Mt300 connect to fortigate with vpn
hi all, I would like know if it is possible to connect to fortigate vpn with GL MT300
many thanks in advance
best regards
Out-of-the-box like the Forticlient → no.
Depends on the technology the Forti uses.
SSLVPN should be just OpenVPN. IPSec is IPsec as well - and configuring it is pain in the ass.
there is no the possibility to install openfortivpn package for OpenWRT on glinet?
best regards
Not with just a single click, no.
You could try to build it yourself from the source code - but if this works or how to do so is behind my knowledge and I would not recommend it - because since you asked about it, it’s behind your knowledge as well :smile:
