I tried with shipping firmware, beta 3 firmware ( from jan 29 2019 ) and it doesn’t connect to the internet. Tried two sim cards from different operators, one from Vodafone the other from NOS, both without pin code.
They both work perfectly on a tplink mr6400 with no manual setup needed. they simply work.
I tried two different mifi devices ( I ordered two from amazon for a project )
I also tried building my own build from openwrt master and no luck.
on the commandline, logread command allways gives me:
Mon Feb 4 22:09:08 2019 daemon.notice netifd: wwan0 (1347): Network registration failed
Mon Feb 4 22:09:08 2019 daemon.notice netifd: wwan0 (1691): Stopping network wwan0
Mon Feb 4 22:09:08 2019 daemon.notice netifd: wwan0 (1691): Command failed: Permission denied
Mon Feb 4 22:09:08 2019 daemon.notice netifd: Interface ‘wwan0’ is now down
on the latest gl.inet build error is:
Tue Jan 29 11:57:43 2019 daemon.notice netifd: Interface ‘modem_1_1_2’ is now down
Tue Jan 29 11:57:43 2019 daemon.notice netifd: Interface ‘modem_1_1_2’ is setting up now
Tue Jan 29 11:57:46 2019 daemon.notice pppd[20971]: pppd 2.4.7 started by root, uid 0
Tue Jan 29 11:57:47 2019 local2.info chat[20999]: abort on (BUSY)
Tue Jan 29 11:57:47 2019 local2.info chat[20999]: abort on (NO CARRIER)
Tue Jan 29 11:57:47 2019 local2.info chat[20999]: abort on (ERROR)
Tue Jan 29 11:57:47 2019 local2.info chat[20999]: report (CONNECT)
Tue Jan 29 11:57:47 2019 local2.info chat[20999]: timeout set to 10 seconds
Tue Jan 29 11:57:47 2019 local2.info chat[20999]: send (AT+CGDCONT=1,“IP”,“”^M)
Tue Jan 29 11:57:47 2019 local2.info chat[20999]: timeout set to 30 seconds
Tue Jan 29 11:57:47 2019 local2.info chat[20999]: expect (OK)
Tue Jan 29 11:57:47 2019 local2.info chat[20999]: AT+CGDCONT=1,“IP”,“”^M^M
Tue Jan 29 11:57:47 2019 local2.info chat[20999]: ERROR
Tue Jan 29 11:57:47 2019 local2.info chat[20999]: – failed
Tue Jan 29 11:57:47 2019 local2.info chat[20999]: Failed (ERROR)
Tue Jan 29 11:57:47 2019 daemon.err pppd[20971]: Connect script failed
Tue Jan 29 11:57:48 2019 daemon.info pppd[20971]: Exit.
Tue Jan 29 11:57:48 2019 daemon.notice netifd: Interface ‘modem_1_1_2’ is now down
Tue Jan 29 11:57:48 2019 daemon.notice netifd: Interface ‘modem_1_1_2’ is setting up now
Tue Jan 29 11:57:51 2019 daemon.notice pppd[21172]: pppd 2.4.7 started by root, uid 0
Tue Jan 29 11:57:52 2019 local2.info chat[21215]: abort on (BUSY)
Tue Jan 29 11:57:52 2019 local2.info chat[21215]: abort on (NO CARRIER)
Tue Jan 29 11:57:52 2019 local2.info chat[21215]: abort on (ERROR)
Tue Jan 29 11:57:52 2019 local2.info chat[21215]: report (CONNECT)
Tue Jan 29 11:57:52 2019 local2.info chat[21215]: timeout set to 10 seconds
Tue Jan 29 11:57:52 2019 local2.info chat[21215]: send (AT+CGDCONT=1,“IP”,“”^M)
Tue Jan 29 11:57:52 2019 local2.info chat[21215]: timeout set to 30 seconds
Tue Jan 29 11:57:52 2019 local2.info chat[21215]: expect (OK)
Tue Jan 29 11:57:52 2019 local2.info chat[21215]: AT+CGDCONT=1,“IP”,“”^M^M
Tue Jan 29 11:57:52 2019 local2.info chat[21215]: ERROR
Tue Jan 29 11:57:52 2019 local2.info chat[21215]: – failed
Tue Jan 29 11:57:52 2019 local2.info chat[21215]: Failed (ERROR)
Tue Jan 29 11:57:52 2019 daemon.err pppd[21172]: Connect script failed
Tue Jan 29 11:57:53 2019 daemon.info pppd[21172]: Exit.
Tue Jan 29 11:57:54 2019 daemon.notice netifd: Interface ‘modem_1_1_2’ is now down
Tue Jan 29 11:57:54 2019 daemon.notice netifd: Interface ‘modem_1_1_2’ is setting up now
Tue Jan 29 11:57:56 2019 user.notice root: modem delay dial,120s
