Hello.
I am aware that in the next version of the router, there will be a change made to the USB/Charging circuit so that the USB power is not cutt off when the battery is charging.
I wanted to suggest the addition of some buttons to toggle wifi and 3G.
I need to disable the wifi when in the office so as not to interfere with on-site wifi, which has to be done in software. I need a laptop with a cable to re-enable it, which is impossible if I am using a tablet on the road.
It would be nice to disable 3G with a button so that I can use the storage or another feature without using 3G.
Thanks!
