I’m having problem making Mango work as a WI-FI repeater. When trying to set up a connection, I see a success message, however, later web UI shows no Internet connection message and there is no connection indeed. Previously it worked fine but stopped after the Internet company did some work on WI-FI (I live in a building with a shared WI-FI network).
I’m attaching system and kernel logs. The only notable line I see is “[ 177.765288] ERROR: AP BSSID not equal”. However, I’m not sure what to get from it. Thanks in advance.
Kernel Log
[ 159.753380] MtAsicSetPreTbtt(): bss_idx=0, PreTBTT timeout = 0x0
[ 159.759484] MtAsicSetPiggyBack(1081): Not support for HIF_MT yet!
[ 159.765753] [PMF]ap_pmf_init:: apidx=0, MFPC=0, MFPR=0, SHA256=0
[ 159.771872] [PMF]RTMPMakeRsnIeCap: RSNIE Capability MFPC=0, MFPR=0
[ 159.778173] [PMF]ap_pmf_init:: apidx=1, MFPC=0, MFPR=0, SHA256=0
[ 159.784287] [PMF]RTMPMakeRsnIeCap: RSNIE Capability MFPC=0, MFPR=0
[ 159.790648] MtAsicSetRalinkBurstMode(4061): Not support for HIF_MT yet!
[ 159.797387] MtAsicSetPiggyBack(1081): Not support for HIF_MT yet!
[ 159.883306] MtAsicSetTxPreamble(4040): Not support for HIF_MT yet!
[ 159.892975] MtAsicAddSharedKeyEntry(1909): Not support for HIF_MT yet!
[ 159.902891] MtAsicAddSharedKeyEntry(1909): Not support for HIF_MT yet!
[ 159.909562] AddTxSType: already registered TxSType (PID = 32, Format = 0
[ 159.916447] The 4-BSSID mode is enabled, the BSSID byte5 MUST be the multiple of 4
[ 159.924257] AddTxSType: already registered TxSType (PID = 6, Format = 0
[ 159.930976] MtAsicSetPreTbtt(): bss_idx=0, PreTBTT timeout = 0xf0
[ 159.937228] Main bssid = 94:83:c4:07:af:eb
[ 160.058650] MtAsicSetPreTbtt(): bss_idx=0, PreTBTT timeout = 0x0
[ 160.064864] MtAsicSetPiggyBack(1081): Not support for HIF_MT yet!
[ 160.071092] [PMF]ap_pmf_init:: apidx=0, MFPC=0, MFPR=0, SHA256=0
[ 160.077244] [PMF]RTMPMakeRsnIeCap: RSNIE Capability MFPC=0, MFPR=0
[ 160.083537] [PMF]ap_pmf_init:: apidx=1, MFPC=0, MFPR=0, SHA256=0
[ 160.089632] [PMF]RTMPMakeRsnIeCap: RSNIE Capability MFPC=0, MFPR=0
[ 160.095971] MtAsicSetRalinkBurstMode(4061): Not support for HIF_MT yet!
[ 160.102724] MtAsicSetPiggyBack(1081): Not support for HIF_MT yet!
[ 160.151228] MtAsicSetTxPreamble(4040): Not support for HIF_MT yet!
[ 160.161198] MtAsicAddSharedKeyEntry(1909): Not support for HIF_MT yet!
[ 160.171148] MtAsicAddSharedKeyEntry(1909): Not support for HIF_MT yet!
[ 160.177816] AddTxSType: already registered TxSType (PID = 32, Format = 0
[ 160.184918] The 4-BSSID mode is enabled, the BSSID byte5 MUST be the multiple of 4
[ 160.192699] AddTxSType: already registered TxSType (PID = 6, Format = 0
[ 160.199512] MtAsicSetPreTbtt(): bss_idx=0, PreTBTT timeout = 0xf0
[ 160.205728] Main bssid = 94:83:c4:07:af:eb
[ 160.318025] AddTxSType: already registered TxSType (PID = 32, Format = 0
[ 160.324908] The 4-BSSID mode is enabled, the BSSID byte5 MUST be the multiple of 4
[ 167.056353] The 4-BSSID mode is enabled, the BSSID byte5 MUST be the multiple of 4
[ 167.065062] MtAsicSetPreTbtt(): bss_idx=0, PreTBTT timeout = 0x0
[ 167.071155] MtAsicSetPiggyBack(1081): Not support for HIF_MT yet!
