Mosquitto Usr/Passwd Login broken after Systemupdate
Hi Forum,
I use the GL-AXT1800. Last week there was an update (4.7.0 Release 8 / OpenWrt 23.05-SNAPSHOT r23485+111-e92cf0c46f) to what I install. After the update, I have problems with my MQTT Broker. Before the update, the broker works perfect as well with user and password for the MQTT clients. After the update the broker works only with anonymous=true. But this only when I set this option via the LUCI Mosquitto configuration page. When I decide to don't use the LUCI configuration page, I modify the /etc/mosquitto/mosquitto.conf. But I can change what I want in /etc/mosquitto/mosquitto.conf it has no effect. It looks like that these config-file isn't used. Then I try to change the config from the LUCI configuration. But here it is not possible to make user/password persistent.
Yes, I have made the passwd file with mosquitto-password and I use the right directory. Also, a complete reinstallation of mosquitto makes no change.
Is there someone how can help about my problem?
Thanks in front.
This seems to be a mosquitto problem. Is there any related log?
Or consult with mosquitto technical support team and maybe solve your problem faster.
The only change is that after AXT18000 has been upgraded from v4.6.8 to v4.7.0, the mosquitto plug-in version may also be updated.
Hmm, maybe there is anywhere a log, but I'll don't know where. Also, I don't think that is a mosquitto problem. As I know, the mosquitto version isn't changed. At the LUCI configuration page is an option that the hock at this point decide that the LUCI or the original config-file is used. I think that the link to the original config file is wrong. And this is first happened after the System update.
You need to manually backup all config files and upload them again after each sysupdate or put
/etc/mosquitto/
into /etc/sysupgrade.conf file to keep the configs or theyre wiped out after upgrade even if you tick "keep settings".
/etc/mosquitto/mosquitto.conf needs to hold these parameters:
password_file /etc/mosquitto/passwords.txt
allow_anonymous false
I understand your decription. But this is not the problem. I tried anything, also to deinstall and reinstall mosquitto. Then I make the changes in the /etc/mosquitto/mosquitto.conf (listener=1883, anonymous= false and passwd =/etc/mosquitto/user) . Restart mosquitto Service and mosquitto bat it seems that the mosquitto.conf isn't used at all.
Mine works normally. Maybe look into the startup script for mosquitto in /etc/init.d if there it says to use /etc/mosquitto/mosquitto.conf or look with htop if it shows the process if it says something in the task line if it shows the conf file
I've checked all Mosquitto (.conf) files. In /etc/mosquitto/mosquitto.conf (listener=1883, anonymous= false and passwd =/etc/mosquitto/user) is set with the right filename. This file isn't used. Then I have checked /etc/init.d. I am not so experienced in the scipt-language but what I see is this:
#!/bin/sh /etc/rc.common
# Basic init script for mosquitto
# April 2012, OpenWrt.org
# Provides support for the luci-app-mosquitto package, if installed
START=80
USE_PROCD=1
TCONF=/tmp/mosquitto.generated.conf
# CONF_WATCH=/etc/config/mosquitto
CONF_WATCH=/etc/mosquitto/mosquitto.conf
# Usage: append_if cfg uci_name output_name
# add a config line of the form "output_name <value>"
# if the "uci_name" was found.
# output_name defaults to uci_name if not specified.
append_if() {
    local cfg="$1"
    local uci_name="$2"
    local out_name="$3"
