I have my Pixel EasyTethered to a MT300N via USB port for internet. Everything connects and wifi works well on MT300N. My only issue is that neither the LAN or WAN ports work when I have phone Easytethered to MT300N. I would like to connect my PC directly via Ethernet or connect a more powerful Wifi router via Ethernet to the LAN port. Also, I switched the WAN port to LAN via Admin Panel, but still neither port is live nor are there any lights showing activity or connectivity.
So the pc does not detect cable when connected to LAN or cannot get IP address?
The PC seems to be detect the connection but there is no data (internet), do I need to disable the wifi for the ethernet to ports to work?
Not need.
Can you give more details like output of the following
ifconfig
logread
I’m not sure where to get those outputs?
ssh to the router and execute the command.
br-lan Link encap:Ethernet HWaddr 94:83:C4:05:B7:9C
inet addr:192.168.7.1 Bcast:192.168.7.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:12672 errors:0 dropped:0 overruns:0 frame:0
TX packets:8138 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:1281460 (1.2 MiB) TX bytes:3760410 (3.5 MiB)
eth0 Link encap:Ethernet HWaddr 94:83:C4:05:B7:9C
inet6 addr: fe80::9683:c4ff:fe05:b79c/64 Scope:Link
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:5542 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:655818 (640.4 KiB)
Interrupt:5
eth0.1 Link encap:Ethernet HWaddr 94:83:C4:05:B7:9C
TX packets:5528 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:631321 (616.5 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:1526 errors:0 dropped:0 overruns:0 frame:0
TX packets:1526 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:102832 (100.4 KiB) TX bytes:102832 (100.4 KiB)
ra0 Link encap:Ethernet HWaddr 94:83:C4:05:B7:9C
RX packets:14702 errors:0 dropped:0 overruns:0 frame:0
TX packets:8416 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1943793 (1.8 MiB) TX bytes:3644078 (3.4 MiB)
Interrupt:6
tap-easytether Link encap:Ethernet HWaddr 02:00:54:74:68:72
inet addr:192.168.117.2 Bcast:192.168.117.255 Mask:255.255.255.0
RX packets:1054 errors:0 dropped:0 overruns:0 frame:0
TX packets:940 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:785200 (766.7 KiB) TX bytes:159230 (155.4 KiB)
Logread (1/2)
Sun Oct 25 14:58:46 2020 kern.notice kernel: [ 0.000000] Linux version 4.14.63 (cc@cc-ubuntu1604) (gcc version 7.3.0 (OpenWrt GCC 7.3.0 r7258-5eb055306f)) #0 Thu Aug 16 07:51:15 2018
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.000000] Board has DDR2
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.000000] Analog PMU set to hw control
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.000000] Digital PMU set to hw control
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.000000] SoC Type: MediaTek MT7628AN ver:1 eco:2
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.000000] bootconsole [early0] enabled
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.000000] CPU0 revision is: 00019655 (MIPS 24KEc)
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.000000] MIPS: machine is GL-MT300N-V2
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.000000] Determined physical RAM map:
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.000000] memory: 08000000 @ 00000000 (usable)
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.000000] Initrd not found or empty - disabling initrd
Sun Oct 25 14:58:46 2020 kern.warn kernel: [ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
Sun Oct 25 14:58:46 2020 kern.warn kernel: [ 0.000000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.000000] Zone ranges:
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.000000] Normal [mem 0x0000000000000000-0x0000000007ffffff]
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.000000] Movable zone start for each node
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.000000] Early memory node ranges
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.000000] node 0: [mem 0x0000000000000000-0x0000000007ffffff]
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000007ffffff]
Sun Oct 25 14:58:46 2020 kern.debug kernel: [ 0.000000] On node 0 totalpages: 32768
Sun Oct 25 14:58:46 2020 kern.debug kernel: [ 0.000000] free_area_init_node: node 0, pgdat 8047cf70, node_mem_map 81000040
Sun Oct 25 14:58:46 2020 kern.debug kernel: [ 0.000000] Normal zone: 256 pages used for memmap
Sun Oct 25 14:58:46 2020 kern.debug kernel: [ 0.000000] Normal zone: 0 pages reserved
Sun Oct 25 14:58:46 2020 kern.debug kernel: [ 0.000000] Normal zone: 32768 pages, LIFO batch:7
Sun Oct 25 14:58:46 2020 kern.notice kernel: [ 0.000000] random: get_random_bytes called from start_kernel+0x8c/0x47c with crng_init=0
Sun Oct 25 14:58:46 2020 kern.debug kernel: [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=132768
Sun Oct 25 14:58:46 2020 kern.debug kernel: [ 0.000000] pcpu-alloc: [0] 0
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 32512
Sun Oct 25 14:58:46 2020 kern.notice kernel: [ 0.000000] Kernel command line: console=ttyS0,115200 rootfstype=squashfs,jffs2
