Make Adding An SSID Easier In GL-iNet GUI
It’s been a while since a similar request was made.
How difficult is it to implement?
PS: Don’t tell me to run vanilla OpenWrt, because I know how to run it already
Thank you for sharing this suggestion. We understand that being able to create additional SSIDs directly from the GL.iNet GUI would make this type of setup more convenient.
How, the supported VAP capabilities and implementation can vary between different router models and wireless platforms, so this type of feature needs to take these platform differences and compatibility into consideration.
Thank you for your attention to this feature and for sharing your suggestion with us.
In my case, let’s just say my request is driven by an unusual situation. Some old devices than can only do 2.4GH and WPA-PSK without special characters in passwords would need to have their own dedicated SSID.
I only own Flint 2 and Flint 3.
In that case, why not just use the 2.4 GHz network for those devices and let all others continue to use 5 GHz?
Because not all modern devices use 5GHz.
4.9.x firmware should introduce an IoT network for this case.
Maybe you can give it a try?
