As with other router firmwares, mango router is unable to override the android phone’s own private dns, i guess it’s a good thing when you are connected to 3rd party networks
is this intended or is there a configuration on the mango i missed ?
Already checked both ‘override dns for all clients’ and ‘dot by cloudflare’ on the mango
edit also, is ‘enforce dnssec’ option necessary or its already default for cloudflare dns hence not required?
If the mobile phone is set with static DNS, the data analysis will preferentially use the mobile static DNS resolution.the DNS settings we route will not overwrite the DNS settings set by the phone
