I am trying to use mosquitto_pub/sub in domino pi.
I installed libmosquitto, mosquitto and mosquitto_client using web interface (domino.local)
When I am running the command it is telling
Error: Connection refused
what can be wrong ?
can you give a little more details of how you run the command? I may have a try.
ok.
for subscribing
mosquitto_pub -t TOPIC_NAME
for publishing to the topic
mosquitto_pub -t TOPIC_NAME -m "MESSAGE"
This 2 commands are enough for running mosquitto basic.
you can even directly run the above commands exactly as-is.
but it is giving error.
EDIT: while submitting only “mosquitto” for starting the broker, it is saying
1442508626: Error: Invalid user 'mosquitto'.
you can ask more questions if required.
Hi I found a >> solution << given by WeIO
Saved your time alzhao
anyways thanks, will ask more questions in future
can you pls post your solutions here. Thanks.
I kept >> and << because it is not showing links with different color or underline.
you can click on solution.
Which will take you to http://www.nodesignlab.net/weio/installing-mosquitto-server-and-configuring/