    if [ -z "$out_name" ]; then
        out_name=$uci_name
    fi
    config_get val $cfg $uci_name
    if [ -n "$val" ]; then
        echo "$out_name $val" >> $TCONF
    fi
# mosquitto uses true/false, uci uses 1/0
# note that this is not shell truthy, but equality with 1!
append_bool() {
    if [ $2 -eq 1 ]; then
        echo "$1 true" >> $TCONF
    else
#        echo "$1 false" >> $TCONF
	echo "$1 false" >> $CONF_WATCH
    fi
# as per append_if, but gets the value as a uci bool, not raw
append_optional_bool() {
    local cfg="$1"
    local uci_name="$2"
    local out_name="$3"
        out_name=$uci_name
    fi
        config_get_bool real $cfg $uci_name
        append_bool $out_name $real
    fi
convert_mosq_general() {
	local cfg="$1"
	config_get destinations "$1" log_dest
	for dest in $destinations; do
		echo "log_dest $dest" >> $TCONF
	done
	config_get_bool no_remote "$1" no_remote_access 0
	if [ "$no_remote" -eq 1 ]; then
		echo "bind_address localhost" >> $TCONF
	fi
	append_if "$1" port
	# per listener settings must be set before any potential security settings
	append_optional_bool "$1" per_listener_settings
	append_if "$1" acl_file
	append_optional_bool "$1" allow_anonymous
	append_optional_bool "$1" allow_duplicate_messages
	append_if "$1" clientid_prefixes
	append_optional_bool "$1" connection_messages
	append_if "$1" include_dir
	append_if "$1" log_facility
	append_optional_bool "$1" log_timestamp
	config_get log_types "$1" log_types
	for log_type in $log_types; do
		echo "log_type $log_type" >> $TCONF
	done
	append_if "$1" max_inflight_bytes
	append_if "$1" max_inflight_messages
	append_if "$1" max_queued_bytes
	append_if "$1" max_queued_messages
	append_if "$1" message_size_limit
	append_if "$1" password_file
	append_if "$1" pid_file
	append_if "$1" psk_file
	append_optional_bool "$1" queue_qos0_messages
	append_optional_bool "$1" retain_available
	append_optional_bool "$1" set_tcp_nodelay
	append_if "$1" protocol
	append_if "$1" sys_interval
	append_optional_bool "$1" upgrade_outgoing_qos
	append_if "$1" user
	append_if "$1" websockets_log_level
	append_if "$1" websockets_headers_size
	# can be general or per listener, see per_listener_settings
	append_if "$1" auth_plugin
	# Careful, this relies on internal behaviour of the cfg_load functions!
	set | grep "CONFIG_$1_auth_opt_" | sed "s/^.*_\(auth_opt_.*\)='\(.*\)'/\1 \2/" >> $TCONF
convert_persistence() {
	local cfg="$1"
	append_if "$cfg" client_expiration persistent_client_expiration
	append_if "$cfg" autosave_interval
	append_optional_bool "$cfg" autosave_on_changes
	append_optional_bool "$cfg" persistence
	append_if "$cfg" file persistence_file
	append_if "$cfg" store_clean_interval
	config_get loc "$cfg" location
	if [ -n "$loc" ]; then
		[ -d "$loc" ] || {
			mkdir -p "$loc";
			chown mosquitto "$loc";
		echo "persistence_location $loc" >> $TCONF
	fi
add_listener() {
    echo "" >> $TCONF
    config_get port "$1" port
    if [ -z "$port" ]; then
        echo "Ignoring listener section without port"
        return
    fi
    # "no_remote" is a non-standard shortcut option
    local bind_address=""
    [ "$no_remote" -eq 1 ] && bind_address="127.0.0.1"
    config_get bind_address "$1" bind_address $bind_address
    echo "listener $port $bind_address" >> $TCONF
    append_if "$1" http_dir
    append_if "$1" max_connections
    append_if "$1" max_qos
    append_if "$1" max_topic_alias
    append_if "$1" mount_point
    append_if "$1" socket_domain
    append_optional_bool "$1" use_username_as_clientid
    append_if "$1" cafile
    append_if "$1" capath
    append_if "$1" certfile
    append_if "$1" ciphers
    append_if "$1" ciphers_tls1.3
    append_if "$1" crlfile
    append_if "$1" dhparamfile
    append_if "$1" keyfile
    append_optional_bool "$1" require_certificate
    append_if "$1" tls_engine
    append_if "$1" tls_engine_kpass_sha1
    append_if "$1" tls_keyform
    append_if "$1" tls_version
    append_optional_bool "$1" use_identity_as_username
    append_optional_bool "$1" use_subject_as_username
    append_if "$1" psk_hint
add_topic() {
    echo "topic $1" >> $TCONF
add_bridge() {
    config_get conn "$1" connection
    config_get addr "$1" address
    if [ -z "$conn" -o -z "$addr" ]; then
        echo "Ignoring bridge section with missing connection/address"
