=0, cent_ch=4, RxPath=3, BandIdx=0, ChBand=0, BW=0,TXStream=2, RXStream=3, scan(1)
Tue Jan 30 15:45:07 2024 kern.notice kernel: [   54.069036] 7981@C23L3,scan_partial_trigger_checker() 1615: (ra0) NumOfChannels = 5, LastScanChannel = 4, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:07 2024 kern.notice kernel: [   54.145491] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=5, ctrl_ch2=0, cent_ch=5 DBDCIdx=0, ChBand=0, BW=0, TXStream=2, RXStream=2, scan(1)
Tue Jan 30 15:45:07 2024 kern.notice kernel: [   54.168151] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=5, ctrl_ch2=0, cent_ch=5, RxPath=3, BandIdx=0, ChBand=0, BW=0,TXStream=2, RXStream=3, scan(1)
Tue Jan 30 15:45:07 2024 kern.notice kernel: [   54.184971] 7981@C23L3,scan_partial_trigger_checker() 1615: (ra0) NumOfChannels = 5, LastScanChannel = 5, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:08 2024 kern.notice kernel: [   54.300970] 7981@C23L3,scan_partial_trigger_checker() 1615: (ra0) NumOfChannels = 5, LastScanChannel = 5, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:08 2024 kern.notice kernel: [   54.325429] 7981@C23L3,operate_loader_phy() 394: oper_cfg: prim_ch(2), ht_bw(0), extcha(0), vht_bw(0), cen_ch_2(0), PhyMode=78!
Tue Jan 30 15:45:08 2024 kern.notice kernel: [   54.336926] 7981@C23L3,operate_loader_phy() 408: oper_dev after adjust: bw(0), prim_ch(2), cen_ch_1(2), cen_ch_2(0),ext_cha(0)!
Tue Jan 30 15:45:08 2024 kern.notice kernel: [   54.348424] 7981@C23L3,operate_loader_phy() 428: oper_radio after decision: bw(0), prim_ch(2), cen_ch_1(2), cen_ch_2(0)!
Tue Jan 30 15:45:08 2024 kern.notice kernel: [   54.359396] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=2, ctrl_ch2=0, cent_ch=2 DBDCIdx=0, ChBand=0, BW=0, TXStream=2, RXStream=2, scan(0)
Tue Jan 30 15:45:08 2024 kern.debug kernel: [   54.416962] BcnCheck start after 1800 ms (ra0)
Tue Jan 30 15:45:08 2024 kern.notice kernel: [   54.421418] 7981@C23L3,scan_partial_trigger_checker() 1615: (ra0) NumOfChannels = 5, LastScanChannel = 5, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:08 2024 kern.notice kernel: [   54.490412] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=2, ctrl_ch2=0, cent_ch=2, RxPath=3, BandIdx=0, ChBand=0, BW=0,TXStream=2, RXStream=3, scan(0)
Tue Jan 30 15:45:08 2024 kern.err kernel: [   54.505226] 7981@C12L1,EDCCAInit() 21006: EDCCA compensation: uni_compensation=0, bw_compensation=0, final compensation=0
Tue Jan 30 15:45:08 2024 kern.notice kernel: [   54.516455] 7981@C23L3,scan_ch_restore() 252: End of SCAN(TYPE: 8, BandIdx: 0), restore to BW(0) channel 2, Total BSS[22]
Tue Jan 30 15:45:08 2024 kern.notice kernel: [   54.527424] 7981@C08L3,UpdateBeaconHandler() 1931: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (ra0)
Tue Jan 30 15:45:08 2024 kern.notice kernel: [   54.535683] 7981@C08L3,UpdateBeaconHandler() 1936: 	Band0 BcnInitedRnd = 325
Tue Jan 30 15:45:08 2024 kern.notice kernel: [   54.544974] 7981@C23L3,scan_partial_trigger_checker() 1615: (ra0) NumOfChannels = 5, LastScanChannel = 5, bScanning = 1, BreakTime = 0[0]
Tue Jan 30 15:45:08 2024 kern.notice kernel: [   54.660969] 7981@C23L3,scan_partial_trigger_checker() 1615: (ra0) NumOfChannels = 5, LastScanChannel = 5, bScanning = 1, BreakTime = 1[0]
Tue Jan 30 15:45:08 2024 kern.notice kernel: [   54.768966] 7981@C23L3,scan_partial_trigger_checker() 1615: (ra0) NumOfChannels = 5, LastScanChannel = 5, bScanning = 1, BreakTime = 2[0]
Tue Jan 30 15:45:08 2024 kern.notice kernel: [   54.781483] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=6, ctrl_ch2=0, cent_ch=6 DBDCIdx=0, ChBand=0, BW=0, TXStream=2, RXStream=2, scan(1)
Tue Jan 30 15:45:08 2024 kern.warn kernel: [   54.782552] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (94:83:c4:3d:d6:71), Reason 0x10
Tue Jan 30 15:45:08 2024 kern.err kernel: [   54.803125] 7981@C03L1,ExtEventBeaconLostHandler() 176:   AP Beacon OFF!!!
Tue Jan 30 15:45:08 2024 kern.notice kernel: [   54.810044] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=6, ctrl_ch2=0, cent_ch=6, RxPath=3, BandIdx=0, ChBand=0, BW=0,TXStream=2, RXStream=3, scan(1)
Tue Jan 30 15:45:08 2024 kern.notice kernel: [   54.884971] 7981@C23L3,scan_partial_trigger_checker() 1615: (ra0) NumOfChannels = 5, LastScanChannel = 6, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:08 2024 kern.notice kernel: [   54.965469] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=7, ctrl_ch2=0, cent_ch=7 DBDCIdx=0, ChBand=0, BW=0, TXStream=2, RXStream=2, scan(1)
Tue Jan 30 15:45:08 2024 kern.notice kernel: [   54.988062] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=7, ctrl_ch2=0, cent_ch=7, RxPath=3, BandIdx=0, ChBand=0, BW=0,TXStream=2, RXStream=3, scan(1)
Tue Jan 30 15:45:08 2024 kern.notice kernel: [   55.001823] 7981@C23L3,scan_partial_trigger_checker() 1615: (ra0) NumOfChannels = 5, LastScanChannel = 7, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:08 2024 kern.notice kernel: [   55.104972] 7981@C23L3,scan_partial_trigger_checker() 1615: (ra0) NumOfChannels = 5, LastScanChannel = 7, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:08 2024 kern.notice kernel: [   55.157477] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=8, ctrl_ch2=0, cent_ch=8 DBDCIdx=0, ChBand=0, BW=0, TXStream=2, RXStream=2, scan(1)
Tue Jan 30 15:45:08 2024 kern.notice kernel: [   55.180060] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=8, ctrl_ch2=0, cent_ch=8, RxPath=3, BandIdx=0, ChBand=0, BW=0,TXStream=2, RXStream=3, scan(1)
Tue Jan 30 15:45:08 2024 kern.notice kernel: [   55.220968] 7981@C23L3,scan_partial_trigger_checker() 1615: (ra0) NumOfChannels = 5, LastScanChannel = 8, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:09 2024 kern.notice kernel: [   55.336971] 7981@C23L3,scan_partial_trigger_checker() 1615: (ra0) NumOfChannels = 5, LastScanChannel = 8, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:09 2024 kern.notice kernel: [   55.349994] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=9, ctrl_ch2=0, cent_ch=9 DBDCIdx=0, ChBand=0, BW=0, TXStream=2, RXStream=2, scan(1)
Tue Jan 30 15:45:09 2024 kern.notice kernel: [   55.372590] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=9, ctrl_ch2=0, cent_ch=9, RxPath=3, BandIdx=0, ChBand=0, BW=0,TXStream=2, RXStream=3, scan(1)
Tue Jan 30 15:45:09 2024 kern.notice kernel: [   55.452965] 7981@C23L3,scan_partial_trigger_checker() 1615: (ra0) NumOfChannels = 5, LastScanChannel = 9, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:09 2024 kern.notice kernel: [   55.529479] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=10, ctrl_ch2=0, cent_ch=10 DBDCIdx=0, ChBand=0, BW=0, TXStream=2, RXStream=2, scan(1)
Tue Jan 30 15:45:09 2024 kern.notice kernel: [   55.552247] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=10, ctrl_ch2=0, cent_ch=10, RxPath=3, BandIdx=0, ChBand=0, BW=0,TXStream=2, RXStream=3, scan(1)
Tue Jan 30 15:45:09 2024 kern.notice kernel: [   55.568983] 7981@C23L3,scan_partial_trigger_checker() 1615: (ra0) NumOfChannels = 5, LastScanChannel = 10, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:09 2024 kern.notice kernel: [   55.685032] 7981@C23L3,scan_partial_trigger_checker() 1615: (ra0) NumOfChannels = 5, LastScanChannel = 10, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:09 2024 kern.notice kernel: [   55.709415] 7981@C23L3,operate_loader_phy() 394: oper_cfg: prim_ch(2), ht_bw(0), extcha(0), vht_bw(0), cen_ch_2(0), PhyMode=78!
Tue Jan 30 15:45:09 2024 kern.notice kernel: [   55.720891] 7981@C23L3,operate_loader_phy() 408: oper_dev after adjust: bw(0), prim_ch(2), cen_ch_1(2), cen_ch_2(0),ext_cha(0)!
Tue Jan 30 15:45:09 2024 kern.notice kernel: [   55.732376] 7981@C23L3,operate_loader_phy() 428: oper_radio after decision: bw(0), prim_ch(2), cen_ch_1(2), cen_ch_2(0)!
