Jmir
Hey there,
I contacted my Router to my Xbox. when I plug my router to power it won’t scan my WIFI automatically and needs scan repeater eveytime.
I already turn on autoscan and re-connect under repeater option. any other options should I change?
Version: 3.203
alzhao
2
Mango connect to your Xbox via wifi?
It should do auto scan and reconnect, unless it fails to connect for many times.
I suggest you do this:
First upgrade to 3.212 beta3. We always solve problems based on latest firmware.
Then if this still happens, ssh to the router and get the log using logread