[ 168.768732] tx_kickout_fail_count = 0
[ 168.772457] tx_timeout_fail_count = 0
[ 168.776233] rx_receive_fail_count = 0
[ 168.779944] alloc_cmd_msg = 70
[ 168.783037] free_cmd_msg = 70
[ 168.790118] br-lan: port 2(ra0) entered disabled state
[ 168.866669] TX_BCN DESC a6f70000 size = 320
[ 168.870991] RX[0] DESC a6f72000 size = 2048
[ 168.875647] RX[1] DESC a6f73000 size = 1024
[ 168.945541] prepare to get e2p access------------
[ 168.950581] E2pAccessMode=2
[ 168.954297] cfg_mode=9
[ 168.956692] cfg_mode=9
[ 168.959095] wmode_band_equal(): Band Equal!
[ 168.967234] APSDCapable[0]=0
[ 168.970157] APSDCapable[1]=0
[ 168.973075] APSDCapable[2]=0
[ 168.976033] APSDCapable[3]=0
[ 168.978955] APSDCapable[4]=0
[ 168.981875] APSDCapable[5]=0
[ 168.984814] APSDCapable[6]=0
[ 168.987732] APSDCapable[7]=0
[ 168.990650] APSDCapable[8]=0
[ 168.993583] APSDCapable[9]=0
[ 168.996501] APSDCapable[10]=0
[ 168.999507] APSDCapable[11]=0
[ 169.002514] APSDCapable[12]=0
[ 169.005543] APSDCapable[13]=0
[ 169.008549] APSDCapable[14]=0
[ 169.011553] APSDCapable[15]=0
[ 169.014583] default ApCliAPSDCapable[0]=0
[ 169.361050] Key1Str is Invalid key length(0) or Type(1)
[ 169.366551] Key1Str is Invalid key length(0) or Type(1)
[ 169.372198] Key2Str is Invalid key length(0) or Type(1)
[ 169.377697] Key2Str is Invalid key length(0) or Type(1)
[ 169.383364] Key3Str is Invalid key length(0) or Type(1)
[ 169.388840] Key3Str is Invalid key length(0) or Type(1)
[ 169.394518] Key4Str is Invalid key length(0) or Type(1)
[ 169.399995] Key4Str is Invalid key length(0) or Type(1)
[ 169.435711] load fw image from fw_header_image
[ 169.440225] AndesMTLoadFwMethod1(2548)::pChipCap->fw_len(63536)
[ 169.446244] FW Version:
[ 169.446251] _
[ 169.448730] e
[ 169.450326] 2
[ 169.451923] _
[ 169.453530] m
[ 169.455127] p
[ 169.456723]
[ 169.458319]
[ 169.459916]
[ 169.461512]
[ 169.463108]
[ 169.466225] FW Build Date:
[ 169.466230] 2
[ 169.468972] 0
[ 169.470568] 1
[ 169.472164] 5
[ 169.473772] 0
[ 169.475369] 6
[ 169.476965] 2
[ 169.478561] 5
[ 169.480157] 2
[ 169.481753] 1
[ 169.483370] 1
[ 169.484968] 4
[ 169.486564] 2
[ 169.488160] 2
[ 169.489756]
[ 169.491352]
[ 169.494552] CmdReStartDLRsp: WiFI FW Download Success
[ 169.694592] CmdAddressLenReq:(ret = 0)
[ 169.699207] CmdFwStartReq: override = 1, address = 1048576
[ 169.704910] CmdStartDLRsp: WiFI FW Download Success
[ 169.710867] MtAsicDMASchedulerInit(): DMA Scheduler Mode=0(LMAC)
[ 169.717069] efuse_probe: efuse = 10000012
[ 169.721138] RtmpChipOpsEepromHook::e2p_type=2, inf_Type=4
[ 169.726632] RtmpEepromGetDefault::e2p_dafault=2
[ 169.731229] RtmpChipOpsEepromHook: E2P type(2), E2pAccessMode = 2, E2P default = 2
[ 169.738916] NVM is FLASH mode
[ 169.741978] 1. Phy Mode = 14
[ 169.908534] Country Region from e2p = ffff
[ 169.912786] tssi_1_target_pwr_g_band = 33
[ 169.916891] 2. Phy Mode = 14
[ 169.919908] 3. Phy Mode = 14
[ 169.922834] NICInitPwrPinCfg(11): Not support for HIF_MT yet!
