I recently updated from 2.264 to 3.026. The new web interface is much better than before! But one thing that isn’t quite working for me anymore is the SD card. Other devices can see a folder named ‘data’ when access the network, work upon trying to open ‘data’, I get a message that the network name can’t be found. Plugging in a USB works perfectly fine.
When I ssh into the router and do ‘df’ I get the following:
Filesystem 1K-blocks Used Available Use% Mounted on /dev/root 10496 10496 0 100% /rom tmpfs 62504 696 61808 1% /tmp /dev/mtdblock6 3968 860 3108 22% /overlay overlayfs:/overlay 3968 860 3108 22% / tmpfs 512 0 512 0% /dev /dev/mmcblk0p1 15650812 23800 15627012 0% /mnt/SD
So I would be expecting the SD card contents to show up in a folder called ‘SD’
As for system logs, I assume the relevant bits are:
Mon Aug 19 12:19:54 2019 kern.info kernel: [ 7.877535] mmc0: new high speed SDHC card at address 0007
Mon Aug 19 12:19:54 2019 kern.info kernel: [ 7.887547] mmcblk0: mmc0:0007 2&DRP 14.9 GiB
Mon Aug 19 12:19:54 2019 kern.info kernel: [ 7.900718] mmcblk0: p1
Mon Aug 19 12:20:05 2019 daemon.notice ntfs-3g[1473]: Mounted /dev/mmcblk0p1 (Read-Write, label “SD”, NTFS 1.2)
Mon Aug 19 12:20:05 2019 daemon.notice ntfs-3g[1473]: Cmdline options: utf8
Mon Aug 19 12:20:05 2019 daemon.notice ntfs-3g[1473]: Mount options: utf8,allow_other,nonempty,relatime,fsname=/dev/mmcblk0p1,blkdev,blksize=4096
Mon Aug 19 12:20:05 2019 daemon.notice ntfs-3g[1473]: Ownership and permissions disabled, configuration type 1
(I tried posting the whole log but it went over the character count; if necessary I will post the entire log in the comments)
Also, there is an empty folder in /mnt called ‘data’, which I assume is related to the folder my devices are seeing. Any ideas as to why the SD card can’t been seen/ accessed? The SD card is formatted as NTFS.
Also, was the 2.264 firmware taken down for the MT300A? I cannot seem to find it at GL.iNet download center