Tue Jan 30 15:45:09 2024 kern.notice kernel: [   55.743298] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=2, ctrl_ch2=0, cent_ch=2 DBDCIdx=0, ChBand=0, BW=0, TXStream=2, RXStream=2, scan(0)
Tue Jan 30 15:45:09 2024 kern.notice kernel: [   55.800964] 7981@C23L3,scan_partial_trigger_checker() 1615: (ra0) NumOfChannels = 5, LastScanChannel = 10, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:09 2024 kern.notice kernel: [   55.875092] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=2, ctrl_ch2=0, cent_ch=2, RxPath=3, BandIdx=0, ChBand=0, BW=0,TXStream=2, RXStream=3, scan(0)
Tue Jan 30 15:45:09 2024 kern.err kernel: [   55.888964] 7981@C12L1,EDCCAInit() 21006: EDCCA compensation: uni_compensation=0, bw_compensation=0, final compensation=0
Tue Jan 30 15:45:09 2024 kern.notice kernel: [   55.899938] 7981@C23L3,scan_ch_restore() 252: End of SCAN(TYPE: 8, BandIdx: 0), restore to BW(0) channel 2, Total BSS[40]
Tue Jan 30 15:45:09 2024 kern.notice kernel: [   55.910897] 7981@C08L3,UpdateBeaconHandler() 1931: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (ra0)
Tue Jan 30 15:45:09 2024 kern.notice kernel: [   55.919155] 7981@C08L3,UpdateBeaconHandler() 1936: 	Band0 BcnInitedRnd = 337
Tue Jan 30 15:45:09 2024 kern.notice kernel: [   55.926366] 7981@C23L3,scan_partial_trigger_checker() 1615: (ra0) NumOfChannels = 5, LastScanChannel = 10, bScanning = 1, BreakTime = 0[0]
Tue Jan 30 15:45:09 2024 kern.notice kernel: [   56.040974] 7981@C23L3,scan_partial_trigger_checker() 1615: (ra0) NumOfChannels = 5, LastScanChannel = 10, bScanning = 1, BreakTime = 1[0]
Tue Jan 30 15:45:09 2024 kern.notice kernel: [   56.157263] 7981@C23L3,scan_partial_trigger_checker() 1615: (ra0) NumOfChannels = 5, LastScanChannel = 10, bScanning = 1, BreakTime = 2[0]
Tue Jan 30 15:45:09 2024 kern.notice kernel: [   56.169835] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=11, ctrl_ch2=0, cent_ch=11 DBDCIdx=0, ChBand=0, BW=0, TXStream=2, RXStream=2, scan(1)
Tue Jan 30 15:45:09 2024 kern.warn kernel: [   56.170905] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (94:83:c4:3d:d6:71), Reason 0x10
Tue Jan 30 15:45:09 2024 kern.err kernel: [   56.191656] 7981@C03L1,ExtEventBeaconLostHandler() 176:   AP Beacon OFF!!!
Tue Jan 30 15:45:09 2024 kern.notice kernel: [   56.198599] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=11, ctrl_ch2=0, cent_ch=11, RxPath=3, BandIdx=0, ChBand=0, BW=0,TXStream=2, RXStream=3, scan(1)
Tue Jan 30 15:45:09 2024 kern.notice kernel: [   56.272972] 7981@C23L3,scan_partial_trigger_checker() 1615: (ra0) NumOfChannels = 5, LastScanChannel = 11, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:10 2024 kern.notice kernel: [   56.353422] 7981@C23L3,operate_loader_phy() 394: oper_cfg: prim_ch(2), ht_bw(0), extcha(0), vht_bw(0), cen_ch_2(0), PhyMode=78!
Tue Jan 30 15:45:10 2024 kern.notice kernel: [   56.364962] 7981@C23L3,operate_loader_phy() 408: oper_dev after adjust: bw(0), prim_ch(2), cen_ch_1(2), cen_ch_2(0),ext_cha(0)!
Tue Jan 30 15:45:10 2024 kern.notice kernel: [   56.376472] 7981@C23L3,operate_loader_phy() 428: oper_radio after decision: bw(0), prim_ch(2), cen_ch_1(2), cen_ch_2(0)!
Tue Jan 30 15:45:10 2024 kern.notice kernel: [   56.376963] 7981@C23L3,scan_partial_trigger_checker() 1615: (ra0) NumOfChannels = 5, LastScanChannel = 11, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:10 2024 kern.notice kernel: [   56.387468] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=2, ctrl_ch2=0, cent_ch=2 DBDCIdx=0, ChBand=0, BW=0, TXStream=2, RXStream=2, scan(0)
Tue Jan 30 15:45:10 2024 kern.notice kernel: [   56.501000] 7981@C23L3,scan_partial_trigger_checker() 1615: (ra0) NumOfChannels = 5, LastScanChannel = 11, bScanning = 1, BreakTime = 0[1]
Tue Jan 30 15:45:10 2024 kern.notice kernel: [   56.531649] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=2, ctrl_ch2=0, cent_ch=2, RxPath=3, BandIdx=0, ChBand=0, BW=0,TXStream=2, RXStream=3, scan(0)
Tue Jan 30 15:45:10 2024 kern.err kernel: [   56.545578] 7981@C12L1,EDCCAInit() 21006: EDCCA compensation: uni_compensation=0, bw_compensation=0, final compensation=0
Tue Jan 30 15:45:10 2024 kern.notice kernel: [   56.556598] 7981@C23L3,scan_ch_restore() 252: End of SCAN(TYPE: 8, BandIdx: 0), restore to BW(0) channel 2, Total BSS[53]
Tue Jan 30 15:45:10 2024 kern.notice kernel: [   56.567566] 7981@C08L3,UpdateBeaconHandler() 1931: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (ra0)
Tue Jan 30 15:45:10 2024 kern.notice kernel: [   56.575825] 7981@C08L3,UpdateBeaconHandler() 1936: 	Band0 BcnInitedRnd = 343
Tue Jan 30 15:45:10 2024 kern.notice kernel: [   56.582900] 7981@C23L3,cntl_scan_conf() 624: reset scan fsm, current status is 0x0
Tue Jan 30 15:45:10 2024 kern.notice kernel: [   56.590468] 7981@C08L3,UpdateBeaconHandler() 1931: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (ra0)
Tue Jan 30 15:45:10 2024 kern.notice kernel: [   56.598725] 7981@C08L3,UpdateBeaconHandler() 1936: 	Band0 BcnInitedRnd = 343
Tue Jan 30 15:45:10 2024 kern.debug kernel: [   56.605771] SCAN DONE, Reset FSM/CNTL IDLE.
Tue Jan 30 15:45:10 2024 kern.notice kernel: [   56.609955] 7981@C23L3,ReleaseChannelOpCharge() 1308: the ChOpCharge of owner=2 is released now!!
Tue Jan 30 15:45:10 2024 kern.debug kernel: [   57.240963] BcnCheck start after 4300 ms (ra0)
Tue Jan 30 15:45:11 2024 daemon.info lua: (...arch64_cortex-a53/gl-sdk4-repeater/usr/sbin/repeater:1694) ra0: found 51 networks
Tue Jan 30 15:45:11 2024 daemon.info lua: (...arch64_cortex-a53/gl-sdk4-repeater/usr/sbin/repeater:1557) scan finished
Tue Jan 30 15:45:13 2024 kern.debug kernel: [   59.852961] BcnCheck start after 1800 ms (ra0)
Tue Jan 30 15:45:13 2024 daemon.info lua: (...arch64_cortex-a53/gl-sdk4-repeater/usr/sbin/repeater:873) Switching...
Tue Jan 30 15:45:13 2024 daemon.info lua: (...arch64_cortex-a53/gl-sdk4-repeater/usr/sbin/repeater:1378) prepare connect 'BPGuest(ee:63:da:75:fa:f0)', OPEN/NONE channel 149
Tue Jan 30 15:45:13 2024 daemon.info lua: (...arch64_cortex-a53/gl-sdk4-repeater/usr/sbin/repeater:1478) connecting 'BPGuest ee:63:da:75:fa:f0'...
Tue Jan 30 15:45:13 2024 daemon.notice netifd: Wireless device 'mt798112' is now down
Tue Jan 30 15:45:13 2024 kern.info kernel: [   60.143328] device rax0 left promiscuous mode
Tue Jan 30 15:45:13 2024 kern.info kernel: [   60.147814] br-lan: port 2(rax0) entered disabled state
Tue Jan 30 15:45:13 2024 kern.info kernel: [   60.169357] device rax1 left promiscuous mode
Tue Jan 30 15:45:13 2024 kern.info kernel: [   60.173790] br-guest: port 1(rax1) entered disabled state
Tue Jan 30 15:45:13 2024 daemon.notice netifd: bridge 'br-guest' link is down
Tue Jan 30 15:45:13 2024 daemon.notice netifd: Interface 'guest' has link connectivity loss
Tue Jan 30 15:45:13 2024 kern.warn kernel: [   60.237042] 7981@C13L2,Set_DisConnectAllSta_Proc() 22426: Send DeAuth (Reason=2) to 64:49:7d:d2:5f:19
Tue Jan 30 15:45:13 2024 kern.warn kernel: [   60.251456] 7981@C01L2,wifi_sys_disconn_act() 1002:  wdev_idx=2
Tue Jan 30 15:45:13 2024 kern.notice kernel: [   60.257724] 7981@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=2
Tue Jan 30 15:45:13 2024 kern.warn kernel: [   60.265253] 7981@C13L2,MacTableDeleteEntry() 1793: Del Sta:64:49:7d:d2:5f:19
Tue Jan 30 15:45:14 2024 kern.info kernel: [   60.349877] br-guest: port 1(rax1) entered blocking state
Tue Jan 30 15:45:14 2024 kern.info kernel: [   60.355310] br-guest: port 1(rax1) entered disabled state
Tue Jan 30 15:45:14 2024 kern.info kernel: [   60.360922] device rax1 entered promiscuous mode
Tue Jan 30 15:45:14 2024 kern.info kernel: [   60.365709] br-guest: port 1(rax1) entered blocking state
Tue Jan 30 15:45:14 2024 kern.info kernel: [   60.371159] br-guest: port 1(rax1) entered forwarding state
Tue Jan 30 15:45:14 2024 daemon.notice netifd: bridge 'br-guest' link is up
Tue Jan 30 15:45:14 2024 daemon.notice netifd: Interface 'guest' has link connectivity
Tue Jan 30 15:45:14 2024 kern.info kernel: [   60.385356] br-lan: port 2(rax0) entered blocking state
Tue Jan 30 15:45:14 2024 kern.info kernel: [   60.390733] br-lan: port 2(rax0) entered disabled state
Tue Jan 30 15:45:14 2024 kern.info kernel: [   60.396220] device rax0 entered promiscuous mode
Tue Jan 30 15:45:14 2024 kern.info kernel: [   60.401022] br-lan: port 2(rax0) entered blocking state
Tue Jan 30 15:45:14 2024 kern.info kernel: [   60.406270] br-lan: port 2(rax0) entered forwarding state
Tue Jan 30 15:45:14 2024 kern.warn kernel: [   60.416494] 7981@C01L2,RTMP_COM_IoctlHandle() 1523: -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_INIT
Tue Jan 30 15:45:14 2024 kern.warn kernel: [   60.424653] 7981@C01L2,RTMP_COM_IoctlHandle() 1500:  -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_UP
Tue Jan 30 15:45:14 2024 kern.notice kernel: [   60.432715] WiFi@C01L3,wifi_sys_open() 856: wdev idx = 5
Tue Jan 30 15:45:14 2024 kern.notice kernel: [   60.438326] 7981@C18L3,BuildChannelList() 484:
Tue Jan 30 15:45:14 2024 kern.notice kernel: [   60.442964] 7981@C23L3,operate_loader_phy() 394: oper_cfg: prim_ch(149), ht_bw(1), extcha(1), vht_bw(1), cen_ch_2(0), PhyMode=177!