[ 169.928685] NICInitializeAsic(848): Not support rtmp_mac_sys_reset () for HIF_MT yet!
[ 169.936647] mt_mac_init()–>
[ 169.939568] MtAsicInitMac()–>
[ 169.943303] mt7628_init_mac_cr()–>
[ 169.946867] MtAsicSetMacMaxLen(1842): Set the Max RxPktLen=1024!
[ 169.952954] <–mt_mac_init()
[ 169.956080] WTBL Segment 1 info:
[ 169.959443] MemBaseAddr/FID:0x28000/0
[ 169.963341] EntrySize/Cnt:32/128
[ 169.966788] WTBL Segment 2 info:
[ 169.970146] MemBaseAddr/FID:0x40000/0
[ 169.974050] EntrySize/Cnt:64/128
[ 169.977497] WTBL Segment 3 info:
[ 169.980855] MemBaseAddr/FID:0x42000/64
[ 169.984847] EntrySize/Cnt:64/128
[ 169.988293] WTBL Segment 4 info:
[ 169.991651] MemBaseAddr/FID:0x44000/128
[ 169.995731] EntrySize/Cnt:32/128
[ 169.999259] AntCfgInit(3606): Not support for HIF_MT yet!
[ 170.004878] MCS Set = ff ff 00 00 00
[ 170.008504] MtAsicSetChBusyStat(1146): Not support for HIF_MT yet!
[ 170.014831] [PMF]ap_pmf_init:: apidx=0, MFPC=0, MFPR=0, SHA256=0
[ 170.020932] [PMF]RTMPMakeRsnIeCap: RSNIE Capability MFPC=0, MFPR=0
[ 170.027232] [PMF]ap_pmf_init:: apidx=1, MFPC=0, MFPR=0, SHA256=0
[ 170.033356] [PMF]RTMPMakeRsnIeCap: RSNIE Capability MFPC=0, MFPR=0
[ 170.039668] MtAsicSetRalinkBurstMode(4061): Not support for HIF_MT yet!
[ 170.046397] MtAsicSetPiggyBack(1081): Not support for HIF_MT yet!
[ 170.072420] MtAsicSetTxPreamble(4040): Not support for HIF_MT yet!
[ 170.082078] MtAsicAddSharedKeyEntry(1909): Not support for HIF_MT yet!
[ 170.091986] MtAsicAddSharedKeyEntry(1909): Not support for HIF_MT yet!
