Maswell 5G Antenne 4X4 MIMO + Dualband-WLAN-Antenne?
hi everyone,
Although my internet signal is very good with the original GL-X3000 antennas, I would like to improve it further by using external antennas. My question is: would these external antennas be compatible with the GL-X3000?
If you have any other antenna suggestions from Amazon.de, I would be grateful.
THANK YOU in advance
wlan antennas (i want a bit more range): https://www.amazon.de/Eightwood-Dualband-WLAN-Antenne-Verlängerungskabel-Bluetooth-Karte-Netzwerk-Router/dp/B09XHBFXXH/ref=sr_1_2?__mk_de_DE=ÅMÅŽÕÑ&s=ce-de&sr=1-2
5g/4g antennas: Amazon.de
The connector of cellular and Wi-Fi external antenna can be compatible with X3000. But regarding their performance, to actually test it to compare.
