MT-6000 client_loop: send disconnect: Broken pipe
since today, when trying to ssh into my MT-6000, I get after a few seconds the message : client_loop: send disconnect: Broken pipe
Then the connection is lost and I get logged out.
I'm using the latest Firmware 4.7.4 rel.6
Is there a solution for this rare behaviour?
Greetings Tom
  1. Please check if there is an IP conflict of the PC?
  2. If the PC CMD long ping the router IP ping 192.168.8.1 -t, will there be packet loss?
  3. When the SSH connection is lost/logout, can you reconnect again at that moment?
  4. Please try to install others GL firmware like v4.7.0 to see if the issue occurs again?
thank you for your reply.
I've flashed the router again and the problem was gone.
Sorry for not closing this item.
greetings Tom
