Mobile app and repeater mode
I have a GL-MT3000 in repeater mode. I also have another GL-MT3000 in access point mode. I’m able to add the access point device into the GLiNet mobile app to “manage” it. When I follow the same process to add the device in repeater mode, I get an error that it cannot find the device. It’s saying it’s offline or blocked. Is there a way to add this so I can see all my devices in the app and if so how? Thanks
hi,
Did you connect the GL-MT3000 in access point mode to that one in repeater mode?Have you try to add new deviced by entering the IP address manually?
Yes I have tried that twice. I reset the entire device in between trying it twice. The repeater has an IP address but when I put in the address the app gives an error that it cannot find it. What else can I try ?
Did you connect the GL-MT3000 in access point mode to that one in repeater mode? Can you access web ui with that IP address with your phone’s browser?
