Modify LAN 5
Hi everyone, I have a flint2 and my main network has ip 192.168.10.0/24.
I created a wireless network with ip 192.168.11.0/24 and everything works.
Now I would like to add to this wireless the LAN port 5 (removing it from 10.0).
How should I proceed?
Thakns
Nobody?
nobody, a few questions:
is this client isolated, does it need access to the internet, what's the configuration on cat /etc/config/network
root@GL-MT6000:~# cat /etc/config/network
config interface 'loopback'
        option device 'lo'
        option proto 'static'
        option ipaddr '127.0.0.1'
        option netmask '255.0.0.0'
config globals 'globals'
        option ula_prefix 'fd9d:8f56:3687::/48'
        option packet_steering '1'
config device
        option name 'br-lan'
        option type 'bridge'
        option macaddr '94:83:c4:a2:b9:96'
        list ports 'lan1'
        list ports 'lan2'
        list ports 'lan3'
        list ports 'lan4'
        list ports 'lan5'
config device
        option name 'lan1'
config device
        option name 'lan2'
config device
        option name 'lan3'
config device
        option name 'lan4'
config device
        option name 'lan5'
config interface 'lan'
        option device 'br-lan'
        option ip6assign '60'
        option isolate '0'
        option ipaddr '192.168.10.254'
config device
        option macaddr '94:83:c4:a2:b9:94'
        option name 'eth1.835'
config interface 'wan'
        option force_link '0'
        option ipv6 '0'
        option classlessroute '0'
        option metric '10'
        option device 'eth1.835'
        option proto 'pppoe'
        option username 'xxxx'
        option password 'xxxx'
config interface 'wan6'
        option proto 'dhcpv6'
        option device '@wan'
        option disabled '1'
config interface 'guest'
        option force_link '1'
        option ipaddr '192.168.9.1'
        option multicast_querier '1'
        option igmp_snooping '0'
        option isolate '0'
        option bridge_empty '1'
        option disabled '0'
config rule 'policy_relay_lo_rt_lan'
        option lookup '16800'
        option in 'loopback'
        option priority '1'
config interface 'tethering6'
        option device '@tethering'
        option disabled '1'
config interface 'wwan6'
        option device '@wwan'
        option disabled '1'
config interface 'wwan'
        option proto 'dhcp'
        option metric '20'
config interface 'secondwan'
        option ipv6 '0'
        option proto 'dhcp'
        option metric '15'
config interface 'secondwan6'
        option device '@secondwan'
        option disabled '1'
        option metric '15'
config rule 'policy_direct_rt'
        option lookup 'main'
        option suppress_prefixlength '0'
        option priority '1100'
config rule 'policy_default_rt_vpn'
        option mark '0x8000/0xc000'
        option lookup '8000'
        option priority '1101'
        option invert '1'
config rule6 'policy_direct_rt6'
config rule6 'policy_default_rt_vpn6'
        option invert '1'
config rule 'policy_default_rt_vpn_ts'
        option priority '1099'
        option mark '0x80000/0xc0000'
        option invert '0'
config interface 'wgserver'
        option proto 'wgserver'
        option config 'main_server'
        option disabled '0'
config interface 'iot'
        option device 'br-iot'
        option ipaddr '192.168.11.254'
config device
        option name 'br-iot'
config interface 'ont'
        option device 'eth1'
        option ipaddr '192.168.1.2'
root@GL-MT6000:~#
Clients on the 11.0 network need to access the internet but they do not need to access the 10.0 network. From the 10.0 network I can access the 11.0 network
