MT-3000 configured as WireGuard client hanging on "The client is starting, please wait…"
I just set up two Beryl AX’s (GL-MT3000), one that will be connected to my ISP (HOME) and one I will travel with (AWAY). I’ve loaded the configuration file from the HOME on to the AWAY but when I turn it on it hangs on “The client is starting, please wait…”
Including my configuration settings as well as the log from the hanging connection below. Can someone take a look and let me know what might be the issue? Thanks.
Configuration Settings:
[Interface]
Address = 10.0.0.2/24
PrivateKey = XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX=
DNS = 64.6.64.6
MTU = 1420
[Peer]
AllowedIPs = 0.0.0.0/0,::/0
Endpoint = 172.XXX.XX.232:51820
PersistentKeepalive = 25
PublicKey = XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX=
Log:
Fri Nov 10 11:42:49 2023 daemon.notice netifd: wgclient (23430): * Rule ‘out_conn_mark_restore’
Fri Nov 10 11:42:49 2023 daemon.notice netifd: wgclient (23430): * Zone ‘lan’
Fri Nov 10 11:42:49 2023 daemon.notice netifd: wgclient (23430): * Zone ‘wan’
Fri Nov 10 11:42:49 2023 daemon.notice netifd: wgclient (23430): * Zone ‘guest’
Fri Nov 10 11:42:49 2023 daemon.notice netifd: wgclient (23430): * Zone ‘wgclient’
Fri Nov 10 11:42:49 2023 daemon.notice netifd: wgclient (23430): * Set tcp_ecn to off
Fri Nov 10 11:42:49 2023 daemon.notice netifd: wgclient (23430): * Set tcp_syncookies to on
Fri Nov 10 11:42:49 2023 daemon.notice netifd: wgclient (23430): * Set tcp_window_scaling to on
Fri Nov 10 11:42:49 2023 daemon.notice netifd: wgclient (23430): * Running script ‘/etc/firewall.nat6’
Fri Nov 10 11:42:49 2023 daemon.notice netifd: wgclient (23430): * Running script ‘/etc/firewall.swap_wan_in_conn_mark.sh’
Fri Nov 10 11:42:49 2023 daemon.notice netifd: wgclient (23430): * Running script ‘/etc/firewall.vpn_server_policy.sh’
Fri Nov 10 11:42:49 2023 daemon.notice netifd: wgclient (23430): * Running script ‘/var/etc/gls2s.include’
Fri Nov 10 11:42:49 2023 daemon.notice netifd: wgclient (23430): ! Skipping due to path error: No such file or directory
Fri Nov 10 11:42:49 2023 daemon.notice netifd: wgclient (23430): * Running script ‘/usr/bin/gl_block.sh’
Fri Nov 10 11:42:49 2023 daemon.notice netifd: wgclient (23430): uci: Entry not found
Fri Nov 10 11:42:49 2023 daemon.notice netifd: wgclient (23430): cat: can’t open ‘/tmp/run/wg_resolved_ip’: No such file or directory
Fri Nov 10 11:42:49 2023 daemon.notice netifd: Interface ‘wgclient’ is now down
Fri Nov 10 11:42:49 2023 daemon.notice netifd: Interface ‘wgclient’ is setting up now
Fri Nov 10 11:42:49 2023 user.notice mwan3[23613]: Execute ifdown event on interface wgclient (unknown)
Fri Nov 10 11:42:50 2023 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Is the port for WG open on your home router?
s/router/modem/g
… & inb4 CGNAT.