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.000000] Writing ErrCtl register=00053a74
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.000000] Readback ErrCtl register=00053a74
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.000000] Memory: 124832K/131072K available (3565K kernel code, 178K rwdata, 856K rodata, 192K init, 214K bss, 6240K reserved, 0K cma-reserved)
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.000000] NR_IRQS: 256
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.000000] intc: using register map from devicetree
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.000000] CPU Clock: 575MHz
Sun Oct 25 14:58:46 2020 kern.crit kernel: [ 0.000000] timer_probe: no matching timers found
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6647862422 ns
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.000012] sched_clock: 32 bits at 287MHz, resolution 3ns, wraps every 7469508094ns
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.007549] Calibrating delay loop… 380.92 BogoMIPS (lpj=1904640)
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.073454] pid_max: default: 32768 minimum: 301
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.078149] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.084500] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.097197] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.106692] futex hash table entries: 256 (order: -1, 3072 bytes)
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.112640] pinctrl core: initialized pinctrl subsystem
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.118994] NET: Registered protocol family 16
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.148842] mt7621_gpio 10000600.gpio: registering 32 gpios
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.154452] mt7621_gpio 10000600.gpio: registering 32 gpios
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.160050] mt7621_gpio 10000600.gpio: registering 32 gpios
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.170258] clocksource: Switched to clocksource MIPS
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.176293] NET: Registered protocol family 2
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.181544] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.188236] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.194418] TCP: Hash tables configured (established 1024 bind 1024)
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.200665] UDP hash table entries: 256 (order: 0, 4096 bytes)
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.206263] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.212612] NET: Registered protocol family 1
Sun Oct 25 14:58:46 2020 kern.debug kernel: [ 0.216787] PCI: CLS 0 bytes, default 32
Sun Oct 25 14:58:46 2020 kern.warn kernel: [ 0.220104] Crashlog allocated RAM at address 0x3f00000
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.226691] workingset: timestamp_bits=30 max_order=15 bucket_order=0
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.238814] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.244433] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.264016] io scheduler noop registered
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.267747] io scheduler deadline registered (default)
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.273680] gpio-export gpio_export: 1 gpio(s) exported
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.278893] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.288097] console [ttyS0] disabled
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.291590] 10000c00.uartlite: ttyS0 at MMIO 0x10000c00 (irq = 28, base_baud = 2500000) is a 16550A
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.300309] console [ttyS0] enabled
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.307308] bootconsole [early0] disabled
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.316082] 10000d00.uart1: ttyS1 at MMIO 0x10000d00 (irq = 29, base_baud = 2500000) is a 16550A
Sun Oct 25 14:58:46 2020 kern.err kernel: [ 0.325668] cacheinfo: Failed to find cpu0 device node
Sun Oct 25 14:58:46 2020 kern.warn kernel: [ 0.330923] cacheinfo: Unable to detect cache hierarchy for CPU 0
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.337856] spi-mt7621 10000b00.spi: sys_freq: 191666666
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.359745] m25p80 spi0.0: w25q128 (16384 Kbytes)
Sun Oct 25 14:58:46 2020 kern.notice kernel: [ 0.364633] 4 fixed-partitions partitions found on MTD device spi0.0
Sun Oct 25 14:58:46 2020 kern.notice kernel: [ 0.371084] Creating 4 MTD partitions on “spi0.0”:
Sun Oct 25 14:58:46 2020 kern.notice kernel: [ 0.375958] 0x000000000000-0x000000030000 : “u-boot”
Sun Oct 25 14:58:46 2020 kern.notice kernel: [ 0.381945] 0x000000030000-0x000000040000 : “u-boot-env”
Sun Oct 25 14:58:46 2020 kern.notice kernel: [ 0.388197] 0x000000040000-0x000000050000 : “factory”
Sun Oct 25 14:58:46 2020 kern.notice kernel: [ 0.394283] 0x000000050000-0x000001000000 : “firmware”
Sun Oct 25 14:58:46 2020 kern.notice kernel: [ 0.472799] 2 uimage-fw partitions found on MTD device firmware
Sun Oct 25 14:58:46 2020 kern.notice kernel: [ 0.478834] 0x000000050000-0x0000001c9232 : “kernel”
Sun Oct 25 14:58:46 2020 kern.notice kernel: [ 0.484815] 0x0000001c9232-0x000001000000 : “rootfs”
Sun Oct 25 14:58:46 2020 kern.notice kernel: [ 0.490759] mtd: device 5 (rootfs) set to be root filesystem
Sun Oct 25 14:58:46 2020 kern.notice kernel: [ 0.497996] 1 squashfs-split partitions found on MTD device rootfs
Sun Oct 25 14:58:46 2020 kern.notice kernel: [ 0.504353] 0x000000c20000-0x000001000000 : “rootfs_data”
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.511569] libphy: Fixed MDIO Bus: probed
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.525347] rt3050-esw 10110000.esw: link changed 0x00
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.533667] mtk_soc_eth 10100000.ethernet eth0: mediatek frame engine at 0xb0100000, irq 5
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.543959] NET: Registered protocol family 10
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.552683] Segment Routing with IPv6
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.556523] NET: Registered protocol family 17
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.561155] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.574303] 8021q: 802.1Q VLAN Support v1.8
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.590897] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 0.599084] Freeing unused kernel memory: 192K
Sun Oct 25 14:58:46 2020 kern.warn kernel: [ 0.603635] This architecture does not have kernel memory protection.
Sun Oct 25 14:58:46 2020 user.info kernel: [ 1.847666] init: Console is alive
Sun Oct 25 14:58:46 2020 user.info kernel: [ 1.851456] init: - watchdog -
Sun Oct 25 14:58:46 2020 kern.notice kernel: [ 2.271444] random: fast init done
Sun Oct 25 14:58:46 2020 user.info kernel: [ 5.205963] kmodloader: loading kernel modules from /etc/modules-boot.d/
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 5.453654] usbcore: registered new interface driver usbfs
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 5.459348] usbcore: registered new interface driver hub
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 5.464919] usbcore: registered new device driver usb
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 5.476393] exFAT: Version 1.2.9
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 5.514431] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
Sun Oct 25 14:58:46 2020 kern.notice kernel: [ 5.530829] SCSI subsystem initialized
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 5.540460] ehci-platform: EHCI generic platform driver
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 5.556031] phy phy-10120000.usbphy.0: remote usb device wakeup disabled
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 5.562844] phy phy-10120000.usbphy.0: UTMI 16bit 30MHz
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 5.568164] ehci-platform 101c0000.ehci: EHCI Host Controller
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 5.574034] ehci-platform 101c0000.ehci: new USB bus registered, assigned bus number 1
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 5.582193] ehci-platform 101c0000.ehci: irq 26, io mem 0x101c0000
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 5.610285] ehci-platform 101c0000.ehci: USB 2.0 started, EHCI 1.00
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 5.617662] hub 1-0:1.0: USB hub found
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 5.621974] hub 1-0:1.0: 1 port detected
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 5.629763] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 5.638071] ohci-platform: OHCI generic platform driver
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 5.643712] ohci-platform 101c1000.ohci: Generic Platform OHCI controller
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 5.650671] ohci-platform 101c1000.ohci: new USB bus registered, assigned bus number 2
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 5.658790] ohci-platform 101c1000.ohci: irq 26, io mem 0x101c1000
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 5.735334] hub 2-0:1.0: USB hub found
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 5.739616] hub 2-0:1.0: 1 port detected
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 5.747043] uhci_hcd: USB Universal Host Controller Interface driver
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 5.761602] usbcore: registered new interface driver usb-storage
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 5.770583] usbcore: registered new interface driver uas
Sun Oct 25 14:58:46 2020 user.info kernel: [ 5.776747] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
Sun Oct 25 14:58:46 2020 user.info kernel: [ 5.794648] init: - preinit -
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 7.491764] rt3050-esw 10110000.esw: link changed 0x00
Sun Oct 25 14:58:46 2020 kern.notice kernel: [ 11.472130] jffs2: notice: (419) jffs2_build_xattr_subsystem: complete building xattr subsystem, 20 of xdatum (3 unchecked, 17 orphan) and 86 of xref (19 dead, 6 orphan) found.
