Hello there.
I'm wanting to set up around 10 slate 7s spread out around a building over multiple floors, all hardwired back to a switch.
Using another slate 7 in repeater, client mode, I'm wanting to roam between the 10 access points with seamless handover. I'm streaming low latency IP video via the ‘client’ slate 7 to a decoder hardwired in local network. From what I have read, MLO is a big advantage in this type of use case.
Can I confirm that MLO works while in Repeater/ client mode.
Any settings I should be aware of for seamless roaming handovers?
Does anyone have experience in this type of setup with Wi-Fi 7 MLO?
Many thanks for your time.
Scott
