Hi, i own 2 of MT300A devices. I just wanted to setup one as NAS.
Configuration is: MT300a (FW 2.264 or 3 beta) with connected 4 BAY USB housing (FANTEC)
In Windows Explorer only 2 disks are visible of 4 installed. Their Filesystem is NTFS or exFat (both addons installed and both filesystems are visible in Explorer but only 2 of 4 disks.
config sambashare
option name ‘1TB’ <<< drive 1 NTFS visible in Windows
option path ‘/mnt/1TB’
option read_only ‘yes’
option guest_ok ‘yes’
config sambashare
option name ‘Basic data partition’ <<< drive 2 exFAT visible in Windows
option path ‘/mnt/Basic data partition’
partly solved:
Checked the drives with mini tool partition wizard. 2 of 4 are GPT set. - one of those (5TB) is found by MT300A but has no content in explorer.
The other 2 drived are MBR now (1 and 2 TB) I converted the 2TB to MBR.
The 4th drive is 4TB GPT exFAT - still not mounted. Was unable to change to MBR because of size.
Issue while trying to mount: The device ‘/dev/sda2’ doesn’t seem to have a valid NTFS.
So far, many thanks to you alzhao! Its nice to see a manufacturer that delivers that support today - again: Thumbs up!
