On an MT3000, where can I find the log file for MinDLNA. I cannot seem to find the file anywhere.....???
The default is that there is no minidlna log recorded.
Try adding the following fields through vi /etc/config/minidlna
, to see if any logs are generated:
option log_dir '/tmp/dlna.log'
Thanks. I had tried that with no luck.
I figured out how to run the process in a terminal window so I could watch it as it processed items. Found my issue this way. Thanks for getting back.