Tue Jan 30 15:45:14 2024 kern.notice kernel: [   60.454729] 7981@C23L3,operate_loader_phy() 408: oper_dev after adjust: bw(2), prim_ch(149), cen_ch_1(155), cen_ch_2(0),ext_cha(1)!
Tue Jan 30 15:45:14 2024 kern.notice kernel: [   60.466566] 7981@C23L3,operate_loader_phy() 428: oper_radio after decision: bw(2), prim_ch(149), cen_ch_1(155), cen_ch_2(0)!
Tue Jan 30 15:45:14 2024 kern.notice kernel: [   60.477863] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=149, ctrl_ch2=0, cent_ch=155 DBDCIdx=1, ChBand=1, BW=2, TXStream=3, RXStream=3, scan(0)
Tue Jan 30 15:45:14 2024 kern.notice kernel: [   60.491156] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=149, ctrl_ch2=0, cent_ch=155, RxPath=7, BandIdx=1, ChBand=1, BW=2,TXStream=3, RXStream=7, scan(0)
Tue Jan 30 15:45:14 2024 kern.err kernel: [   60.505098] 7981@C12L1,EDCCAInit() 21006: EDCCA compensation: uni_compensation=0, bw_compensation=0, final compensation=0
Tue Jan 30 15:45:14 2024 kern.warn kernel: [   60.516315] WiFi@C00L2,dump_ht_cap() 29: Caller: wlan_operate_init+0xbc/0x160 [mt_wifi]
Tue Jan 30 15:45:14 2024 kern.debug kernel: [   60.524370] wdev_attr_update(): wdevId5 = 9e:83:c4:3d:d6:71
Tue Jan 30 15:45:14 2024 kern.notice kernel: [   60.529977] 7981@C08L3,hw_ctrl_flow_v2_open() 13: wdev_idx=5
Tue Jan 30 15:45:14 2024 kern.warn kernel: [   60.537097] WiFi@C00L2,dump_ht_cap() 29: Caller: dump_ht_cap+0x10/0x20 [mt_wifi]
Tue Jan 30 15:45:14 2024 kern.info kernel: [   60.544527] mtk_ppe_dev_register_hook : ineterface apclix0 register (4)
Tue Jan 30 15:45:14 2024 kern.err kernel: [   60.553153] 7981@C12L1,Set_ApCliPMFMFPC_Proc() 1998: [PMF]: Security is not WPA2/WPA2PSK AES
Tue Jan 30 15:45:14 2024 kern.err kernel: [   60.561622] 7981@C12L1,Set_ApCliPMFMFPC_Proc() 2003: [PMF]: MFPC=0, MFPR=0, SHA256=0
Tue Jan 30 15:45:14 2024 kern.debug kernel: [   60.569950] SetApCliEnableByWdev: I/F(apcli1) (enable = 1)
Tue Jan 30 15:45:14 2024 daemon.notice netifd: Interface 'wwan' is enabled
Tue Jan 30 15:45:14 2024 kern.warn kernel: [   60.583598] 7981@C08L2,mbss_virtual_if_open() 134:  ===> ra1
Tue Jan 30 15:45:14 2024 kern.warn kernel: [   60.589293] 7981@C01L2,RTMP_COM_IoctlHandle() 1523: -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_INIT
Tue Jan 30 15:45:14 2024 kern.warn kernel: [   60.597418] 7981@C01L2,RTMP_COM_IoctlHandle() 1500:  -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_UP
Tue Jan 30 15:45:14 2024 kern.notice kernel: [   60.605426] WiFi@C01L3,wifi_sys_open() 856: wdev idx = 1
Tue Jan 30 15:45:14 2024 kern.notice kernel: [   60.610995] 7981@C18L3,BuildChannelList() 484:
Tue Jan 30 15:45:14 2024 kern.notice kernel: [   60.615579] 7981@C23L3,operate_loader_phy() 394: oper_cfg: prim_ch(2), ht_bw(0), extcha(0), vht_bw(0), cen_ch_2(0), PhyMode=78!
Tue Jan 30 15:45:14 2024 kern.notice kernel: [   60.627060] 7981@C23L3,operate_loader_phy() 408: oper_dev after adjust: bw(0), prim_ch(2), cen_ch_1(2), cen_ch_2(0),ext_cha(0)!
Tue Jan 30 15:45:14 2024 kern.notice kernel: [   60.638543] 7981@C23L3,operate_loader_phy() 428: oper_radio after decision: bw(0), prim_ch(2), cen_ch_1(2), cen_ch_2(0)!
Tue Jan 30 15:45:14 2024 kern.warn kernel: [   60.649608] WiFi@C00L2,dump_ht_cap() 29: Caller: wlan_operate_init+0xbc/0x160 [mt_wifi]
Tue Jan 30 15:45:14 2024 kern.debug kernel: [   60.657625] wdev_attr_update(): wdevId1 = 96:83:c4:3d:d6:71
Tue Jan 30 15:45:14 2024 kern.err kernel: [   60.663227] WiFi@C12L1,wifi_sys_open() 907: wifi_sys_open():band0 group_idx[1]=9, bw_grp=16 omac=17
Tue Jan 30 15:45:14 2024 kern.notice kernel: [   60.672318] 7981@C08L3,hw_ctrl_flow_v2_open() 13: wdev_idx=1
Tue Jan 30 15:45:14 2024 kern.warn kernel: [   60.678274] 7981@C02L2,AsicRadioOnOffCtrl() 2340: DbdcIdx=0 RadioOn
Tue Jan 30 15:45:14 2024 kern.warn kernel: [   60.684726] 7981@C00L2,ApAutoChannelAtBootUp() 333: ----------------->
Tue Jan 30 15:45:14 2024 kern.err kernel: [   60.691380] 7981@C03L1,MtCmdSetMacTxRx() 10246: (ret = 0)
Tue Jan 30 15:45:14 2024 kern.err kernel: [   60.696893] 7981@C03L1,MtCmdSetMacTxRx() 10246: (ret = 0)
Tue Jan 30 15:45:14 2024 kern.err kernel: [   60.702304] 7981@C00L1,ApAutoChannelAtBootUp() 497: not A band
Tue Jan 30 15:45:14 2024 kern.err kernel: [   60.708136] 7981@C08L1,ap_run_at_boot() 623: e[41m ACS is disable !!e[m
Tue Jan 30 15:45:14 2024 kern.warn kernel: [   60.714957] 7981@C08L2,APStartUpForMbss() 983: ===>(caller:ap_inf_open+0x144/0x4e0 [mt_wifi]), mbss_idx:1, CfgMode:78
Tue Jan 30 15:45:14 2024 kern.warn kernel: [   60.725603] 7981@C15L2,APPMFInit() 121: [PMF] Security is not WPA2/WPA2PSK AES
Tue Jan 30 15:45:14 2024 kern.warn kernel: [   60.732832] 7981@C15L2,APPMFInit() 133: [PMF] apidx=1, MFPC=0, MFPR=0, SHA256=0
Tue Jan 30 15:45:14 2024 kern.notice kernel: [   60.740140] 7981@C18L3,BuildChannelList() 484:
Tue Jan 30 15:45:14 2024 kern.warn kernel: [   60.744889] WiFi@C00L2,dump_ht_cap() 29: Caller: dump_ht_cap+0x10/0x20 [mt_wifi]
Tue Jan 30 15:45:14 2024 kern.warn kernel: [   60.752528] WiFi@C08L2,ap_link_up() 7143: (caller:wdev_do_linkup+0x20/0x38 [mt_wifi]), wdev(1)
Tue Jan 30 15:45:14 2024 kern.notice kernel: [   60.761173] 7981@C01L3,wifi_sys_linkup() 1231: wdev idx = 1
Tue Jan 30 15:45:14 2024 kern.notice kernel: [   60.766959] 7981@C00L3,wtc_acquire_groupkey_wcid() 84:  Found a non-occupied wtbl_idx:284 for WDEV_TYPE:1
Tue Jan 30 15:45:14 2024 kern.notice kernel: [   60.766959]  LinkToOmacIdx = 11, LinkToWdevType = 1
Tue Jan 30 15:45:14 2024 kern.notice kernel: [   60.781476] 7981@C08L3,hw_ctrl_flow_v2_link_up() 72: wdev_idx=1
Tue Jan 30 15:45:14 2024 kern.notice kernel: [   60.791814] 7981@C08L3,UpdateBeaconHandler() 1911: BCN_UPDATE_INIT, OmacIdx = 11 (ra1)
Tue Jan 30 15:45:14 2024 kern.warn kernel: [   60.799731] 7981@C08L2,bcn_buf_init() 170: BcnPkt is allocated!, bcn offload=1
Tue Jan 30 15:45:14 2024 kern.err kernel: [   60.807142] 7981@C00L1,TxCCKStreamCtrl() 20470: set wrong parameters
Tue Jan 30 15:45:14 2024 kern.debug kernel: [   60.824176] PrintSrCmd:
Tue Jan 30 15:45:14 2024 kern.debug kernel: [   60.824176] u1CmdSubId = 1, u1ArgNum = 0, u1DbdcIdx = 0, u1Status = 0
Tue Jan 30 15:45:14 2024 kern.debug kernel: [   60.824176] u1DropTaIdx = 0, u1StaIdx = 0, u4Value = 1
Tue Jan 30 15:45:14 2024 kern.debug kernel: [   60.838220] PrintSrCmd:
