Hi Guys!
I have a strange problem.
Bought a new GL-MT3000.
I try to connect to a 2.4Ghz WPA-PSK secured Wifi (Channel 1).
The thing is, connection fails.
The Log is full of the following error:
[ 1001.524033] 7981@C13L1,sta_join_peer_response_matched() 993: RSN IE VALIDATE FAIL
I already updated to the newest firmware, even beta one, no luck.
I also disabled the mac randomize feature and used the real one.
What i need is BSSID Binding, but that shouldn't be an issue.
Also tried via Luci Interface...again without any luck.
Disabled all the other Default 2.4Ghz Wifi Network, nope...
Also looked around in this forum but couldn't find anything.
Any help is appreciated.
I also have a gl-ar750 which works like a charm with that exact same Network.
I can still return the device, if it is too buggy...