[ 170.098648] The 4-BSSID mode is enabled, the BSSID byte5 MUST be the multiple of 4
[ 170.106431] MtAsicSetPreTbtt(): bss_idx=0, PreTBTT timeout = 0xf0
[ 170.112626] Main bssid = 94:83:c4:07:af:eb
[ 170.116884] <==== rt28xx_init, Status=0
[ 170.120824] mt7628_set_ed_cca: TURN OFF EDCCA mac 0x10618 = 0xd7083f0f, EDCCA_Status=0
[ 170.128979] WiFi Startup Cost (ra0): 1.260s
[ 170.134036] br-lan: port 2(ra0) entered blocking state
[ 170.139263] br-lan: port 2(ra0) entered forwarding state
[ 173.789483] AddTxSType: already registered TxSType (PID = 32, Format = 0
[ 173.796369] The 4-BSSID mode is enabled, the BSSID byte5 MUST be the multiple of 4
[ 177.282872] AddTxSType: already registered TxSType (PID = 32, Format = 0
[ 177.289784] The 4-BSSID mode is enabled, the BSSID byte5 MUST be the multiple of 4
System Log
Sat May 22 19:02:02 2021 daemon.notice netifd: Network device ‘ra0’ link is up
Sat May 22 19:02:04 2021 daemon.notice procd: /etc/rc.d/S99wireguard: uci: Entry not found
Sat May 22 19:02:04 2021 user.notice wireguard: wireguard client start
Sat May 22 19:02:04 2021 daemon.notice procd: /etc/rc.d/S99wireguard_server: uci: Entry not found
Sat May 22 19:02:04 2021 daemon.info procd: - init complete -
Sat May 22 19:02:05 2021 user.info mwan3rtmon[2320]: Detect rtchange event.
Sat May 22 19:02:06 2021 daemon.info dnsmasq-dhcp[2389]: DHCPREQUEST(br-lan) 192.168.8.207 00:e0:4c:01:68:9a
Sat May 22 19:02:06 2021 daemon.warn dnsmasq-dhcp[2389]: Ignoring domain mycomputer for DHCP host name new
Sat May 22 19:02:06 2021 daemon.info dnsmasq-dhcp[2389]: DHCPACK(br-lan) 192.168.8.207 00:e0:4c:01:68:9a new
Sat May 22 19:02:06 2021 daemon.notice netifd: Network device ‘apcli0’ link is up
Sat May 22 19:02:06 2021 daemon.notice netifd: Interface ‘wwan’ is enabled
Sat May 22 19:02:06 2021 daemon.notice netifd: Interface ‘wwan’ has link connectivity
Sat May 22 19:02:06 2021 daemon.notice netifd: Interface ‘wwan’ is setting up now
Sat May 22 19:02:06 2021 daemon.notice netifd: Network device ‘apcli0’ link is down
Sat May 22 19:02:06 2021 daemon.notice netifd: Interface ‘wwan’ has link connectivity loss
Sat May 22 19:02:06 2021 user.notice apcli: apcli0 down
Sat May 22 19:02:06 2021 daemon.notice netifd: Interface ‘wwan’ is now down
Sat May 22 19:02:06 2021 daemon.notice netifd: Interface ‘wwan’ is disabled
Sat May 22 19:02:07 2021 daemon.notice netifd: wwan (3431): udhcpc: started, v1.30.1
Sat May 22 19:02:07 2021 daemon.notice netifd: wwan (3431): udhcpc: sending discover
Sat May 22 19:02:10 2021 daemon.notice netifd: wwan (3431): udhcpc: sending discover
Sat May 22 19:02:13 2021 daemon.notice netifd: wwan (3431): udhcpc: sending discover
Sat May 22 19:03:37 2021 user.info : saved ssid ignore: WIFI NETWORK
Sat May 22 19:03:37 2021 user.info : [ 810] gl-sdk>> bIsSaved=0, ssid=WIFI NETWORK, encryption=none, bssid=E0:63:DA:0A:2F:D0, wds=0, device=mt7628, identity=, channel=6
Sat May 22 19:03:38 2021 user.notice apcli: apcli0 down
Sat May 22 19:03:38 2021 daemon.notice netifd: wwan (3431): udhcpc: received SIGTERM
Sat May 22 19:03:38 2021 daemon.notice netifd: Interface ‘wwan’ is now down
Sat May 22 19:03:38 2021 daemon.notice netifd: Interface ‘wwan’ is disabled