Tue Jan 30 15:45:14 2024 kern.debug kernel: [   60.838220] u1CmdSubId = 5, u1ArgNum = 0, u1DbdcIdx = 0, u1Status = 0
Tue Jan 30 15:45:14 2024 kern.debug kernel: [   60.838220] u1DropTaIdx = 0, u1StaIdx = 0, u4Value = 0
Tue Jan 30 15:45:14 2024 kern.debug kernel: [   60.852221] PrintSrCmd:
Tue Jan 30 15:45:14 2024 kern.debug kernel: [   60.852221] u1CmdSubId = 3, u1ArgNum = 0, u1DbdcIdx = 0, u1Status = 0
Tue Jan 30 15:45:14 2024 kern.debug kernel: [   60.852221] u1DropTaIdx = 0, u1StaIdx = 0, u4Value = 1
Tue Jan 30 15:45:14 2024 kern.debug kernel: [   60.866218] PrintSrCmd:
Tue Jan 30 15:45:14 2024 kern.debug kernel: [   60.866218] u1CmdSubId = 23, u1ArgNum = 0, u1DbdcIdx = 0, u1Status = 0
Tue Jan 30 15:45:14 2024 kern.debug kernel: [   60.866218] u1DropTaIdx = 0, u1StaIdx = 0, u4Value = 0
Tue Jan 30 15:45:14 2024 kern.debug kernel: [   60.880331] PrintSrCmd:
Tue Jan 30 15:45:14 2024 kern.debug kernel: [   60.880331] u1CmdSubId = 31, u1ArgNum = 0, u1DbdcIdx = 0, u1Status = 0
Tue Jan 30 15:45:14 2024 kern.debug kernel: [   60.880331] u1DropTaIdx = 0, u1StaIdx = 0, u4Value = 0
Tue Jan 30 15:45:14 2024 kern.debug kernel: [   60.894441] PrintSrCmd:
Tue Jan 30 15:45:14 2024 kern.debug kernel: [   60.894441] u1CmdSubId = 33, u1ArgNum = 0, u1DbdcIdx = 0, u1Status = 0
Tue Jan 30 15:45:14 2024 kern.debug kernel: [   60.894441] u1DropTaIdx = 0, u1StaIdx = 0, u4Value = 0
Tue Jan 30 15:45:14 2024 kern.err kernel: [   60.908597] 7981@C12L1,EDCCAInit() 21006: EDCCA compensation: uni_compensation=0, bw_compensation=0, final compensation=0
Tue Jan 30 15:45:14 2024 kern.notice kernel: [   60.919638] 7981@C03L3,MtCmdTxPwrShowInfo() 13746: ucTxPowerInfoCatg: 2, BandIdx: 0
Tue Jan 30 15:45:14 2024 kern.notice kernel: [   60.927472] 7981@C03L3,MtCmdTxPwrShowInfo() 13775: (ret = 0)
Tue Jan 30 15:45:14 2024 kern.debug kernel: [   60.933170] [mtf_txpower_all_rate_info] band_idx:0 pwr:37 ChBand:2G ePAGain:0
Tue Jan 30 15:45:14 2024 kern.info kernel: [   60.940384] extif_set_dev(ra1)
Tue Jan 30 15:45:14 2024 kern.info kernel: [   60.943441] mtk_ppe_dev_register_hook : ineterface ra1 register (5)
Tue Jan 30 15:45:14 2024 kern.warn kernel: [   60.960644] 7981@C08L2,mbss_virtual_if_close() 171:  ===> ra1
Tue Jan 30 15:45:14 2024 kern.warn kernel: [   60.966481] 7981@C01L2,RTMP_COM_IoctlHandle() 1511:  -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_DOWN
Tue Jan 30 15:45:14 2024 kern.warn kernel: [   60.974969] WiFi@C08L2,ap_link_down() 7161: (caller:wdev_do_linkdown+0x20/0x38 [mt_wifi]), wdev(1)
Tue Jan 30 15:45:14 2024 kern.err kernel: [   60.984259] 7981@C08L1,UpdateBeaconHandler() 1891: wdev(1) bss not ready (state:2, caller:ap_link_down+0x84/0x130 [mt_wifi])!!
Tue Jan 30 15:45:14 2024 kern.notice kernel: [   60.995747] 7981@C01L3,wifi_sys_linkdown() 1363: wdev idx = 1
Tue Jan 30 15:45:14 2024 kern.notice kernel: [   61.001788] 7981@C08L3,hw_ctrl_flow_v2_link_down() 123: wdev_idx=1
Tue Jan 30 15:45:14 2024 kern.notice kernel: [   61.008869] WiFi@C01L3,wifi_sys_close() 945: wdev idx = 1
Tue Jan 30 15:45:14 2024 kern.notice kernel: [   61.014561] 7981@C08L3,hw_ctrl_flow_v2_close() 41: wdev_idx=1
Tue Jan 30 15:45:14 2024 kern.warn kernel: [   61.020546] 7981@C01L2,RTMP_COM_IoctlHandle() 1534: -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_DEINIT
Tue Jan 30 15:45:14 2024 kern.info kernel: [   61.028828] extif_put_dev(ra1)
Tue Jan 30 15:45:14 2024 kern.info kernel: [   61.031885] mtk_ppe_dev_unregister_hook : ineterface ra1 set null (5)
Tue Jan 30 15:45:15 2024 daemon.notice netifd: Wireless device 'mt798112' is now up
Tue Jan 30 15:45:15 2024 daemon.notice netifd: Network device 'rax0' link is up
Tue Jan 30 15:45:15 2024 daemon.notice netifd: Network device 'rax1' link is up
Tue Jan 30 15:45:15 2024 kern.warn kernel: [   61.441333] 7981@C09L2,cntl_connect_request() 395: type=2,len=0,caller:ApCliIfUp+0x190/0x348 [mt_wifi]
Tue Jan 30 15:45:15 2024 kern.debug kernel: [   61.450691] PrintSrCmd:
Tue Jan 30 15:45:15 2024 kern.debug kernel: [   61.450691] u1CmdSubId = 3, u1ArgNum = 0, u1DbdcIdx = 1, u1Status = 0
Tue Jan 30 15:45:15 2024 kern.debug kernel: [   61.450691] u1DropTaIdx = 0, u1StaIdx = 0, u4Value = 0
Tue Jan 30 15:45:15 2024 kern.debug kernel: [   61.464742] PrintSrCmd:
Tue Jan 30 15:45:15 2024 kern.debug kernel: [   61.464742] u1CmdSubId = 1, u1ArgNum = 0, u1DbdcIdx = 1, u1Status = 0
Tue Jan 30 15:45:15 2024 kern.debug kernel: [   61.464742] u1DropTaIdx = 0, u1StaIdx = 0, u4Value = 0
Tue Jan 30 15:45:15 2024 kern.debug kernel: [   61.480272] entrytb_aid_aquire(): found non-occupied aid:4, allocated from:4
Tue Jan 30 15:45:15 2024 kern.err kernel: [   61.487364] 7981@C12L1,SetWPAPSKKey() 1637: WPAPSK Key length(0) error, required 8 ~ 64 characters!(keyStr=)
Tue Jan 30 15:45:15 2024 kern.notice kernel: [   61.497230] 7981@C23L3,operate_loader_phy() 394: oper_cfg: prim_ch(149), ht_bw(1), extcha(1), vht_bw(0), cen_ch_2(0), PhyMode=177!
Tue Jan 30 15:45:15 2024 kern.notice kernel: [   61.509017] 7981@C23L3,operate_loader_phy() 408: oper_dev after adjust: bw(1), prim_ch(149), cen_ch_1(151), cen_ch_2(0),ext_cha(1)!
Tue Jan 30 15:45:15 2024 kern.notice kernel: [   61.520869] 7981@C23L3,operate_loader_phy() 428: oper_radio after decision: bw(2), prim_ch(149), cen_ch_1(155), cen_ch_2(0)!
Tue Jan 30 15:45:15 2024 kern.notice kernel: [   61.532200] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=149, ctrl_ch2=0, cent_ch=155 DBDCIdx=1, ChBand=1, BW=2, TXStream=3, RXStream=3, scan(0)
Tue Jan 30 15:45:15 2024 kern.notice kernel: [   61.545745] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=149, ctrl_ch2=0, cent_ch=155, RxPath=7, BandIdx=1, ChBand=1, BW=2,TXStream=3, RXStream=7, scan(0)
Tue Jan 30 15:45:15 2024 kern.err kernel: [   61.559837] 7981@C12L1,EDCCAInit() 21006: EDCCA compensation: uni_compensation=0, bw_compensation=0, final compensation=0
Tue Jan 30 15:45:15 2024 kern.notice kernel: [   61.570990] 7981@C23L3,operate_loader_phy() 394: oper_cfg: prim_ch(149), ht_bw(1), extcha(1), vht_bw(0), cen_ch_2(0), PhyMode=177!
Tue Jan 30 15:45:15 2024 kern.notice kernel: [   61.582844] 7981@C23L3,operate_loader_phy() 408: oper_dev after adjust: bw(1), prim_ch(149), cen_ch_1(151), cen_ch_2(0),ext_cha(1)!
Tue Jan 30 15:45:15 2024 kern.notice kernel: [   61.594752] 7981@C23L3,operate_loader_phy() 428: oper_radio after decision: bw(1), prim_ch(149), cen_ch_1(151), cen_ch_2(0)!
