MT300A - DHCP Issue
Hi All,
I’m testing my firmware built from the GLI repo and I face some issue :
  • the wan get it’s ip address, gateway and dnses addresses from our internal dhcp server. ok
  • the wlan get it’s ip address from the router dhcp server. ok
however the eth0.1 can’t get any ip address. I need to force my laptop to be on 192.168.1.20 to access the router.
Thanks
eth0.1 is the LAN. You need to set a static IP, right?
Yes you are right eth0.1 is the LAN.
I don’t want to set a static IP address as I expected like the wlan0 to get an IP from the router DHCP server.
Thanks.
Hi All,
Some feedback.
  • Tested with the GLI firmware 2.24, no trouble on dhcp on both lan and wlan
  • Tested with my own compiled version, see the.config here attached, no trouble on dhcp on both lan and wlan
  • However as I tried to build an appropriate firmware for radiusdesk, http://radiusdesk.com/docuwiki/user_guide/md_on_lede
In this configuration wlan gives me an IP address while eth0.1 doesn’t. I need to investigate on the radiusdesk setup side.
Thanks
