MT-3000 was running great, connecting to WG server, until today. Nothing has changed but now it won't connect anymore. Here is the Log:
Connection Log
Wed Aug 27 22:33.38 2025 daemon warn
dnsmasq[7553]: O servers found in /tmp/
resolv.conf.d/resolv.conf.wgclient1, will retry
Wed Aug 27 22:33:38 2025 daemon.info
insmasq[7553]: read /tmp/hosts/
dhcp.wgclient1 -3 addresses
dnsmasq[7554]: read /tmp/hosts/
hcp.wgclient1-3 addresses
Wed Aug 21 22:33:40 2025 daemon.warn
dnsmasq[8529]: no servers found in /tmp/
C
Wed Aug '2 21 22:33:40 2025 daemon.info
dnsmasq[8529]: read /tmp/hosts/
dhcp.wgclient1-3 addresses
Wed Aug 27 22:33:40 2025 daemon info
dnsmasq[8528]: read /tmp/hosts/
Wed Aug 27 22.33:46 2025 daemon.notice
procd: /etc/rc.d/S95vpn-client: Found
matching instance wgclient1 for rule peer:
2002
Wed Aug 27 22:33:46 2025 daemon.notice
procd: /etc/rc.d/S95vpn-client: Starting
instance wgclient1 (has enabled rules)
Wed Aug 27 22:33:48 2025 daemon.warn
I am still able to connect to the WG server from my mobile phone and laptop but MT-3000 won't connect anymore.
I have noticed new update pending, installed it (now it is 4.8.1), rebooted router and still cannot connect.
Can you please help me to get back the VPN functionality?
Have you tried removing and re-creating the WG VPN profiles on the router? I found on mine the Openvpn profiles were no longer working after I had upgraded the firmware, the token value had been wiped out and clicking update appeared to work (no error) but hadn't. Not the same VPN client but you could also try using a profile from the glinet app alternatively, but it should work from the router itself using the credentials/key you entered and generated.
I have no access to the server - if I delete the existing configuration I won't be able to connect and re-create new WG VPN profile.
I have tried copying WG config file from my phone (which connects with no issue), but MT-3000 still won't connect.
Both Client (GL-MT3000) and Server (GL-AR300M) have time synchronized successfully.
There is the time zone difference, but both devices are synchronized according to their location.