Tue Jan 30 15:45:15 2024 kern.notice kernel: [   61.606070] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=149, ctrl_ch2=0, cent_ch=151 DBDCIdx=1, ChBand=1, BW=1, TXStream=3, RXStream=3, scan(0)
Tue Jan 30 15:45:15 2024 kern.notice kernel: [   61.815005] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=149, ctrl_ch2=0, cent_ch=151, RxPath=7, BandIdx=1, ChBand=1, BW=1,TXStream=3, RXStream=7, scan(0)
Tue Jan 30 15:45:15 2024 kern.err kernel: [   61.829016] 7981@C12L1,EDCCAInit() 21006: EDCCA compensation: uni_compensation=0, bw_compensation=0, final compensation=0
Tue Jan 30 15:45:15 2024 kern.notice kernel: [   61.840250] 7981@C09L3,sta_mlme_auth_req_action() 201: wdev(type=2,wdev_idx=5,wdev_func_idx=1
Tue Jan 30 15:45:15 2024 kern.notice kernel: [   61.848831] 7981@C09L3,sta_send_auth_req() 68: STA Start send Auth req
Tue Jan 30 15:45:15 2024 kern.err kernel: [   61.855361] 7981@C09L1,sta_send_auth_req() 107: AUTH - Send AUTH request seq#1 (Alg=0)...
Tue Jan 30 15:45:15 2024 kern.notice kernel: [   61.867450] 7981@C09L3,sta_mlme_assoc_req_action() 783: ASSOC - Send ASSOC request...
Tue Jan 30 15:45:15 2024 kern.debug kernel: [   61.875315] ======================================> check WPA2PSK :0
Tue Jan 30 15:45:15 2024 kern.warn kernel: [   61.886497] 7981@C09L2,LinkUp() 3064: !!! LINK UP !!! wdev(name=apclix0,type=2,func_idx=1,PortSecured=22)
Tue Jan 30 15:45:15 2024 kern.warn kernel: [   61.896070] 7981@C09L2,LinkUp() 3067: BssType=1, AID=6, ssid=BPGuest, Channel=149, CentralChannel = 151
Tue Jan 30 15:45:15 2024 kern.notice kernel: [   61.905509] 7981@C01L3,wifi_sys_linkup() 1231: wdev idx = 5
Tue Jan 30 15:45:15 2024 kern.notice kernel: [   61.911402] 7981@C00L3,wtc_acquire_groupkey_wcid() 84:  Found a non-occupied wtbl_idx:284 for WDEV_TYPE:2
Tue Jan 30 15:45:15 2024 kern.notice kernel: [   61.911402]  LinkToOmacIdx = 1, LinkToWdevType = 2
Tue Jan 30 15:45:15 2024 kern.notice kernel: [   61.925842] 7981@C08L3,hw_ctrl_flow_v2_link_up() 72: wdev_idx=5
Tue Jan 30 15:45:15 2024 kern.notice kernel: [   61.936186] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 5
Tue Jan 30 15:45:15 2024 kern.notice kernel: [   61.942248] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=5
Tue Jan 30 15:45:15 2024 daemon.notice netifd: Network device 'apclix0' link is up
Tue Jan 30 15:45:15 2024 daemon.notice netifd: Interface 'wwan' has link connectivity
Tue Jan 30 15:45:15 2024 daemon.notice netifd: Interface 'wwan' is setting up now
Tue Jan 30 15:45:15 2024 kern.info kernel: [   61.960424] IPv6: ADDRCONF(NETDEV_CHANGE): apclix0: link becomes ready
Tue Jan 30 15:45:15 2024 kern.debug kernel: [   61.967700] add link apclix0, blk_mc:0, link_tbl_cnt=1
Tue Jan 30 15:45:15 2024 kern.debug kernel: [   61.972898] nf_register_hooks()
Tue Jan 30 15:45:15 2024 kern.debug kernel: [   61.976133] add new: rax0(UP)->apclix0(UP), active path:1
Tue Jan 30 15:45:15 2024 kern.debug kernel: [   61.983165] add new: rax1(UP)->apclix0(UP), active path:2
Tue Jan 30 15:45:15 2024 daemon.notice netifd: wwan (8111): udhcpc: started, v1.33.2
Tue Jan 30 15:45:15 2024 daemon.notice netifd: wwan (8111): udhcpc: sending discover
Tue Jan 30 15:45:15 2024 kern.notice kernel: [   62.062447] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(2), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=1023]64:49:7d:d2:5f:19
Tue Jan 30 15:45:15 2024 kern.debug kernel: [   62.075368] entrytb_aid_aquire(): found non-occupied aid:5, allocated from:4
Tue Jan 30 15:45:15 2024 kern.warn kernel: [   62.082438] 7981@C13L2,MacTableInsertEntry() 1537: New Sta:64:49:7d:d2:5f:19
Tue Jan 30 15:45:15 2024 kern.notice kernel: [   62.091320] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647:  Recv Assoc from STA - 64:49:7d:d2:5f:19
Tue Jan 30 15:45:15 2024 kern.notice kernel: [   62.100616] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ReASSOC Send ReASSOC response (Status=0)...
Tue Jan 30 15:45:15 2024 kern.notice kernel: [   62.110058] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 2
Tue Jan 30 15:45:15 2024 kern.notice kernel: [   62.116084] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=2
Tue Jan 30 15:45:15 2024 kern.notice kernel: [   62.237688] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Tue Jan 30 15:45:15 2024 daemon.notice netifd: wwan (8111): udhcpc: sending select for 192.168.2.212
Tue Jan 30 15:45:16 2024 daemon.notice netifd: wwan (8111): udhcpc: lease of 192.168.2.212 obtained, lease time 86400
Tue Jan 30 15:45:16 2024 daemon.info avahi-daemon[5584]: Joining mDNS multicast group on interface apclix0.IPv4 with address 192.168.2.212.
Tue Jan 30 15:45:16 2024 daemon.info avahi-daemon[5584]: New relevant interface apclix0.IPv4 for mDNS.
Tue Jan 30 15:45:16 2024 daemon.info avahi-daemon[5584]: Registering new address record for 192.168.2.212 on apclix0.IPv4.
Tue Jan 30 15:45:16 2024 daemon.notice netifd: Interface 'wwan' is now up
Tue Jan 30 15:45:16 2024 daemon.info dnsmasq[5902]: reading /tmp/resolv.conf.d/resolv.conf.auto
Tue Jan 30 15:45:16 2024 daemon.info dnsmasq[5902]: using only locally-known addresses for domain test
Tue Jan 30 15:45:16 2024 daemon.info dnsmasq[5902]: using only locally-known addresses for domain onion
Tue Jan 30 15:45:16 2024 daemon.info dnsmasq[5902]: using only locally-known addresses for domain localhost
Tue Jan 30 15:45:16 2024 daemon.info dnsmasq[5902]: using only locally-known addresses for domain invalid
Tue Jan 30 15:45:16 2024 daemon.info dnsmasq[5902]: using only locally-known addresses for domain bind
Tue Jan 30 15:45:16 2024 daemon.info dnsmasq[5902]: using only locally-known addresses for domain lan
Tue Jan 30 15:45:16 2024 daemon.info dnsmasq[5902]: using nameserver 192.168.2.1#53
Tue Jan 30 15:45:16 2024 user.notice firewall: Reloading firewall due to ifup of wwan (apclix0)
Tue Jan 30 15:45:16 2024 user.notice kmwan: config json str={ "op": 2, "data": { "cells": [ { "interface": "wwan", "netdev": "apclix0", "track_mode": "force", "addr_type": 4, "tracks": [ { "type": "ping", "ip": "1.1.1.1" }, { "type": "ping", "ip": "8.8.8.8" }, { "type": "ping", "ip": "208.67.222.222" }, { "type": "ping", "ip": "208.67.220.220" } ] } ] } }
Tue Jan 30 15:45:16 2024 kern.debug kernel: [   62.945154] [add_dev_config 307]add node success. iface:wwan, dev:apclix0, ifindex:13
Tue Jan 30 15:45:16 2024 kern.debug kernel: [   63.126574] Set_ByPassCac_Proc(): set CAC value to 1
Tue Jan 30 15:45:16 2024 kern.notice kernel: [   63.269666] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Tue Jan 30 15:45:17 2024 daemon.info avahi-daemon[5584]: Joining mDNS multicast group on interface apclix0.IPv6 with address fe80::9c83:c4ff:fe3d:d671.
Tue Jan 30 15:45:17 2024 daemon.info avahi-daemon[5584]: New relevant interface apclix0.IPv6 for mDNS.
Tue Jan 30 15:45:17 2024 daemon.info avahi-daemon[5584]: Registering new address record for fe80::9c83:c4ff:fe3d:d671 on apclix0.*.
Tue Jan 30 15:45:17 2024 kern.notice kernel: [   63.428571] 7981@C15L3,PeerPairMsg2Action() 6202: ===>Receive msg 2
Tue Jan 30 15:45:17 2024 kern.notice kernel: [   63.435321] 7981@C15L3,WPABuildPairMsg3() 5557: <=== send Msg3 of 4-way
Tue Jan 30 15:45:17 2024 kern.notice kernel: [   63.452408] 7981@C15L3,PeerPairMsg4Action() 6632: ===>Receive msg 4
Tue Jan 30 15:45:17 2024 kern.warn kernel: [   63.464072] 7981@C15L2,PeerPairMsg4Action() 6994: AP SETKEYS DONE(rax0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=2 from 64:49:7d:d2:5f:19
Tue Jan 30 15:45:17 2024 daemon.info dnsmasq-dhcp[5902]: DHCPREQUEST(br-lan) 192.168.8.206 64:49:7d:d2:5f:19
Tue Jan 30 15:45:17 2024 daemon.info dnsmasq-dhcp[5902]: DHCPACK(br-lan) 192.168.8.206 64:49:7d:d2:5f:19 USPRO-L-TB
Tue Jan 30 15:45:17 2024 user.notice kmwan: config json str={ "op": 1, "data": { } }
Tue Jan 30 15:45:17 2024 kern.debug kernel: [   63.717062] kmwan: All nodes are deleted.
Tue Jan 30 15:45:17 2024 user.notice kmwan: config json str={ "op": 0, "data": { "sensitivity": 3000, "mode": "failover" } }
Tue Jan 30 15:45:17 2024 kern.debug kernel: [   63.731863] kmwan: sensitivity and mode are set.
Tue Jan 30 15:45:17 2024 daemon.info avahi-daemon[5584]: Withdrawing address record for 192.168.2.212 on apclix0.
Tue Jan 30 15:45:17 2024 daemon.info avahi-daemon[5584]: Leaving mDNS multicast group on interface apclix0.IPv4 with address 192.168.2.212.
Tue Jan 30 15:45:17 2024 daemon.info avahi-daemon[5584]: Interface apclix0.IPv4 no longer relevant for mDNS.
