I purchased a Brume 2 in January to replace my APU2, but have had issues with the 2.5Gbit port getting bad packet loss. I've tried updating U-Boot with the critical fix but this hasn't appeared to have improved anything.
It looks like there is now a new revision of the Brume 2 with a different Ethernet PHY, do you know if this is to resolve the issue I am having?
One data point that is interesting is the device will work with no packet loss and then as the internal temperature sensor reports around 40C the loss will return.
I have only been running OpenWrt 24.10.0-rc5 then 24.10.1, so I am not sure if it occurs on the GL.iNet supplied firmware.
Other than this issue (which to be honest makes the device unusable) I am very happy with the form factor and power efficiency of the MT2500A, so it would be a shame to have to retire it.
Where have you seen this? There are two models of the Brume 2 and the only difference is the casing, one plastic and the other is metal (A model) no internal differences.
I am using Firmware version 4.7.4 official glinet firmware along with the latest uboot fix and all is fine here. I have the plastic model.
Thanks for your reply, unfortunately I have already tried setting the link speed as part of my troubleshooting process. There's also no link up/down messages logged in the syslog.