Sun Oct 25 14:58:46 2020 user.info kernel: [ 11.489987] mount_root: switching to jffs2 overlay
Sun Oct 25 14:58:46 2020 kern.warn kernel: [ 11.567686] overlayfs: upper fs does not support tmpfile.
Sun Oct 25 14:58:46 2020 user.warn kernel: [ 11.582390] urandom-seed: Seeding with /etc/urandom.seed
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 11.596478] rt3050-esw 10110000.esw: link changed 0x02
Sun Oct 25 14:58:46 2020 user.info kernel: [ 11.794932] procd: - early -
Sun Oct 25 14:58:46 2020 user.info kernel: [ 11.797968] procd: - watchdog -
Sun Oct 25 14:58:46 2020 user.info kernel: [ 12.501532] procd: - watchdog -
Sun Oct 25 14:58:46 2020 user.info kernel: [ 12.505024] procd: - ubus -
Sun Oct 25 14:58:46 2020 kern.notice kernel: [ 12.742538] random: ubusd: uninitialized urandom read (4 bytes read)
Sun Oct 25 14:58:46 2020 kern.notice kernel: [ 12.871140] random: ubusd: uninitialized urandom read (4 bytes read)
Sun Oct 25 14:58:46 2020 kern.notice kernel: [ 12.892682] random: ubusd: uninitialized urandom read (4 bytes read)
Sun Oct 25 14:58:46 2020 user.info kernel: [ 12.906111] procd: - init -
Sun Oct 25 14:58:46 2020 user.info kernel: [ 18.178640] kmodloader: loading kernel modules from /etc/modules.d/*
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 18.233567] ntfs: driver 2.1.32 [Flags: R/O MODULE].
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 18.283200] tun: Universal TUN/TAP device driver, 1.6
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 18.307744] ip6_tables: (C) 2000-2006 Netfilter Core Team
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 18.343991] Netfilter messages via NETLINK v0.30.
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 18.363742] ip_set: protocol 6
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 18.473919] u32 classifier
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 18.476675] input device check on
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 18.480451] Actions configured
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 18.501781] Mirror/redirect action on
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 18.532428] nf_conntrack version 0.5.0 (2048 buckets, 8192 max)
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 18.620581] fuse init (API version 7.26)
Sun Oct 25 14:58:46 2020 kern.warn kernel: [ 19.711299]
Sun Oct 25 14:58:46 2020 kern.warn kernel: [ 19.711299] === pAd = c0612000, size = 1008552 ===
Sun Oct 25 14:58:46 2020 kern.warn kernel: [ 19.720914] ← RTMPAllocTxRxRingMemory, Status=0, ErrorValue=0x
Sun Oct 25 14:58:46 2020 kern.warn kernel: [ 19.728683] ← RTMPAllocAdapterBlock, Status=0
Sun Oct 25 14:58:46 2020 kern.warn kernel: [ 19.733308] RtmpChipOpsHook(748): Not support for HIF_MT yet!
Sun Oct 25 14:58:46 2020 kern.warn kernel: [ 19.739133] mt7628_init()–>
Sun Oct 25 14:58:46 2020 kern.warn kernel: [ 19.742069] mt7628_init(FW(8a00), HW(8a01), CHIPID(7628))
Sun Oct 25 14:58:46 2020 kern.warn kernel: [ 19.747543] e2.bin mt7628_init(1142)::(2), pChipCap->fw_len(63536)
Sun Oct 25 14:58:46 2020 kern.warn kernel: [ 19.753816] mt_bcn_buf_init(289): Not support for HIF_MT yet!