Tue Jan 30 15:45:17 2024 daemon.info avahi-daemon[5584]: Joining mDNS multicast group on interface apclix0.IPv4 with address 192.168.2.212.
Tue Jan 30 15:45:17 2024 daemon.info avahi-daemon[5584]: New relevant interface apclix0.IPv4 for mDNS.
Tue Jan 30 15:45:17 2024 daemon.info avahi-daemon[5584]: Registering new address record for 192.168.2.212 on apclix0.IPv4.
Tue Jan 30 15:45:17 2024 user.notice kmwan: config json str={ "op": 2, "data": { "cells": [ { "interface": "wwan", "netdev": "apclix0", "track_mode": "force", "addr_type": 4, "tracks": [ { "type": "ping", "ip": "1.1.1.1" }, { "type": "ping", "ip": "8.8.8.8" }, { "type": "ping", "ip": "208.67.222.222" }, { "type": "ping", "ip": "208.67.220.220" } ] } ] } }
Tue Jan 30 15:45:17 2024 kern.debug kernel: [   63.892328] [add_dev_config 307]add node success. iface:wwan, dev:apclix0, ifindex:13
Tue Jan 30 15:45:18 2024 kern.debug kernel: [   64.480965] BcnCheck start after 2500 ms (ra0)
Tue Jan 30 15:45:18 2024 kern.debug kernel: [   64.485413] BcnCheck start after 2500 ms (ra0)
Tue Jan 30 15:45:19 2024 daemon.info lua: (...arch64_cortex-a53/gl-sdk4-repeater/usr/sbin/repeater:1273) connected to 'BPGuest(EE:63:DA:75:FA:F0)' channel: 149, spent 2s
Tue Jan 30 15:45:20 2024 kern.warn kernel: [   66.496441] 7981@C01L2,wifi_sys_disconn_act() 1002:  wdev_idx=2
Tue Jan 30 15:45:20 2024 kern.notice kernel: [   66.503142] 7981@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=2
Tue Jan 30 15:45:20 2024 kern.warn kernel: [   66.510261] 7981@C13L2,MacTableDeleteEntry() 1793: Del Sta:64:49:7d:d2:5f:19
Tue Jan 30 15:45:20 2024 kern.notice kernel: [   66.517492] 7981@C08L3,ap_peer_deauth_action() 429: AUTH - receive DE-AUTH(seq-39) from 64:49:7d:d2:5f:19, reason=1
Tue Jan 30 15:45:25 2024 kern.notice kernel: [   71.371188] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(2), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=1023]64:49:7d:d2:5f:19
Tue Jan 30 15:45:25 2024 kern.debug kernel: [   71.384126] entrytb_aid_aquire(): found non-occupied aid:5, allocated from:4
Tue Jan 30 15:45:25 2024 kern.warn kernel: [   71.391187] 7981@C13L2,MacTableInsertEntry() 1537: New Sta:64:49:7d:d2:5f:19
Tue Jan 30 15:45:25 2024 kern.notice kernel: [   71.399807] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647:  Recv Assoc from STA - 64:49:7d:d2:5f:19
Tue Jan 30 15:45:25 2024 kern.notice kernel: [   71.409167] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)...
Tue Jan 30 15:45:25 2024 kern.notice kernel: [   71.418321] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 2
Tue Jan 30 15:45:25 2024 kern.notice kernel: [   71.424471] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=2
Tue Jan 30 15:45:25 2024 kern.notice kernel: [   71.545680] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Tue Jan 30 15:45:25 2024 kern.notice kernel: [   71.552536] 7981@C15L3,PeerPairMsg2Action() 6202: ===>Receive msg 2
Tue Jan 30 15:45:25 2024 kern.notice kernel: [   71.559315] 7981@C15L3,WPABuildPairMsg3() 5557: <=== send Msg3 of 4-way
Tue Jan 30 15:45:25 2024 kern.notice kernel: [   71.566032] 7981@C15L3,PeerPairMsg4Action() 6632: ===>Receive msg 4
Tue Jan 30 15:45:25 2024 kern.warn kernel: [   71.577846] 7981@C15L2,PeerPairMsg4Action() 6994: AP SETKEYS DONE(rax0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=2 from 64:49:7d:d2:5f:19
Tue Jan 30 15:45:25 2024 daemon.info dnsmasq-dhcp[5902]: DHCPREQUEST(br-lan) 192.168.8.206 64:49:7d:d2:5f:19
Tue Jan 30 15:45:25 2024 daemon.info dnsmasq-dhcp[5902]: DHCPACK(br-lan) 192.168.8.206 64:49:7d:d2:5f:19 USPRO-L-TB
Wed Jan 31 12:49:55 2024 cron.err crond[5386]: time disparity of 1264 minutes detected
Wed Jan 31 12:49:56 2024 daemon.notice netifd: Network device 'wgclient' link is up
Wed Jan 31 12:49:56 2024 daemon.notice netifd: Interface 'wgclient' is now up
Wed Jan 31 12:49:56 2024 daemon.info dnsmasq[5902]: exiting on receipt of SIGTERM
Wed Jan 31 12:49:56 2024 user.notice firewall: Reloading firewall due to ifup of wgclient (wgclient)
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq[9174]: Connected to system UBus
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq[9174]: started, version 2.85 cachesize 150
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq[9174]: DNS service limited to local subnets
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq[9174]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth cryptohash DNSSEC no-ID loop-detect inotify dumpfile
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq[9174]: UBus support enabled: connected to system bus
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq-dhcp[9174]: DHCP, IP range 192.168.9.100 -- 192.168.9.249, lease time 12h
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq-dhcp[9174]: DHCP, IP range 192.168.8.100 -- 192.168.8.249, lease time 12h
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq[9174]: using only locally-known addresses for domain test
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq[9174]: using only locally-known addresses for domain onion
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq[9174]: using only locally-known addresses for domain localhost
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq[9174]: using only locally-known addresses for domain invalid
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq[9174]: using only locally-known addresses for domain bind
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq[9174]: using only locally-known addresses for domain lan
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq[9174]: reading /tmp/resolv.conf.d/resolv.conf.wg
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq[9174]: using nameserver 193.138.219.228#53
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq[9174]: read /etc/hosts - 4 addresses
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq[9174]: read /tmp/hosts/dhcp.cfg01411c - 6 addresses
Wed Jan 31 12:49:59 2024 daemon.info dnsmasq-dhcp[9174]: read /etc/ethers - 0 addresses
Wed Jan 31 12:49:59 2024 user.notice wgclient-up: env value:T_J_V_ifname=string J_V_address_external=1 USER=root ifname=wgclient ACTION=KEYPAIR-CREATED N_J_V_address_external=address-external SHLVL=2 J_V_keep=1 HOME=/ HOTPLUG_TYPE=wireguard T_J_V_interface=string J_V_ifname=wgclient T_J_V_link_up=boolean LOGNAME=root DEVICENAME= T_J_V_action=int TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin CONFIG_LIST_STATE= J_V_interface=wgclient K_J_V= action ifname link_up address_external keep interface J_V_link_up=1 J_V_action=0 T_J_V_address_external=boolean N_J_V_link_up=link-up T_J_V_keep=boolean PWD=/ JSON_CUR=J_V CONFIG_SECTIONS=global AzireVPN Mullvad FromApp group_937 group_256 group_3223 peer_2162 peer_2163 peer_2164 peer_2165 peer_2166 peer_2167 peer_2168 peer_2169 peer_2170 peer_2171 peer_2172 peer_2173 peer_2174 peer_2175 peer_2176 peer_2177 peer_2178 peer_2179 peer_2180 peer_2181 peer_2182 peer_2183 peer_2184 peer_2185 peer_2186 peer_2187 peer_2188 peer_2189 peer_2190 peer_2191 peer_2192 peer_2193 peer_2
Wed Jan 31 12:51:21 2024 kern.notice kernel: [  162.682493] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(2), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=1023]4e:7a:e3:cd:74:57
Wed Jan 31 12:51:21 2024 kern.debug kernel: [  162.695568] entrytb_aid_aquire(): found non-occupied aid:6, allocated from:4
Wed Jan 31 12:51:21 2024 kern.warn kernel: [  162.702645] 7981@C13L2,MacTableInsertEntry() 1537: New Sta:4e:7a:e3:cd:74:57
Wed Jan 31 12:51:21 2024 kern.notice kernel: [  162.717849] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647:  Recv Assoc from STA - 4e:7a:e3:cd:74:57
Wed Jan 31 12:51:21 2024 kern.notice kernel: [  162.727201] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)...
Wed Jan 31 12:51:21 2024 kern.notice kernel: [  162.736348] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 2
Wed Jan 31 12:51:21 2024 kern.notice kernel: [  162.742388] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=2
Wed Jan 31 12:51:21 2024 kern.notice kernel: [  162.867818] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Wed Jan 31 12:51:21 2024 kern.notice kernel: [  162.887296] 7981@C15L3,PeerPairMsg2Action() 6202: ===>Receive msg 2
Wed Jan 31 12:51:21 2024 kern.notice kernel: [  162.894062] 7981@C15L3,WPABuildPairMsg3() 5557: <=== send Msg3 of 4-way
Wed Jan 31 12:51:21 2024 kern.notice kernel: [  162.902840] 7981@C15L3,PeerPairMsg4Action() 6632: ===>Receive msg 4
Wed Jan 31 12:51:21 2024 kern.warn kernel: [  162.914413] 7981@C15L2,PeerPairMsg4Action() 6994: AP SETKEYS DONE(rax0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=3 from 4e:7a:e3:cd:74:57
Wed Jan 31 12:51:25 2024 daemon.info dnsmasq-dhcp[9174]: DHCPREQUEST(br-lan) 192.168.8.115 4e:7a:e3:cd:74:57
Wed Jan 31 12:51:25 2024 daemon.info dnsmasq-dhcp[9174]: DHCPACK(br-lan) 192.168.8.115 4e:7a:e3:cd:74:57 Tommy-s-Tab-S8
Wed Jan 31 12:54:37 2024 kern.notice kernel: [  358.510651] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(2), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=1023]8e:87:b4:d2:91:72
Wed Jan 31 12:54:37 2024 kern.debug kernel: [  358.523567] entrytb_aid_aquire(): found non-occupied aid:7, allocated from:4
Wed Jan 31 12:54:37 2024 kern.warn kernel: [  358.530631] 7981@C13L2,MacTableInsertEntry() 1537: New Sta:8e:87:b4:d2:91:72
Wed Jan 31 12:54:37 2024 kern.err kernel: [  358.539460] 7981@C08L1,PeerAssocReqCmmSanity() 985: DSCPPolicyEnable = 1
Wed Jan 31 12:54:37 2024 kern.notice kernel: [  358.546201] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647:  Recv Assoc from STA - 8e:87:b4:d2:91:72
Wed Jan 31 12:54:37 2024 kern.notice kernel: [  358.555456] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)...
