MT300N - Connect to industrial Ethernet network using Wifi
Networking noob here,
I’ve searched through the forums and haven’t been able to find a clear answer.
I have a GT-MT300N that I’d like to be able to plug into an unmanaged switch, and connect to the LAN using WiFi. It’d be an added bonus if I could configure the WAN and LAN port to act as a switch that I could WiFi into. This would save me heaps of time when programming devices connected together without a switch. If someone could point me into the right direction it would be greatly appreciated!
If my understanding your use case is correct, then you can set up the GL-MT300N in Access Point mode.
