I need to setup a PPTP client connection through my newly bought MT300N-V2.
I’ve installed kmod-nf-nathelper-extra, and noticed that the custom firewall rules make use of it with:
PPTP Passthrough
iptables -t raw -D OUTPUT -p tcp -m tcp --dport 1723 -j CT --helper pptp
iptables -t raw -A OUTPUT -p tcp -m tcp --dport 1723 -j CT --helper pptp
Unfortunately these rules cannot work:
iptables v1.6.2: can’t initialize iptables table `raw’: Table does not exist (do you need to insmod?)
What is missing is kmod-ipt-raw package, which is unfortunately not available.
Is there any solution for this problem? Official support for the module would be wonderful, but also a pointer on how to compile a compatible version on my own will be welcome.
Thanks a lot in advance,
Antonio