Sat May 22 19:03:38 2021 daemon.notice netifd: Network device ‘apcli0’ link is down
Sat May 22 19:03:38 2021 daemon.notice netifd: Interface ‘wwan’ has link connectivity loss
Sat May 22 19:03:38 2021 daemon.notice netifd: Network device ‘apcli0’ link is up
Sat May 22 19:03:38 2021 user.info : [ 2895] gl-wifi-core>> bIsStaEnabled=1
Sat May 22 19:03:43 2021 user.info : [ 817] gl-sdk>> wifi_join return=0, channel=6
Sat May 22 19:03:43 2021 daemon.notice netifd: Interface ‘wwan’ is enabled
Sat May 22 19:03:43 2021 daemon.notice netifd: Interface ‘wwan’ is setting up now
Sat May 22 19:03:44 2021 daemon.notice netifd: wwan (5888): udhcpc: started, v1.30.1
Sat May 22 19:03:44 2021 daemon.notice netifd: wwan (5888): udhcpc: sending discover
Sat May 22 19:03:44 2021 daemon.notice netifd: Network device ‘apcli0’ link is down
Sat May 22 19:03:44 2021 daemon.notice netifd: Interface ‘wwan’ has link connectivity loss
Sat May 22 19:03:44 2021 daemon.notice netifd: wwan (5888): udhcpc: read error: Network is down, reopening socket
Sat May 22 19:03:44 2021 user.notice apcli: apcli0 down
Sat May 22 19:03:44 2021 daemon.notice netifd: wwan (5888): udhcpc: received SIGTERM
Sat May 22 19:03:44 2021 daemon.notice netifd: Interface ‘wwan’ is now down
Sat May 22 19:03:44 2021 daemon.notice netifd: Interface ‘wwan’ is disabled
Sat May 22 19:03:44 2021 daemon.notice netifd: Interface ‘wwan’ is enabled
Sat May 22 19:03:47 2021 daemon.notice netifd: Network device ‘ra0’ link is down
Sat May 22 19:03:48 2021 daemon.notice netifd: Network device ‘ra0’ link is up
Sat May 22 19:03:52 2021 daemon.notice netifd: Network device ‘apcli0’ link is up
Sat May 22 19:03:52 2021 daemon.notice netifd: Interface ‘wwan’ has link connectivity
Sat May 22 19:03:52 2021 daemon.notice netifd: Interface ‘wwan’ is setting up now
Sat May 22 19:03:52 2021 daemon.notice netifd: wwan (6333): udhcpc: started, v1.30.1
Sat May 22 19:03:52 2021 daemon.notice netifd: wwan (6333): udhcpc: sending discover
Sat May 22 19:03:55 2021 daemon.notice netifd: wwan (6333): udhcpc: sending discover
Sat May 22 19:03:55 2021 daemon.notice netifd: Network device ‘apcli0’ link is down
Sat May 22 19:03:55 2021 daemon.notice netifd: Interface ‘wwan’ has link connectivity loss
Sat May 22 19:03:55 2021 daemon.notice netifd: wwan (6333): udhcpc: read error: Network is down, reopening socket
Sat May 22 19:03:55 2021 daemon.notice netifd: Network device ‘apcli0’ link is up
Sat May 22 19:03:55 2021 user.notice apcli: apcli0 down
Sat May 22 19:03:55 2021 daemon.notice netifd: wwan (6333): udhcpc: received SIGTERM
Sat May 22 19:03:55 2021 daemon.notice netifd: Interface ‘wwan’ is now down
Sat May 22 19:03:55 2021 daemon.notice netifd: Interface ‘wwan’ is disabled
Sat May 22 19:03:55 2021 daemon.notice netifd: Interface ‘wwan’ is enabled
Sat May 22 19:03:55 2021 daemon.notice netifd: Interface ‘wwan’ is setting up now
Sat May 22 19:03:56 2021 daemon.notice netifd: wwan (6437): udhcpc: started, v1.30.1
Sat May 22 19:03:56 2021 daemon.notice netifd: wwan (6437): udhcpc: sending discover
Sat May 22 19:03:59 2021 daemon.notice netifd: wwan (6437): udhcpc: sending discover
Sat May 22 19:04:02 2021 daemon.notice netifd: wwan (6437): udhcpc: sending discover
