Manual DNS GL-AX 1800 doesn't work
Hi!
I have a small server at home and this server runs Pi-Hole with local DNS and ad filter.
I try to use this server as a Manual DNS for the router so all router’s clients will pass through this server.
But it doesn’t work. I can set manually DNS server on the client to make it work but I don’t want to do it for all clients.
Router Admin panel
on Windows PC
ipconfig
output for nslookup
When I specify a server for nslookup it finds the address
what is console.gl-inet.com server?
Also, some logs from the router
Why it doesn’t work?
If I set DNS manually
It just works
Is it a router issue?
OpenWRT issue. You need to set it at the interface level → advanced
Then the DNS IP will be given to the client when it connects.
Run these commands on your router.
PI =“192.168.8.112”
uci add_list dhcp.lan.dhcp_option=“6,${PI}”
uci commit dhcp
Then the reboot or restart DNS on router ( /etc/init.d/dnsmasq restart)
