M2 development board Restart
Hi, i would like to know how to automatically restart the board every day at least one time, i can schedule restart on the router but it didnt restart the m2 board because it has external supply appart of a usb... regards.
May I know what reason why you require to restart the board every day?
Try the below in SSH, it brings the modem power on/off via AT command when the router boot-up.
Update-1:
Edit:
/etc/rc.local
Add:
sleep 5
gl_modem AT+QPOWD
i dont know why but for example yesterday I went to bed and it was working perfect and today when i wake up it appeared disconnected.. probably restarting it everyday or once per week it will work better, regards.
hello
Can you go to the web page to see its status when it is disconnected?
See if it's disconnected, or if it's connected and there's no network
thank you
it showed something strange like the sim is wasnt registered, i will come back again when it happened again and i will make a screenshot to put here. Thanks :wink:
anyway bringing usb power on/off i think it wont reboot the board because it has a external power add appart the usb
