Do you have any recommendations on the max wireless power I should set for the 6416? The software seems to allow up to 1000 mW, but that seems surprisingly high. What max power do you suggest before the transmissions become distorted?
Hi, the wireless power should be set to 18dbm. Seems in Luci you can select a bigger value, but the hardware is limited to 18dbm.
