my MT1300 connect PC by LAN, it will reboot everytime when my BT traffic up to ~400Mbps.
Anyone has similar problem ???
Can you check in your MT1300, do you have real time data statistics enabled. If yes, disable it and try.
already disable before.
Seems the firmware ver 3.201 + luci has bug and unsatble.
I have reverted to factory ver 3.200 and no reboot since then, stable now.
I filed an bug internal to investigate.
