MT-1300, IPv6 and VPN
I am trying to resolve an issue on on my WAN Ethernet port on this router.
I wanted to try turning on IPv6 and see if that does anything to my issue.
But, the following warning is on the IPv6 page:
"Note: If you use functions of both VPN and IPv6 at the same time, it’s likely to cause IPv6 data leakage. "
I use a Wireguard VPN from my computer, that is connected to the M-1300. I do not use the VPN services of the router itself.
Am I at risk in this scenario? Or is this warning message only applicable to using the VPN and IPv6 directly on the MT-1300?
Thank you.
No risk. incoming traffic is blocked.
Similar topic here:
