I just received my GL-MiFi and it works perfectly. I ordered it without minipcie module, because I already had an Ericsson F5521gw at home.
I installed the module, booted up fine. Upgraded firmware to v2.22.
The Ericsson F5521gw MiniPCIe module (HP model, hs2340 HSPA+ MobileBroadband) was detected fine, but, it was not possible to create a connection through the glweb interface. Switched to advanced settings (LuCI), added the new interface there as UMTS/GPRS/EV-DO with modem device selected as /dev/ttyACM0, filled in my APN and it started working immediately. I was even able to set up LED configuration to show connected state properly on the box.
Going back to GL-MiFi’s own glweb interface, the “Internet status” is empty (says Cable not connected).
If I go to New connection > 3G the page says “Please plug in your modem”. But the modem is plugged in and it is working as I am accessing this forum through it right now. I also upgraded the system to testing firmware 2.24, still the same.
What can I do to make glweb interface also to recognize Ericsson F5521gw / HP hs2340 HSPA+ MobileBroadband modem?
OK, what I found so far is that this modem appears as /dev/ttyACM0 /dev/ttyACM1 /dev/ttyACM2 on the system. I just created symlinks of these to the old-style /dev/ttyUSB0 /dev/ttyUSB1 and /dev/ttyUSB2 and glweb interface recognized it!
Create a file called /etc/init.d/fixericsson with the following content:
#!/bin/sh
for i in 0 1 2
do
if [ -e /dev/ttyACM$i ]; then
if [ ! -h /dev/ttyUSB$i ]; then
ln -s /dev/ttyACM$i /dev/ttyUSB$i
logger -t fixericsson Symlink from /dev/ttyACM$i to /dev/ttyUSB$i created
else
logger -t fixericsson Cannot create symlink because /dev/ttyUSB$i already exists!
fi
else
logger -t fixericsson Theres no ttyACM$i device present, no need to symlink
fi
done
Well, in the glweb interface, the dropdown box still only shows the ttyUSB* options as selectable (which in my case are just symlinks to ttyACM*). It should show both…
