I’ve been using the MT-1300 for only a few weeks as a repeater, but all of a sudden it just refuses to connect to the wifi that it was previously using, but other devices are able to connect to the same wifi
I have tried rebooting the router as well as reverting it back to factory settings, but that also didn’t work. I then tried to set up the router as a repeater using my mobile hotspot, which did work
I ssh’d to the router and checked the logs, and I am getting the results below, but they don’t really clue me in on what is going on
Fri Apr 2 12:36:13 2021 user.info : saved ssid ignore: wifi_name 0
Fri Apr 2 12:36:13 2021 user.info : [ 810] gl-sdk>> bIsSaved=0, ssid=wifi_name, encryption=psk2, bssid=18:02:2D:2E:48:20, wds=0, device=mt7615e2, identity=, channel=4
Fri Apr 2 12:36:13 2021 user.notice apcli: apclix0 down
Fri Apr 2 12:36:13 2021 daemon.notice netifd: wwan (31699): udhcpc: received SIGTERM
Fri Apr 2 12:36:13 2021 daemon.notice netifd: Network device 'apclix0' link is down
Fri Apr 2 12:36:13 2021 daemon.notice netifd: Interface 'wwan' has link connectivity loss
Fri Apr 2 12:36:13 2021 daemon.notice netifd: Interface 'wwan' is now down
Fri Apr 2 12:36:13 2021 daemon.notice netifd: Interface 'wwan' is disabled
Fri Apr 2 12:36:13 2021 daemon.notice netifd: Network device 'apclix0' link is up
Fri Apr 2 12:36:13 2021 user.info : [ 2960] gl-wifi-core>> bIsStaEnabled=1
Fri Apr 2 12:36:18 2021 daemon.notice netifd: Interface 'wwan' is enabled
Fri Apr 2 12:36:18 2021 daemon.notice netifd: Interface 'wwan' is setting up now
Fri Apr 2 12:36:19 2021 daemon.notice netifd: wwan (11946): udhcpc: started, v1.30.1
Fri Apr 2 12:36:19 2021 user.info : [ 817] gl-sdk>> wifi_join return=0, channel=-1
Fri Apr 2 12:36:19 2021 daemon.notice netifd: wwan (11946): udhcpc: sending discover
Fri Apr 2 12:36:19 2021 user.notice apcli: apclix0 down
Fri Apr 2 12:36:19 2021 daemon.notice netifd: Network device 'apclix0' link is down
Fri Apr 2 12:36:19 2021 daemon.notice netifd: Interface 'wwan' has link connectivity loss
Fri Apr 2 12:36:19 2021 daemon.info dnsmasq-dhcp[2420]: DHCPREQUEST(br-lan) 192.168.8.203 3c:22:fb:43:28:89
Fri Apr 2 12:36:19 2021 daemon.info dnsmasq-dhcp[2420]: DHCPACK(br-lan) 192.168.8.203 3c:22:fb:43:28:89 Laptop
Any help would be appreciated as I am not able to work properly with these issues