Wed Jan 31 12:54:37 2024 kern.err kernel: [  358.564545] 7981@C08L1,ap_cmm_peer_assoc_req_action() 2636: 8e:87:b4:d2:91:72, DSCPPolicyEnable=1
Wed Jan 31 12:54:37 2024 kern.notice kernel: [  358.573432] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 2
Wed Jan 31 12:54:37 2024 kern.notice kernel: [  358.579445] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=2
Wed Jan 31 12:54:37 2024 kern.notice kernel: [  358.700512] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Wed Jan 31 12:54:38 2024 kern.notice kernel: [  359.728274] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Wed Jan 31 12:54:38 2024 kern.notice kernel: [  359.764351] 7981@C15L3,PeerPairMsg2Action() 6202: ===>Receive msg 2
Wed Jan 31 12:54:38 2024 kern.notice kernel: [  359.771081] 7981@C15L3,WPABuildPairMsg3() 5557: <=== send Msg3 of 4-way
Wed Jan 31 12:54:38 2024 kern.notice kernel: [  359.777735] 7981@C15L3,PeerPairMsg4Action() 6632: ===>Receive msg 4
Wed Jan 31 12:54:38 2024 kern.warn kernel: [  359.789300] 7981@C15L2,PeerPairMsg4Action() 6994: AP SETKEYS DONE(rax0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=4 from 8e:87:b4:d2:91:72
Wed Jan 31 12:54:38 2024 daemon.info dnsmasq-dhcp[9174]: DHCPREQUEST(br-lan) 192.168.8.180 8e:87:b4:d2:91:72
Wed Jan 31 12:54:38 2024 daemon.info dnsmasq-dhcp[9174]: DHCPACK(br-lan) 192.168.8.180 8e:87:b4:d2:91:72 Pixel-8-Pro
Wed Jan 31 13:11:28 2024 kern.warn kernel: [ 1369.849154] 7981@C08L2,ap_peer_disassoc_action() 3479: ASSOC - 1 receive DIS-ASSOC request
Wed Jan 31 13:11:28 2024 kern.warn kernel: [ 1369.857533] 7981@C01L2,wifi_sys_disconn_act() 1002:  wdev_idx=2
Wed Jan 31 13:11:28 2024 kern.notice kernel: [ 1369.865661] 7981@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=2
Wed Jan 31 13:11:28 2024 kern.warn kernel: [ 1369.872724] 7981@C13L2,MacTableDeleteEntry() 1793: Del Sta:8e:87:b4:d2:91:72
Wed Jan 31 13:11:48 2024 kern.notice kernel: [ 1389.482141] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(2), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=1023]8e:87:b4:d2:91:72
Wed Jan 31 13:11:48 2024 kern.debug kernel: [ 1389.495062] entrytb_aid_aquire(): found non-occupied aid:7, allocated from:4
Wed Jan 31 13:11:48 2024 kern.warn kernel: [ 1389.502123] 7981@C13L2,MacTableInsertEntry() 1537: New Sta:8e:87:b4:d2:91:72
Wed Jan 31 13:11:48 2024 kern.err kernel: [ 1389.510923] 7981@C08L1,PeerAssocReqCmmSanity() 985: DSCPPolicyEnable = 1
Wed Jan 31 13:11:48 2024 kern.notice kernel: [ 1389.517649] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647:  Recv Assoc from STA - 8e:87:b4:d2:91:72
Wed Jan 31 13:11:48 2024 kern.notice kernel: [ 1389.526901] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)...
Wed Jan 31 13:11:48 2024 kern.err kernel: [ 1389.536008] 7981@C08L1,ap_cmm_peer_assoc_req_action() 2636: 8e:87:b4:d2:91:72, DSCPPolicyEnable=1
Wed Jan 31 13:11:48 2024 kern.notice kernel: [ 1389.544907] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 2
Wed Jan 31 13:11:48 2024 kern.notice kernel: [ 1389.550926] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=2
Wed Jan 31 13:11:48 2024 kern.notice kernel: [ 1389.673062] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Wed Jan 31 13:11:48 2024 kern.notice kernel: [ 1389.679686] 7981@C15L3,PeerPairMsg2Action() 6202: ===>Receive msg 2
Wed Jan 31 13:11:48 2024 kern.notice kernel: [ 1389.686412] 7981@C15L3,WPABuildPairMsg3() 5557: <=== send Msg3 of 4-way
Wed Jan 31 13:11:48 2024 kern.notice kernel: [ 1389.693038] 7981@C15L3,PeerPairMsg4Action() 6632: ===>Receive msg 4
Wed Jan 31 13:11:48 2024 kern.warn kernel: [ 1389.704594] 7981@C15L2,PeerPairMsg4Action() 6994: AP SETKEYS DONE(rax0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=4 from 8e:87:b4:d2:91:72
Wed Jan 31 13:11:48 2024 kern.err kernel: [ 1389.720082] 7981@C14L1,ReceiveBTMQuery() 1510: Find peer address in BTMPeerList already
Wed Jan 31 13:11:48 2024 daemon.info dnsmasq-dhcp[9174]: DHCPREQUEST(br-lan) 192.168.8.180 8e:87:b4:d2:91:72
Wed Jan 31 13:11:48 2024 daemon.info dnsmasq-dhcp[9174]: DHCPACK(br-lan) 192.168.8.180 8e:87:b4:d2:91:72 Pixel-8-Pro
I am a bit confused about date + time because it makes a huge jump within the logs. :confused:
Hmm, I’ll make sure to reference back next time I have a disconnect. It’s been going strong for a while now… Thanks admon for looking this over for me.
Also, I’ve had it happened with two separate public networks. One of them is password protected and the other isn’t.
Wed Jan 31 13:50:03 2024 daemon.info avahi-daemon[5526]: Registering new address record for fe80::9c83:c4ff:fe3d:d671 on apclix0.*.
Wed Jan 31 14:15:57 2024 kern.debug kernel: [   64.292996] BcnCheck start after 2500 ms (ra0)
Wed Jan 31 14:15:57 2024 kern.debug kernel: [   64.297468] BcnCheck start after 2500 ms (ra0)
Wed Jan 31 14:15:58 2024 daemon.info lua: (...arch64_cortex-a53/gl-sdk4-repeater/usr/sbin/repeater:1273) connected to 'BPGuest(EE:63:DA:75:FA:F0)' channel: 149, spent 2s
Wed Jan 31 14:15:58 2024 kern.warn kernel: [   65.881129] 7981@C01L2,wifi_sys_disconn_act() 1002:  wdev_idx=2
Wed Jan 31 14:15:58 2024 kern.notice kernel: [   65.887302] 7981@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=2
Wed Jan 31 14:15:58 2024 kern.warn kernel: [   65.894466] 7981@C13L2,MacTableDeleteEntry() 1793: Del Sta:64:49:7d:d2:5f:19
Wed Jan 31 14:15:58 2024 kern.notice kernel: [   65.901647] 7981@C08L3,ap_peer_deauth_action() 429: AUTH - receive DE-AUTH(seq-34) from 64:49:7d:d2:5f:19, reason=1
Wed Jan 31 14:16:00 2024 daemon.notice netifd: Network device 'wgclient' link is up
Wed Jan 31 14:16:00 2024 daemon.notice netifd: Interface 'wgclient' is now up
Wed Jan 31 14:16:00 2024 daemon.info dnsmasq[6149]: exiting on receipt of SIGTERM
Wed Jan 31 14:16:00 2024 user.notice firewall: Reloading firewall due to ifup of wgclient (wgclient)
Wed Jan 31 14:16:03 2024 kern.notice kernel: [   70.833401] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(2), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=1023]64:49:7d:d2:5f:19
Wed Jan 31 14:16:03 2024 kern.debug kernel: [   70.846306] entrytb_aid_aquire(): found non-occupied aid:4, allocated from:4
Wed Jan 31 14:16:03 2024 kern.warn kernel: [   70.853362] 7981@C13L2,MacTableInsertEntry() 1537: New Sta:64:49:7d:d2:5f:19
Wed Jan 31 14:16:03 2024 kern.notice kernel: [   70.862892] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647:  Recv Assoc from STA - 64:49:7d:d2:5f:19
Wed Jan 31 14:16:03 2024 kern.notice kernel: [   70.872166] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)...
