My original (factory) MT300n-v1 failed “opkg update”, so I upgraded FW the latest version 2.265, but “opkg update” still fails, with the same signature errors:
Downloading 404 Page not found - GL.iNet.
Signature check failed.
Remove wrong Signature file.
For your information, my opkg.conf, after upgrade, is as follows:
dest root /
dest ram /tmp
lists_dir ext /var/opkg-lists
option overlay_root /overlay
option check_signature 1
And my distfeeds.conf is as follows:
src/gz chaos_calmer_base 404 Page not found - GL.iNet
src/gz chaos_calmer_luci 404 Page not found - GL.iNet
src/gz chaos_calmer_management 404 Page not found - GL.iNet
src/gz chaos_calmer_packages 404 Page not found - GL.iNet
src/gz chaos_calmer_routing 404 Page not found - GL.iNet
src/gz chaos_calmer_telephony 404 Page not found - GL.iNet
src/gz chaos_calmer_oldpackages 404 Page not found - GL.iNet
src/gz chaos_calmer_node 404 Page not found - GL.iNet
The FW version 2.265 folder has a different distfeeds.conf:
src/gz glinet_core http://download.gl-inet.com/releases/kmod-3.0/ramips/mt7620
src/gz glinet_base http://download.gl-inet.com/releases/packages-3.x/ramips/base
src/gz glinet_gli_pub http://download.gl-inet.com/releases/packages-3.x/ramips/gli_pub
src/gz glinet_packages http://download.gl-inet.com/releases/packages-3.x/ramips/packages
src/gz glinet_luci http://download.gl-inet.com/releases/packages-3.x/ramips/luci
src/gz glinet_routing http://download.gl-inet.com/releases/packages-3.x/ramips/routing
src/gz glinet_telephony http://download.gl-inet.com/releases/packages-3.x/ramips/telephony
src/gz glinet_glinet http://download.gl-inet.com/releases/packages-3.x/ramips/glinet
But even when with this list I still get the same signature errors.
How can I get around this problem?
