I’ve been running through testing the 3.2.11 betas and all three have had the same issue. File Sharing appears to install successfully but never get the option to apply. In order to get it functioning correctly, I have had to install a separate pkg.
Gl-files-brower has to manually be installed in order for everything to work as expected.
On a good note, my hotspot connection issues have been corrected with beta 3.
I am able to install the package under plug-ins, however, it should install correctly as it has done in past versions. This was more to let the group know that this is still an issue in Beta3 so they have time to correct it.