        return
    fi
    # Also invalid if no topics are defined, mosquitto will not start!
    config_get tlen "$1" "topic_LENGTH"
    if [ -z "$tlen" ]; then
        echo "Ignoring bridge section with no topics defined"
        return
    fi
    echo "" >> $TCONF
    echo "# Bridge connection from UCI section" >> $TCONF
    append_if "$1" connection
    append_if "$1" address
    append_optional_bool "$1" attempt_unsubscribe bridge_attempt_unsubscribe
    append_if "$1" bind_address bridge_bind_address
    append_if "$1" max_packet_size bridge_max_packet_size
    append_optional_bool "$1" outgoing_retain bridge_outgoing_retain
    append_if "$1" protocol_version bridge_protocol_version
    append_optional_bool "$1" cleansession
    append_optional_bool "$1" local_cleansession
    append_if "$1" keepalive_interval
    append_if "$1" idle_timeout
    append_if "$1" local_clientid
    append_if "$1" local_password
    append_if "$1" local_username
    append_optional_bool "$1" notifications
    append_optional_bool "$1" notifications_local_only
    append_if "$1" notification_topic
    # Note, deprecated upstream, preserve old uci configs
    append_if "$1" clientid remote_clientid
    append_if "$1" remote_clientid
    append_if "$1" password remote_password
    append_if "$1" remote_password
    append_if "$1" username remote_username
    append_if "$1" remote_username
    append_if "$1" restart_timeout
    append_optional_bool "$1" round_robin
    append_if "$1" start_type
    append_if "$1" threshold
    config_list_foreach "$1" topic add_topic
    append_optional_bool "$1" try_private
    append_if "$1" alpn bridge_alpn
    append_if "$1" cafile bridge_cafile
    append_if "$1" capath bridge_capath
    append_if "$1" certfile bridge_certfile
    append_if "$1" identity bridge_identity
    append_optional_bool "$1" insecure bridge_insecure
    append_if "$1" keyfile bridge_keyfile
    append_if "$1" psk bridge_psk
    append_optional_bool "$1" require_ocsp bridge_require_ocsp
    append_if "$1" tls_version bridge_tls_version
convert_uci() {
	rm -rf $TCONF
	echo "Generating mosquitto config file in $TCONF"
	echo "# mosquitto.conf file generated from UCI config." >>$TCONF
	# Don't include a timestamp, it makes md5sum compares fail
	config_load mosquitto
	config_foreach convert_mosq_general "mosquitto"
	config_foreach convert_persistence "persistence"
	config_foreach add_listener "listener"
	config_foreach add_bridge "bridge"
start_service_real() {
	local cfg="$1"
	local use_uci write_pid
	config_get use_uci "$cfg" use_uci
	if [ "$use_uci" -eq 1 ]; then
		CONF=$TCONF
		convert_uci
	else
		CONF=/etc/mosquitto/mosquitto.conf
		CONF_WATCH=$CONF
        fi
	config_get write_pid "$cfg" write_pid 0
	procd_open_instance
	procd_set_param command mosquitto
	procd_append_param command -c $CONF
	# Makes /etc/init.d/mosquitto reload work if you edit the final file.
	procd_set_param file $CONF_WATCH
	[ "$write_pid" -eq 1 ] && procd_set_param pidfile /var/run/mosquitto.pid
	procd_set_param respawn
	procd_close_instance
start_service() {
	config_foreach start_service_real owrt
service_triggers() {
	# Makes "reload_config" work
	procd_add_reload_trigger "mosquitto"
I have changed the Line
to CONF_WATCH=/etc/mosquitto/mosquitto.conf
and
to echo "$1 false" >> $CONF_WATCH
But I think, this was not the right change to make the config working. Can you help where the mistake is?