Sun Oct 25 14:58:46 2020 kern.warn kernel: [ 19.759637] <–mt7628_init()
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 19.830441] usbcore: registered new interface driver cdc_acm
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 19.836190] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 19.866749] usbcore: registered new interface driver cdc_wdm
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 19.887507] ip_tables: (C) 2000-2006 Netfilter Core Team
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 19.904052] usbcore: registered new interface driver ipheth
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 20.112824] ctnetlink v0.93: registering with nfnetlink.
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 20.400839] usbcore: registered new interface driver usbserial
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 20.406851] usbcore: registered new interface driver usbserial_generic
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 20.413618] usbserial: USB Serial support registered for generic
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 20.459219] wireguard: WireGuard 0.0.20191012 loaded. See www.wireguard.com for information.
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 20.467855] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld Jason@zx2c4.com. All Rights Reserved.
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 20.605951] xt_time: kernel timezone is -0000
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 20.623392] usbcore: registered new interface driver cdc_ether
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 20.645506] usbcore: registered new interface driver cdc_ncm
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 20.665774] usbcore: registered new interface driver cp210x
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 20.671632] usbserial: USB Serial support registered for cp210x
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 20.695175] usbcore: registered new interface driver huawei_cdc_ncm
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 20.744887] PPP generic driver version 2.4.2
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 20.762701] PPP MPPE Compression module registered
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 20.777065] NET: Registered protocol family 24
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 20.792652] usbcore: registered new interface driver qmi_wwan
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 20.813297] usbcore: registered new interface driver rndis_host
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 20.835711] usbcore: registered new interface driver sierra
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 20.841558] usbserial: USB Serial support registered for Sierra USB modem
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 20.879178] usbcore: registered new interface driver sierra_net
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 20.911683] usbcore: registered new interface driver option
Sun Oct 25 14:58:46 2020 kern.info kernel: [ 20.917427] usbserial: USB Serial support registered for GSM modem (1-port)
Sun Oct 25 14:58:46 2020 user.info kernel: [ 20.951015] kmodloader: done loading kernel modules from /etc/modules.d/*
Sun Oct 25 14:58:46 2020 daemon.notice procd: /etc/rc.d/S15gl_fixdomain: uci: Parse error (option/list command found before the first section) at line 64, byte 0
Sun Oct 25 14:58:46 2020 daemon.notice procd: /etc/rc.d/S18firewall_gl: uci: Entry not found
Sun Oct 25 14:58:48 2020 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Sun Oct 25 14:58:48 2020 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Sun Oct 25 14:58:49 2020 daemon.info dnsmasq[1256]: started, version 2.80test2 cachesize 150
Sun Oct 25 14:58:49 2020 daemon.info dnsmasq[1256]: DNS service limited to local subnets
Sun Oct 25 14:58:49 2020 daemon.info dnsmasq[1256]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC no-ID loop-detect inotify dumpfile
Sun Oct 25 14:58:49 2020 daemon.info dnsmasq[1256]: using local addresses only for domain test
Sun Oct 25 14:58:49 2020 daemon.info dnsmasq[1256]: using local addresses only for domain onion
Sun Oct 25 14:58:49 2020 daemon.info dnsmasq[1256]: using local addresses only for domain localhost
Sun Oct 25 14:58:49 2020 daemon.info dnsmasq[1256]: using local addresses only for domain invalid
Sun Oct 25 14:58:49 2020 daemon.info dnsmasq[1256]: using local addresses only for domain bind
Sun Oct 25 14:58:49 2020 daemon.info dnsmasq[1256]: using local addresses only for domain lan
Sun Oct 25 14:58:49 2020 daemon.warn dnsmasq[1256]: no servers found in /tmp/resolv.conf.auto, will retry
Sun Oct 25 14:58:50 2020 daemon.info dnsmasq[1256]: read /etc/hosts - 4 addresses
Sun Oct 25 14:58:50 2020 daemon.info dnsmasq[1256]: read /tmp/hosts/dhcp.cfg01411c - 0 addresses
Sun Oct 25 14:58:50 2020 kern.info kernel: [ 28.089403] rt3050-esw 10110000.esw: link changed 0x00
Sun Oct 25 14:58:52 2020 daemon.notice procd: /etc/rc.d/S19gl_ipv6: uci: Parse error (option/list command found before the first section) at line 64, byte 0
