Hi Everyone,
I have been running my "Slate" for many years (since July 2019!). I have been running on the latest version of legacy firmware v3.216 without any significant issues. Just recently (this week!) I took the opportunity to purchase a "Flint 2" primarily because of the limited OpenVPN(17Mbps) and WireGuard(68Mbps) performance of the "Slate"!
I am also coalescing the two independent systems ("Slate" as the Edge Router/Firewall & the LinkSys WRT1200AC as the Dual-Band WiFi Access Point) into the one "Flint 2" device...
So, the question I have for you all: Is there any kind of guide or other documented suggestions for making the migration from the "Slate" to the "Flint 2" as easy as possible?
I need to configure multiple 2.4GHz and multiple 5GHz networks with certain existing predefined BSSID's (to enable a seamless transition for some devices), the WiFi networks are currently being provided by the LinkSys WRT1200AC running OpenWRT 23.05.3 r23809.
I also want to dump the full DHCP LAN IP Reservation Table in the "Slate" (I use "dynamically assigned static IP's for many devices and systems on my wired and wireless networks).
I then want to take that dumped data (message it, if necessary) and input it into the "Flint 2" to avoid doing EVERYTHING item by item and/or element by element, manually!!!!
I'd also like to dump and copy over the DYNDNS client daemon configuration...
Does anyone, have any suggestions? At least, does any know which of the system CLI commands (or GUI) that I can use to extract the various pieces of information and data?
Can I created a backup in the advanced menu option in LUCI of the "Slate" and "LinkSys" and use that data to then "somehow" input into the "Flint 2"?
Also, one VERY important desire is to seamlessly migrate both the OpenVPN and WireGuard environments in the "Slate" over to the "Flint", so that, I won't have to reconfigure all of the computer systems and smart devices that use those VPN capabilities now????
In summary I want to essentially dump the state of the "Slate" and "LinkSys" devices, turn them both off, power up the "Flint 2" and use any tools or handcrafted scripts to input all of the combined configuration data into the "Flint 2"!!!! I don't want to have to "touch" any computers nor any devices and once the "Flint 2" is powered back up, ALL of my network is operational with the enhanced speed and capabilities of the new "Flint 2" based Edge Router/Firewall and WiFI Access Point...
Thanks, in advance, for ANY and ALL suggestions and pointers!!!!
