Dear group,
Setup: gl-mifi, running 3.211
Use-Case: monitoring probe, periodically checking whether my internet access is alive and all my hosts in my network are up and running.
Customisation: opened WAN (eth0) so I can ssh in. I don’t want to connect LAN (eth1) to my actual LAN because I already have a DHCP server running. I also want to keep the LAN port and wlan0/access point running as-is so I have a backdoor if I misconfigure something
What I want:
The mifi checks whether the firewall (another host on the network) still sees the internet. So the internal connection towards the firewall might still be up, but the mifi (and the rest of the network) cannot reach the internet. If this is the case, the LTE modem should be brought up (enabling some further tests and magic).
What I did:
Initially, the routing table (ip route list. if you prefer route -n, I can amend) looks like this:
default via 10.0.20.1 dev eth0 proto static src 10.0.20.88 metric 10
10.0.20.0/24 dev eth0 proto static scope link metric 10
192.168.8.0/24 dev br-lan proto kernel scope link src 192.168.8.1
When I fire up the modem, it looks like this:
default via 10.24.57.196 dev wwan0 proto static src 10.24.57.195 metric 40
10.24.57.192/29 dev wwan0 proto static scope link metric 40
So the default route over the internal interface still takes precedence. I found out how to lower the metric for a route:
ip route del 0.0.0.0/0.0.0.0 via <GW IP>
ip route add 0.0.0.0/0.0.0.0 via <GW IP> metric <new metric> proto static src <OUTGOING IP>
So the routing table looks like this:
default via 10.24.57.196 dev wwan0 proto static src 10.24.57.195 metric 5
But: Packets don’t flow over the LTE interface.
If I ping with ping -I , I get answers. If I ping without the source interface, the packets don’t get routed according to the routing table.
I also tried increasing the metric of the route via eth0, it did not help, same effect.
What other nerd-knob do I have to twist? Or is there some hidden daemon that needs to be poked when I fiddle with the routing table?
Thanks a lot
Simon