Wed Jan 31 14:16:03 2024 kern.notice kernel: [   70.881263] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 2
Wed Jan 31 14:16:03 2024 kern.notice kernel: [   70.887290] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=2
Wed Jan 31 14:16:03 2024 kern.notice kernel: [   71.009670] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Wed Jan 31 14:16:03 2024 kern.notice kernel: [   71.016294] 7981@C15L3,PeerPairMsg2Action() 6202: ===>Receive msg 2
Wed Jan 31 14:16:03 2024 kern.notice kernel: [   71.023024] 7981@C15L3,WPABuildPairMsg3() 5557: <=== send Msg3 of 4-way
Wed Jan 31 14:16:04 2024 daemon.info dnsmasq[9040]: Connected to system UBus
Wed Jan 31 14:16:04 2024 daemon.info dnsmasq[9040]: started, version 2.85 cachesize 150
Wed Jan 31 14:16:04 2024 daemon.info dnsmasq[9040]: DNS service limited to local subnets
Wed Jan 31 14:16:04 2024 daemon.info dnsmasq[9040]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth cryptohash DNSSEC no-ID loop-detect inotify dumpfile
Wed Jan 31 14:16:04 2024 daemon.info dnsmasq[9040]: UBus support enabled: connected to system bus
Wed Jan 31 14:16:04 2024 daemon.info dnsmasq-dhcp[9040]: DHCP, IP range 192.168.9.100 -- 192.168.9.249, lease time 12h
Wed Jan 31 14:16:04 2024 daemon.info dnsmasq-dhcp[9040]: DHCP, IP range 192.168.8.100 -- 192.168.8.249, lease time 12h
Wed Jan 31 14:16:04 2024 daemon.info dnsmasq[9040]: using only locally-known addresses for domain test
Wed Jan 31 14:16:04 2024 daemon.info dnsmasq[9040]: using only locally-known addresses for domain onion
Wed Jan 31 14:16:04 2024 daemon.info dnsmasq[9040]: using only locally-known addresses for domain localhost
Wed Jan 31 14:16:04 2024 daemon.info dnsmasq[9040]: using only locally-known addresses for domain invalid
Wed Jan 31 14:16:04 2024 daemon.info dnsmasq[9040]: using only locally-known addresses for domain bind
Wed Jan 31 14:16:04 2024 daemon.info dnsmasq[9040]: using only locally-known addresses for domain lan
Wed Jan 31 14:16:04 2024 daemon.info dnsmasq[9040]: reading /tmp/resolv.conf.d/resolv.conf.wg
Wed Jan 31 14:16:04 2024 daemon.info dnsmasq[9040]: using nameserver 193.138.219.228#53
Wed Jan 31 14:16:04 2024 daemon.info dnsmasq[9040]: read /etc/hosts - 4 addresses
Wed Jan 31 14:16:04 2024 daemon.info dnsmasq[9040]: read /tmp/hosts/dhcp.cfg01411c - 6 addresses
Wed Jan 31 14:16:04 2024 daemon.info dnsmasq-dhcp[9040]: read /etc/ethers - 0 addresses
Wed Jan 31 14:16:04 2024 user.notice wgclient-up: env value:T_J_V_ifname=string J_V_address_external=1 USER=root ifname=wgclient ACTION=KEYPAIR-CREATED N_J_V_address_external=address-external SHLVL=2 J_V_keep=1 HOME=/ HOTPLUG_TYPE=wireguard T_J_V_interface=string J_V_ifname=wgclient T_J_V_link_up=boolean LOGNAME=root DEVICENAME= T_J_V_action=int TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin CONFIG_LIST_STATE= J_V_interface=wgclient K_J_V= action ifname link_up address_external keep interface J_V_link_up=1 J_V_action=0 T_J_V_address_external=boolean N_J_V_link_up=link-up T_J_V_keep=boolean PWD=/ JSON_CUR=J_V CONFIG_SECTIONS=global AzireVPN Mullvad FromApp group_937 group_256 group_3223 peer_2162 peer_2163 peer_2164 peer_2165 peer_2166 peer_2167 peer_2168 peer_2169 peer_2170 peer_2171 peer_2172 peer_2173 peer_2174 peer_2175 peer_2176 peer_2177 peer_2178 peer_2179 peer_2180 peer_2181 peer_2182 peer_2183 peer_2184 peer_2185 peer_2186 peer_2187 peer_2188 peer_2189 peer_2190 peer_2191 peer_2192 peer_2193 peer_2
Wed Jan 31 14:16:04 2024 daemon.info dnsmasq-dhcp[9040]: DHCPREQUEST(br-lan) 192.168.8.206 64:49:7d:d2:5f:19
Wed Jan 31 14:16:04 2024 daemon.info dnsmasq-dhcp[9040]: DHCPACK(br-lan) 192.168.8.206 64:49:7d:d2:5f:19 USPRO-L-TB
Wed Jan 31 14:16:04 2024 kern.notice kernel: [   71.561423] 7981@C15L3,PeerPairMsg4Action() 6632: ===>Receive msg 4
Wed Jan 31 14:16:04 2024 kern.warn kernel: [   71.579603] 7981@C15L2,PeerPairMsg4Action() 6994: AP SETKEYS DONE(rax0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=1 from 64:49:7d:d2:5f:19
Wed Jan 31 14:16:05 2024 daemon.info dnsmasq-dhcp[9040]: DHCPREQUEST(br-lan) 192.168.8.206 64:49:7d:d2:5f:19
Wed Jan 31 14:16:05 2024 daemon.info dnsmasq-dhcp[9040]: DHCPACK(br-lan) 192.168.8.206 64:49:7d:d2:5f:19 USPRO-L-TB
Wed Jan 31 14:17:35 2024 kern.notice kernel: [  162.678948] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(2), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=1023]4e:7a:e3:cd:74:57
Wed Jan 31 14:17:35 2024 kern.debug kernel: [  162.691880] entrytb_aid_aquire(): found non-occupied aid:6, allocated from:4
Wed Jan 31 14:17:35 2024 kern.warn kernel: [  162.698944] 7981@C13L2,MacTableInsertEntry() 1537: New Sta:4e:7a:e3:cd:74:57
Wed Jan 31 14:17:35 2024 kern.notice kernel: [  162.714975] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647:  Recv Assoc from STA - 4e:7a:e3:cd:74:57
Wed Jan 31 14:17:35 2024 kern.notice kernel: [  162.724380] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)...
Wed Jan 31 14:17:35 2024 kern.notice kernel: [  162.733586] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 2
Wed Jan 31 14:17:35 2024 kern.notice kernel: [  162.739756] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=2
Wed Jan 31 14:17:35 2024 kern.notice kernel: [  162.861259] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Wed Jan 31 14:17:35 2024 kern.notice kernel: [  162.894258] 7981@C15L3,PeerPairMsg2Action() 6202: ===>Receive msg 2
Wed Jan 31 14:17:35 2024 kern.notice kernel: [  162.901085] 7981@C15L3,WPABuildPairMsg3() 5557: <=== send Msg3 of 4-way
Wed Jan 31 14:17:35 2024 kern.notice kernel: [  162.908613] 7981@C15L3,PeerPairMsg4Action() 6632: ===>Receive msg 4
Wed Jan 31 14:17:35 2024 kern.warn kernel: [  162.920194] 7981@C15L2,PeerPairMsg4Action() 6994: AP SETKEYS DONE(rax0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=3 from 4e:7a:e3:cd:74:57
Wed Jan 31 14:17:36 2024 daemon.info dnsmasq-dhcp[9040]: DHCPREQUEST(br-lan) 192.168.8.115 4e:7a:e3:cd:74:57
Wed Jan 31 14:17:36 2024 daemon.info dnsmasq-dhcp[9040]: DHCPACK(br-lan) 192.168.8.115 4e:7a:e3:cd:74:57 Tommy-s-Tab-S8
Wed Jan 31 14:20:09 2024 user.notice gl-switch: switch released
Wed Jan 31 14:20:09 2024 daemon.notice netifd: Network device 'wgclient' link is down
Wed Jan 31 14:20:09 2024 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Wed Jan 31 14:20:09 2024 daemon.notice netifd: wgclient (10267): sh: 1: unknown operand
Wed Jan 31 14:20:09 2024 daemon.info dnsmasq[9040]: exiting on receipt of SIGTERM
Wed Jan 31 14:20:10 2024 daemon.notice netifd: wgclient (10267): udhcpc: started, v1.33.2
Wed Jan 31 14:20:10 2024 daemon.notice netifd: wgclient (10267): udhcpc: sending discover
Wed Jan 31 14:20:13 2024 daemon.notice netifd: wgclient (10267): udhcpc: no lease, failing
Wed Jan 31 14:20:13 2024 daemon.notice netifd: Interface 'wgclient' is now down
Wed Jan 31 14:20:13 2024 daemon.info dnsmasq[10735]: Connected to system UBus
Wed Jan 31 14:20:13 2024 daemon.info dnsmasq[10735]: started, version 2.85 cachesize 150
Wed Jan 31 14:20:13 2024 daemon.info dnsmasq[10735]: DNS service limited to local subnets
Wed Jan 31 14:20:13 2024 daemon.info dnsmasq[10735]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth cryptohash DNSSEC no-ID loop-detect inotify dumpfile
Wed Jan 31 14:20:13 2024 daemon.info dnsmasq[10735]: UBus support enabled: connected to system bus
Wed Jan 31 14:20:13 2024 daemon.info dnsmasq-dhcp[10735]: DHCP, IP range 192.168.9.100 -- 192.168.9.249, lease time 12h
Wed Jan 31 14:20:13 2024 daemon.info dnsmasq-dhcp[10735]: DHCP, IP range 192.168.8.100 -- 192.168.8.249, lease time 12h
Wed Jan 31 14:20:13 2024 daemon.info dnsmasq[10735]: using only locally-known addresses for domain test
Wed Jan 31 14:20:13 2024 daemon.info dnsmasq[10735]: using only locally-known addresses for domain onion
Wed Jan 31 14:20:13 2024 daemon.info dnsmasq[10735]: using only locally-known addresses for domain localhost
Wed Jan 31 14:20:13 2024 daemon.info dnsmasq[10735]: using only locally-known addresses for domain invalid
Wed Jan 31 14:20:13 2024 daemon.info dnsmasq[10735]: using only locally-known addresses for domain bind
Wed Jan 31 14:20:13 2024 daemon.info dnsmasq[10735]: using only locally-known addresses for domain lan
Wed Jan 31 14:20:13 2024 daemon.info dnsmasq[10735]: reading /tmp/resolv.conf.d/resolv.conf.auto
Wed Jan 31 14:20:13 2024 daemon.info dnsmasq[10735]: using nameserver 192.168.2.1#53
Wed Jan 31 14:20:13 2024 daemon.info dnsmasq[10735]: read /etc/hosts - 4 addresses
Wed Jan 31 14:20:13 2024 daemon.info dnsmasq[10735]: read /tmp/hosts/dhcp.cfg01411c - 6 addresses
Wed Jan 31 14:20:13 2024 daemon.info dnsmasq-dhcp[10735]: read /etc/ethers - 0 addresses
Wed Jan 31 14:20:13 2024 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
I see there was a gap, it disconnected right at 14:15.
If I have a cable that just isn’t capable of pulling 5v-3A that could be an issue right? I’m truly hoping it isnt a router issue. I’ve also noticed when it disconnects; going into the Admin Panel → Internet, my Repeater is disabled then quickly reenables. That’s all I got for you. Thanks again.
