Hi all,
is the uboot procedure for V2 not the same for V1 or ARM ?
I try to power-on my new MT300N-V2 with reset button pushed but, after 4 blink of red led, the other 2 green led remain light on and I’m not able to open web page of uboot.
I correctly set my PC NIC with 192.168.1.2/24 and I’ve tested this procedure more time with success on my AR150 and MT300A.
Another dubt is aboutExternal antennas:
In the short guide included in the box: “Do NOT use any external antennas”
In the Product spec tab on website GL-Inet (https://www.gl-inet.com/products/gl-mt300n-v2/) is reported:
External antennas support: YES
So, I’m a little bit confused…
