So if I purchase the 4g module, it will work with UMTS and LTE or just LTE? Where can I find the band compatibility list for each of the three modules? Are the modules exchangeable later? Can I have two modules (there are two SIM slots)?
You can set it to work with UMTS or LTE.
In the shop pages, if you purchase modules, you will see the detailed specs of the modules and find the band info.
All modules are exchangeable.
Only one module is supported.
This is how it is listed on the site, very confusing:
EC20-E Mini PCIe
FDD LTE: B1/B3/B5/B7/B8/B20
UMTS: B1/B5/B8
GSM: 850/900/1800/1900MHzEC20-A Mini PCIe
FDD LTE: B2/B4/B5/B12/B17
UMTS: B2/B4/B5
GSM: 850/1900MHzEC20-C Mini PCIe
FDD LTE: B1/B3/B8
TDD LTE: B38/B39/B40/B41
TDSCDMA: B34/B39
UMTS: B1/B8
GSM: 900/1800MHz
Does that mean that:
EC20-E Mini PCIe
UMTS: B1/B5/B8
is what is covered by the EC20-E?
EC20-E Mini PCIe
UMTS: B1/B5/B8
So because this device has the WAN/LAN, is it safe to assume that it can also accept a WAN connection instead of the cellular (similar to the other mini-routers)? It will also use cellular as WAN and then output to WAN instead of Wi-Fi? Does it also have WISP repeater mode like the mini-routers?
Also, is it possible for this device to be PoE?
@Jadurrance, the function is exactly the same as other mini routers.
PoE is possible. But it has built-in battery. So why you need PoE. In order to make it have PoE, we need to remove the battery and redesign the case, which seems not going to happen recently.