Sun Oct 25 14:58:52 2020 daemon.notice procd: /etc/rc.d/S20network: Failed to load config file: : Parse error (option/list command found before the first section) at line 64, byte 0
Sun Oct 25 14:58:53 2020 user.notice : Added device handler type: tunnel
Sun Oct 25 14:58:53 2020 user.notice : Added device handler type: Network device
Sun Oct 25 14:58:53 2020 user.notice : Added device handler type: bridge
Sun Oct 25 14:58:53 2020 user.notice : Added device handler type: veth
Sun Oct 25 14:58:53 2020 user.notice : Added device handler type: macvlan
Sun Oct 25 14:58:53 2020 user.notice : Added device handler type: 8021ad
Sun Oct 25 14:58:53 2020 user.notice : Added device handler type: 8021q
Sun Oct 25 14:58:54 2020 daemon.notice procd: /etc/init.d/network: uci: Parse error (option/list command found before the first section) at line 64, byte 0
Sun Oct 25 14:58:54 2020 daemon.notice procd: /etc/rc.d/S21initswitch: uci: Entry not found
logread (2/2)
Sun Oct 25 14:58:55 2020 daemon.notice procd: /etc/rc.d/S30gl_ssids: uci: Entry not found
Sun Oct 25 14:58:55 2020 daemon.notice procd: /etc/init.d/gl_ssids: uci: Entry not found
Sun Oct 25 14:58:56 2020 daemon.notice procd: /etc/init.d/network: ifconfig: SIOCGIFFLAGS: No such device
Sun Oct 25 14:58:56 2020 daemon.notice procd: /etc/init.d/network: mt7628(mt7628): disable failed
Sun Oct 25 14:58:56 2020 daemon.notice procd: /etc/init.d/network: uci: Parse error (option/list command found before the first section) at line 64, byte 0
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.174348] TX_BCN DESC a6fe2000 size = 320
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.178661] RX[0] DESC a6fe4000 size = 2048
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.183334] RX[1] DESC a6fe5000 size = 1024
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.233680] prepare to get e2p access------------
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.238727] E2pAccessMode=2
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.242555] cfg_mode=9
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.244948] cfg_mode=9
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.247343] wmode_band_equal(): Band Equal!
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.255911] APSDCapable[0]=0
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.258831] APSDCapable[1]=0
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.261760] APSDCapable[2]=0
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.264676] APSDCapable[3]=0
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.267593] APSDCapable[4]=0
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.270517] APSDCapable[5]=0
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.273435] APSDCapable[6]=0
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.276351] APSDCapable[7]=0
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.279268] APSDCapable[8]=0
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.282193] APSDCapable[9]=0
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.285110] APSDCapable[10]=0
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.288114] APSDCapable[11]=0
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.291135] APSDCapable[12]=0
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.294139] APSDCapable[13]=0
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.297143] APSDCapable[14]=0
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.300148] APSDCapable[15]=0
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.303163] default ApCliAPSDCapable[0]=0
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.692711] Key1Str is Invalid key length(0) or Type(1)
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.698195] Key1Str is Invalid key length(0) or Type(1)
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.703881] Key2Str is Invalid key length(0) or Type(1)
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.709363] Key2Str is Invalid key length(0) or Type(1)
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.715058] Key3Str is Invalid key length(0) or Type(1)
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.720559] Key3Str is Invalid key length(0) or Type(1)
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.726235] Key4Str is Invalid key length(0) or Type(1)
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.731737] Key4Str is Invalid key length(0) or Type(1)
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.768048] load fw image from fw_header_image
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.772574] AndesMTLoadFwMethod1(2548)::pChipCap->fw_len(63536)
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.778571] FW Version:
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.778576] _
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.781070] e
Sun Oct 25 14:58:57 2020 kern.warn kernel: [ 35.782665] 2
Have you added tap-easytether interface to the wan zone?
Yes, I believe so, I followed the tutorial.
How can I have a remote check using any desk? Timezone and time?
