Maximum MicroSD Size?
Hi, my router, a Slate, accepts a MicroSD card. it looks like there’s a max size limit for them, in my case it’s 128GB. I wonder what will happen if I use a larger size card? Will it still work, just 128GB is recognized, or it won’t work at all? Is there such a limitation for USB drives? Thanks
Size should not matter too much.
Thanks for the reply. I ordered a 512GB microSD card. Will give it a try.
